Question about Maytag Neptune Washer Door Mah3000aww
Water not completely draining
Washer drains but when you spin the washer by hand you can still hear water. When left for long duration it causes odor.
    Prodigy:
    An expert who has answered 500 questions.
  • Maytag Expert
  • 517 Answers
Take out the plug first????????????????????????????????????
may need to look at the pump and pipes there may be a blockage or pump is worn and needs to be replaced
Posted on Jan 13, 2014
2 Suggested Answers
mkt2488
  • 23 Answers
SOURCE: fabric-matic
there is typically a motor driven pump that removes the water from the drum to the drain hose. sometimes a sock or small article of clothing will get in this pump or the hose and clog it up. also, sometimes the pump itself will go bad. you need to disconnect your drain hose from the pump and look to see if it is functional.
Posted on Jan 28, 2012
Machine stops in midcycle and doesn't drain or spin. Pressing the drain & spin button causes all lights to flash & dial shows 'FO5'.
No spin, or lite spin try these: bare in mind that many times there is no spin it can be due to a clogged water pump so check it for debris and or broken propeller.
Other items to check Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. Bare in mind the lid switch assembly can fail either mechanically or electrically.
Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Or try the hand test:
If no hammering sound has ever been heard out of this machine, one of the unofficial tests we professional appliantologists will do in the field is called the Hand Test. WARNING:This test is not sanctioned by Whirlpool Corporation; it involves bypassing safety equipment and then putting your hand on and near rotating machinery which could result in injury, dismemberment, disfigurement, disembowelment, mangling, hideous screaming, and a ****** *****. Proceed at your own risk! Have a nice day.
- put the timer on a spin cycle and open the lid- grab the inner basket with maybe 30% to 40% of your hand strength with your left hand
- turn on the machine and bypass the lid switch by depressing the lid switch with a key until the machine begins to spin
- if the clutch is engaging properly, the basket should immediately begin to spin and slip through your hand
- if it takes very little force to stop the tub from spinning, the clutch needs to be replaced.
Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either)
Next if belt driven check for a loose, worn or broken belt. And on some models there is no clutch but rather what is called a splutch. And a MODE shifter. These can go bad and effect the spin cycle.
On some front load models u may need to check the STATOR assembly.
The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Sometimes a no spin machine can be due to a plugged waterpump hose or obstructed water pump propeller. Check these by eye and hand. And in some models check with a meter for continuity and voltage.
LID SWITCH TEST- next step is toremove the cabinetand jumper the lid switch harness (tan to gray). Put the unit in spin and watch the shiny metal clutch disc that is on top of the transmission where the shaft comes out. If the machine starts and runs in spin, check to see if the disc is spinning. If it is, then the problem isnot in the gearcase- look for trouble in theclutch,
basket driveor the tub drive block
If, on the other hand, the disc is NOT spinning, check for a problem withthe motor drive coupleror one of its retainers. This washer doesn't have a belt. Instead, the motor is directly coupled to the gearcase by a drive coupler; that's why it's called a direct drive washer.
Read more:Diagnosing and Repairing Spin and Agitate Problems in a Whirlpool / Kenmore Direct Drive Washer
http://fixitnow.com/wp/2010/07/07/diagnosing-and-repairing-spin-and-agitate-problems-in-a-whirlpool-kenmore-direct-drive-washer/#ixzz3XW7eZwiN
By the way my advice is free cuz God is good!
Washer will not drain:
Thedrain water pumpis the main part in your washing machine that pumps out the water. If this is defective or has failed in any way, this will be the reason why your washer will not drain the water. Before you order a new drain pump, make sure tocheck the pump to be sure a small object like clothing or similar has not lodged itself insideof it causing the NO DRAIN issue and even a no spin issue?. If the drain pump is not clogged, you can test it with a multimeter and remove and replace if needed. Go to Google or YouTube and search for "Replace Washing Machine Drain Pump" then type your brand and model number of washer to show you details on replacement.
Read more:http://removeandreplace.com/2014/10/30/fix-washing-machine-that-wont-drain-washer-not-draining-water/#ixzz3X2LbXMWJ
The washing machinedrain hoseis where the water flows through to get the water out.If this drain hose is blocked, kinked, bent, or clogged, the washer will NOT be able to remove the waterfrom the tub. Check the drain hose to be sure it allows the water to flow freely. You can take the drain hose off and run water through it in your sink to be sure it is not blocked. If there is water STILL in the washer when you remove the drain hose, grab a bucket as the water will exit from where you disconnected it
Thewater pump belt(to drain out the water) may have broke or become frayed or loose.If this belt breaks then it is unable to drain and remove the water from your washer. Inspect the belt to see if this is causing theNO DRAINissue and remove and replace if needed.
If thelid switchis not working as required it will cause your washer to not drain (and many other problems).This may be unlikely as a bad lid switch will usually cause your washer to alsonot agitate or spin.However on some models this can vary. The best thing to do if you have a suspected bad lid switch is to test it. It can fail electrically and or mechanically. If mechanical failure is the issue, you should be able to see if it is cracked, broken, or not in place to make contact with the lid. To test it electrically, use a multimeter set on Ohms and test it for continuityMy advice is free cuz God is good!
Fix Washing Machine That Won Drain Washer Not Draining Water Diagnosing and Repairing Spin and Agitate Problems in Whirlpool Kenmore... Fix Washing Machine That Won Drain Washer Not Draining Water
Jan 09, 2017 | Washing Machines
Mah7500aww
what it sounds like is the drain from your house wher the washing machine drain hose hooks into is daraining slow so after it spins and pumps the water out the pump shuts off but the drain hose is syphoning the water back into the machine,theres probally lint built up in your drain pipe
Jul 09, 2008 | Maytag Neptune MAH7500WH Front Load Washer
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
My washer will spin but not drain
Check to see that your drain pump is working. Normally the drain pump is somewhat noisy and you should hear it start whenever a cycle is completed and your washer needs to drain the water out. If your pump is working, check your drain piping for blockages.
Sep 21, 2014 | Samsung WF337AA Front Load Washer
You can hear water behind the drum when you spin
I don't believe you have a problem with your washer. It is NORMAL to have residual water in the drain lines and drain pump following a wash cycle. You will be able to hear the water sloshing around if you move the drum or drain lines. This is the lowest point of the drain cycle and gravity will ALWAYS cause some water to be there. As long as the water is not visible in the spin basket inside the drum, and the washer is properly draining during the wash and rinse cycles, you have nothing to worry about.
If you have any questions, please post back and let me know. I hope this is helpful to you.
May 12, 2010 | Maytag Neptune MAH5500B Front Load Washer
WHEN WASH IS COMPLETE, WHEN YOU SPIN THE TUB BY HAND YOU CAN HEAR WATER SLASHING.
The pump cannot completely drain all the water out of washers. There will be some water left in the bottom of the tub that you can't see but here slosh around if you move the basket. If your clothes are not wet, this is probably normal.
Jan 24, 2010 | Maytag Neptune MAH5500B Front Load Washer
AFTER SPINNING, WATER IS LEFT SOMEWHERE IN THE DRUM. i CAN'T SEE IT BUT CAN HEAR IT AND THE WASHER SMELLS BAD.
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
May 31, 2009 | Estate TAWX700JQ Top Load Washer
Water still in bottom of tub after drain/spin cycle
I removed the drain hose from the bottom left rear corner of the washer & cleaned a large amount of gooey sludge from the bottom of the drain inside the washing machine.
Feb 14, 2009 | Kenmore 12502 Top Load Washer
Maytag Neptune Washer Door Mah3000aww Logo
75 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
