Question about Toro Power Clear 621 R
Toro clear won't start - Toro Power Clear 621 R
    Master:
  • 755 Answers
Bad gas , plug ,air filter , no spark ck all need all 3 to start
Posted on Jan 20, 2015
Toro 149cc Lawn Mower Won't Start
Most gas mower carburetors have a tiny hole for the fuel to rise into the vacuum venturi throat of the intake. The hole in this riser tube which goes down the center of your float chamber to the area where the fuel sits in the bowl is only as big as dental floss. Take the tine of a wire brush to clear it of crystallized or varnished gasoline and oxidized pot metal tube crust. When they make stainless carburetors, it will eliminate half of the heart attacks caused by this problem. Additives and condensation that settle out in old gas also can lead to clogging.
Apr 17, 2013 | Toro Lawn Mower With Toro Power Tools
Toro Power Clear 418 ZE Snow Blower won't stay started
The main jet of your carb is clogged and you need to open carb and clear the obstruction - spray carb cleaner on the bolt that holds the gas container to bottom of carb - also spray all the innards along with any tube that protrudes into the gas can.
Then using air compressor blow the sucker out and reassemble. That should do it.
Dec 06, 2012 | Toro Garden
Toro z master won't start
bypass the safety switches one at a time to test them
Sep 19, 2012 | Toro 52" 27hp Z Master Zero Turn Lawn...
Toro 6.5 tecumseh won't start
replace your spark plug. it takes a Champion J19LM. If you left fuel in your tank over the winter then drain your tank and your float bowl. Add clean fresh fuel and it should go if not you need to clean your carb
May 17, 2012 | Toro Power Lawn Mower
Proline toro commercial 32 inch won't run
try starting fluid that will see if its a fuel problem then check for spark
Apr 19, 2012 | Toro Garden
Toro push mower with B & S engine won' start unless I put gas in spark plug hole.. I removed carburater bowl and bolt holding bowl is clear. What's wrong?
There is trash in your carburetor blocking the main jet. You are going to have to remove the carburetor and give the carburetor a thorough cleaning. Watch out for the spray carb cleaner, wear safety glasses or a face shield as when cleaning out the carb the passages can redirect back at your face.
I hope this gets you going again.
Aug 05, 2011 | Toro Lawn Mower With Toro Power Tools
Looking for a manual for a Toro 22 inch recyler. Lawn mower hs 6.5hsp tecumseh engine. Won't start. Do not see spark .
You can search for your manual as well as other helpful information at the following site:
https://homeownersolutions.toro.com/portal/server.pt/community/product_center/225#productDetailsPage
It would be helpful to have your Model Number and the Year your machine was made.
May 23, 2011 | Toro Lawn Mower With Toro Power Tools
Toro Power Clear 621 R Logo
494 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
