Question about Frigidaire Affinity AEQ6000WH Dryer
Frigidaire Dryer e72 problem - Frigidaire Affinity AEQ6000WH Dryer
Frigidaire front load dryer, displays E72 call service, what does this mean?
Hi Don, this is AP!
I understand you are receiving an error code of E72 on your Frigidaire dryer. Without knowing the model number specifically I can tell you the general explanation for an E72 code is an outlet control thermistor short circuit. The recommended solution is to check the resistance of the outlet control thermistor, and check wiring for a short circuit across the thermistor connections. Resistance should be between 4.9K ohms and 6.2K ohms at room temperature (68-77F or 20-25C). You may possibly need to replace the outlet control thermistor and/or wiring and retest.
However, this is not a typical DIY project. I would recommend reaching out to an experienced appliance technician just to ensure no troubleshooting step has been missed. Parts are often costly and if the problem is precisely diagnosed, it can save you a lot of time and funds.
Best of luck,
Mar 28, 2014 | Frigidaire Clothes Dryer Thermostat...
E72
Hello Don, this is Z! Thank you for your post!
I see that your Frigidaire washer is displaying error E72. Have you recently moved your washer to a different location or have the hoses been removed? If so, please verify that the hoses are connected to the correct valve. Otherwise, I would suggest contacting a professional to accurately diagnose your washer since it may possibly be experiencing a communication problem with the control board of faulty valve(s). Hope this helps!
Mar 28, 2014 | Frigidaire Affinity ATF7000ES Front Load...
What dsoes E72 mean?
does it say in the owners manual because I see not 72 for an error code in the tech sheet
Zanussi ZWD 1270 no heat
E72 can also be caused by broken wiring to the NTC(Sensor). If the wiring is low voltage( very thin wires) then pull gently on the wires where they go into the NTC. If they break away there is the problem, you would need to replace the wiring harness for that NTC. Also, check the fan motor is running and the belt on the ventilator has nt stretched. If all is ok check the condenser is nt blocked with lint
Mar 11, 2014 | Zanussi ZWD1270 Front Load Washer / Dryer
Unlock network locked nokia e72
Hi, To which network has your Nokia E72 been locked to? You can unlock a network locked Nokia E72 safer and easier using unlock code. You can get the unlock code for a Nokia E72 from www.Unlock-Zone.Com at affordable cost with free unlocking instructions. Good luck mate.
Jan 08, 2013 | Nokia E72 Smartphone
Nokia e72 mobile display showing white
u should replace LCD of your e72
Jul 29, 2012 | Nokia E72 Smartphone
Frigidaire aeq7000eg0 motor doesn't run
Most of your fuses for a Frigidaire dryer are upper right hand side of the rear bulkhead. Here is a westinghouse dryer video I made In the video I look for failed components and show the various parts, explain their function, and location.
Frigidaire service manual
https://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes/dryer-will-not-work/how-do-i-get-inside-my-dryer/gas-dryer-quits-heating/more-gas-dryer-enlightenment/gallery-of-dryer-parts-locations-and-diagrams/frigidaire-gibson-kelvanator-dryer-101
Jul 23, 2012 | Frigidaire Dryers
How to get unloced nokia e72
You can get the UNLOCK CODE at here
Simpleunlocking.com
and get the Phone Unlocked from Network lock,You can follow the instructions below and unlock it step by step...
Nokia E72 Unlocking Instructions
Warning : Do not enter any wrong unlock codes on your Nokia E72 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia E72 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia E72 without any sim card.
2 - Don't bother as to what is displayed on your Nokia E72.
3 - Compose #pw+CODE+1#.
4 - The Nokia E72 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia E72 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia E72
Sep 14, 2011 | Nokia E72 Smartphone
Dryer working fine but no heat coming through, displaying e72 error code
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 13, 2011 | Zanussi ZWD1470W Front Load Washer / Dryer
Frigidaire Affinity AEQ6000WH Dryer Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
