Question about Craftsman 28901 Riding Lawn Tractor
Transmission will not engage - Craftsman 28901 Riding Lawn Tractor
Replaced neutral safety switch starter still tries to engage when clutch pedal is engaged
Not enough information to answer. Need manufacturer, year, model, engine size, 2WD/4WD/AWD, and Manual or Automatic transmission as applicable in order to answer the question.
Nov 22, 2015 | Cars & Trucks
How to fix 06 chevy equinox shifter its only engaging in drive?
Check you transmission fluid, if it is low, it will not engage the other gears
Feb 22, 2015 | 2006 Chevrolet Equinox
Why doesn't my transmission engage when i shft into gear on a 98 cirrus
Check that the shift cable is connected (top of the transmission)
Sep 03, 2014 | 1998 Chrysler Cirrus
Ford escape transmission
Run the fault codes to see if the TCM ( transmission control module) is faulty or servos have failed . have a pressure test done on the box to check operating pressures for the clutch packs and bands.
Oct 27, 2013 | Ford Explorer Cars & Trucks
Transmission won't engage
WHAT CAR IS IT? You need to thell the car that you have put a new transaxle.
Nov 30, 2012 | Cars & Trucks
Transmission will not engage in drive. Will only engage in reverse.
your transmission forward clutch pack has failed, u are going to need an overhaul to correct this
Dec 31, 2009 | 1995 Nissan 240SX
The transmission will not engage
If the unit is between1998 & 2004 , the gears in the transmission may be stripped.To tell for sure, remove belt cover, start the unit & engage the drive. If the pulley turns & not the axel, the gears are stripped.
Aug 11, 2009 | Toro Lawn Mower With Toro Power Tools
2002 hyundai santa fe transmission will not engage
You might have lost your lower gears, I would have someone look at it to see if your gears are gone or if its just a faulty sensor.
Jun 15, 2009 | 2002 Hyundai Santa Fe
Transmission not engaging
is it manual or automatic transmission?
Dec 18, 2008 | 1990 Toyota 4Runner
Craftsman 28901 Riding Lawn Tractor Logo
14 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
