Question about Palm AT&T C/PHONE PALM CENTRO S64801
Cell phone shows "receiving message," but no button can retrieve. Can't turn phone off
When pushing turn off button it shows "cannot cancel get message." No button works to get message, and I cell phone won't turn off.
I can't send or receive picture messages on my Radiant Z740 Go Phone Why not?
Did it stop sending/receiving or did you just get the phone recently, having popped your sim card from a non-smart phone into the Z740?
If so, you will need to purchase a data plan from your phone carrier in addition to your phone service. If this is not the case ...
Tap messaging icon
Tap the far far right function button at the bottom of the phone
Choose Settings
Check mark Auto-retrieve
MMS Creation mode = Free
Enable WAP push recieving
With those basic settings you should be able to recieve and send. If you have a data plan. If you have a plan you should conact customer service with your carrier. The number for customer service should be displayed on the same settings page.
Dec 07, 2014 | Cell Phones
I've received a mms message and my screen say MMS retrieval failed, how can read this message?
This often has to do with a network error, or your phone its self. The best solutions are as follows.
  1. Turn your phone off and turn it back on and attempt to retrieve the message again.
  2. If that fails, ask the sender to resend the message.
If the above solutions do not work you might need to consult with your wireless provider.
Jun 03, 2011 | Cell Phones
HTC smart F.3188 not responding to factory reset.
Hold on talk and cancel buttons and push reset button once. Hold on talk and cancel buttons until you receive message on the screen saying, 'this will delete all your data in the set except the rom', then push center button to hardrest. Before resetting keep a bcakup of your data if there is an important data in your set.
Apr 13, 2011 | HTC Cell Phones
How to deactivate camp line on Necv Dterm80
The LCD screen of my DTerm80 was showing a "CAMP-ON" message along with someone else's name. I fixed it by pushing the "Exit" button then the second softbutton, under "Clbk", then the first softbutton, under "All". I received the message ""CLEAR CALLBACK CAMP CANCEL"
Fixed my problem.
Jan 28, 2011 | NEC Dterm DTP 16D-1 Corded Phone
When i push the intercom then message button to retrieve messages it tells me invalid across the screen
while the handset is hung up (without pressing the intercom button) press the "MESSAGE" button, on the display it should show ~why~ the message light is on (cause it is possible someone tried to intercom you, then hit the wrong button) after that you can turn off your light by pressing:
1) INTERCOM
2) 700
3) *your extension #*
it is possible that the extension that turned on your message light is no longer in service, making it an invalid extension
Jan 06, 2011 | Panasonic KX-T7431 Corded Phone
My LG pop will not let me retrieve mms messages! help please!!!!
The MMS delivery process is triggered by a special SMS message called the "MMS Notification". The "MMS Notification" contains a URL pointer back to the full content of the MMS message. So when the receiving phone gets the MMS Notification, it must connect to the URL in the notification in order to retrieve the actual message content.
The error that you include above looks like the URL cannot be fetched.
If it worked before, but it does not work now ... then it is possible that something has changed with regard to your firewall or network configuration. The receiving device needs to actually connect back to host server in order to retrieve the MMS content.
It is also possible that something has changed in the configuration at your mobile operator. Hope it will be helpful to you.
Apr 05, 2010 | Cell Phones
How do I retrieve messages on the Panasonic KX-T7030 phone?
  • Call into your mailbox (usually by dialing intercom 165)
  • Press 4, and 4 again (for "Incomplete call handling")
    By default, three options are enabled:
    option #1: leave a message
    options #5: call the operator
    option #6: return to top menu
  • Follow the audible prompts to disable options 5 and 6
Here are some other features you may need
  • Make sure your Auto Answer button is lit up, so you can receive intercom announcements, and respond hands-free.
  • Use the Call Forwarding (FWD) to send un-answered calls to another phone or to voicemail
  • Press BGM (or 1 on the touch-tone pad) for background music, if your system is equipped.
  • Use Absent Messages to show text messages on other people's phones when you are away.
  • Use System Call Waiting so your phone will ring even when you're on the phone. Press Intercom and dial 7311 to set it up, or 7310 to cancel.
  • Use Do Not Disturb (DND) when you don't want to receive calls. Press Intercom, press FWD/DND and dial 1 to activate, or 0 to cancel.
  • Press MESSAGE when you call a busy intercom number. This will turn on the MESSAGE light on the other phone, and the other person can tap that button to automatically call you back.
  • If you get a busy signal when you call an intercom number, you can signal the other person by dialing 1 (if that phone is programmed for System Call Waiting (above).
  • Dial 330 to make an announcement to all phones.
  • If you want your phone to automatically select an outside line when you pick up the handset, press PROGRAM, dial 99, dial 12, press STORE, press PROGRAM
  • Feb 12, 2009 | Panasonic KX-T7030 Corded Phone
    Phone turns off momentarily and reboots when I try to retrieve messages.
    It seemed like there is a corruption in the phone's firmware. You should be able to take it back to where you bought it and get a replacement.
    Note** The firmware tells your phone what to do when you press any button....without it, the phone is nothing more than a shell.
    Mar 20, 2008 | Samsung SCH-u740 Cellular Phone
    Palm AT&T C/PHONE PALM CENTRO S64801 Logo
    16 people viewed this question
    Top Palm Cell Phones Experts
    Computer Repairing
    Computer Repairing
    fhonwizards
    wayne chamberlain
    Are you a Palm Cell Phone Expert? Answer questions, earn points and help others
