Question about Plumbing
I HAVE A UP 15-42F CIRCULATOR PUMP CAP GOOD PUMP WILL RUN IF I PROD THE IMPELLER BARINGS SEEM GOOD RUNS SMOOTHLY AFTER PRODED TO START?
THROW THE PUMP AWAY IT PROBABLY HAS A BAD ARMATURE. NOT WORTH ASSEMBLING A TEAM OF EXPERTS TO POSSIBLY DIAGNOSE THE PROBLEM.
Posted on Jan 28, 2009
I just replaced thermostat good on anti freeze still running hot
Hows the water flow through the radiator? maybe there are some plugged tubes in it. The impellers on the water pump may have eroded down so the volume of water the pump circulates isn't enough. Look in the radiator with the cap off and the engine running. If bubbles are present one of the heads is warped allowing compression gases from a cylinder to enter the radiator.
May 09, 2014 | 2003 GMC Envoy
Kohler 5E, initially water pump impeller no good causing overheat and shut down of motor (overheat switch killed ignition), replaced raw water pump impeller, heat exchanger stays cool, exhaust manifold...
You did not say what fuel you running the motor on??? It sounds like it may be LPG or Propane.... is so then it seems as though you do not have enough surface for evaporation...
heatman101
Jun 13, 2011 | Kohler Electrical Supplies
Im not getting any heat? good thermostat,rad.cap
Does the temp gauge read normal. You might have to backflush the heater core.
Feb 14, 2011 | 2001 Chevrolet Silverado 1500
It seems like there is not enough pressure to activate the cleaners they barley move,i have watched it while it was open its trying to work
Welcome to FixYa.
Based on your description and provided the dishwasher is indeed filling with water but not circulating, It sounds like a busted wash impeller within the main motor/circulation pump.
First though, do you hear a quiet sound of a motor starting once the unit has completed filling with water ?
( it will be super quiet if the wash impeller is broke as I suspect it may be...almost like a fountain, since the Asko are very quiet under normal conditions. You will have to either get right down with your ear to the bottom or run it with the door open by activating the door switch with a screw-driver )
If so that is a tell tale of no wash action yet the motor runs, hence broken impeller. If you don't hear anything it may be a wire come off the main motor/circulation pump...but not likely.
This unfortunately is common with Asko dishwasher and it is a case of being a victim of their own design.
What happens typically is the ball-bearings from the upper rack holders fall out making their way into the sump, hence breaking the wash impeller from the motor.
Let me know what you find and I'll try and help you move forward from there.
Good luck,
Macmarkus :)
Aug 24, 2010 | Asko D1776 Built-in Dishwasher
1991 bmw 318is 4 door 16 valve motor, runs hot and radiator cold
you may have bad waterpump,the impeller on pump may be borken, just because it doesnt leak doesnt mean its good.also could have exhaust entering cooling system (bad headgasket) if pump is good have a block test done.
Sep 29, 2009 | BMW 318 Cars & Trucks
My new AO Smith 2HP pool pump won't pump water, just hums
I'm guessing that you replaced the motor that goes to the pump, not the pump itself. You know the motor works just fine. Is the motor rotating in the correct manner(clockwise or counterclockwise) in relation to the rotation of the pump? Have you checked the pump to see if the impeller is working/rotating? Is the motor hooked up to the pump correctly, so that the motor is turning the impeller? Are all connections to the pump tight, so there are no suction leaks? Have you primed the pump and purged it of any air locks?
Aug 11, 2009 | AO Smith 2 HP 115/230V 56C Replacement...
Engine coolant not circulating
no thermostat sound like you have a ubstruction somewhere make sure the oil is not milky if it is you need to replace you impellar seal behinde the blade make sure your radiator grates are clean with a preasure washer
Jun 22, 2009 | 2003 kawasaki KX 125
Our dishwasher is not running through all cylcles
Either:
1. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, you should see some water at least once, if not - check water valve, water level float and water pressure.
2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
Dec 02, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Overheatin cady 1999
hello jaanutno, did you check to make certain the thermostat is operating? there may also be a weep hole on the water pump and you will see or feel some moisture there, you can remove the thermostat and boil it on the stove to see if it works once it reaches temp if it doesnt open you need a thermostat if it does work put the thermostat housing back together without the thermostst and start the vehicle to see if it will circulate one more thing to check is that the rad cap is proper for the radiator (how many psi) hope this gets you on the road good luck
Nov 11, 2008 | 1999 Cadillac DeVille
Plumbing Logo
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
