I have a problem with my CDROM
My laptop is not playing CDS please how do i solve this problem
  • 124 Answers
Thanks for giving me the opportunity to help. On an XP computer, click on start, then control panel, then sounds. This should bring up the "mixer" panel. Make sure that none are muted. Unmute them and see if that helps. Since you didn't say what operating system you are using, I took a guess. If my advice helped, please rate the information I gave you. Thanks for using Fixya.com
Posted on Jan 27, 2009
  • Bernie Thames
    Bernie Thames Jan 30, 2009
    I was wondering if you still needed help? If you were able to use my suggestions to fix your problem, I'd appreciate a rating so my boss knows I'm doing right by my customers. Thanks!
My Lenovo g550 model slimtype dvd ads8a4s is playing CD's only not DVD's, it does not recognize them. What can I do?
Please double check your drive. GOTO My computer and there you will see disk partitions and optical drive type.. I mean your DVD drive does it says DVD or CDROM? Now if thats DVD then you need to check software you are using.. Its better if you can download VLC
Player thats the best software I have tried.. and no region issue.
Jan 09, 2015 | Lenovo Computers & Internet
My cd rom drive plays cds rips cds reads and does cd rom programs but will not let me burn cds any more..... i was able to burn cds just fine before???? please any help?
Have you tried reseating the CD rom;verify all the connectors are securely fastened. What type of Dell is this; a tower, desktop, or laptop? If you know how to open the case then proceed with reseating as follows:
First power down the system
After opening the case
locate the CDROM
If this is a new system it is probably connected using a SATA connector (black cable with a blue connector and power connector.)
At the back of the remove each connector then reconnect the cable
The SATA or Parrellel cable has a connector at both ends so trace the cable and re-seat the connector on the motherboard as well.
close the case
boot the system back up
test the cdrom
Aug 01, 2011 | Dell Computers & Internet
What CD roms are compatible with the thinkpad R30?
From the specs it says a DVD-ROM/CD-RW combination drive which means you should be able to play music, dadat and DVD's. You should be able to burn cds also.
If you cannot play these or burn, make sure the disk is not scratched. Try a couple of other disks to make sure the cdrom is working correctly.
Oct 03, 2009 | IBM ThinkPad R30 2656 Notebook
It's telling me I have no driver for the CD Rom
you need your sound and video codecs..
in writing cd's is your cdrom writable?
Sep 09, 2009 | Everex StepNote VA4103M Notebook
My cd drive will read cds but not dvds i try to istall somethig it wont work
Hi dkush29306,
while the other two posters have pointed out the obvious, that CDROM drives only read CDs, and that you need a DVD drive to read DVDs, i would like to add something to this.
I will asume you have a CDROM COMBO Drive, that *should* play CDRs and DVDs.
if you find it does spin CDs up and read them, but not DVDs then i might be able to offer some suggestions.
firstly, make sure there is no software conflicts (like two CD Writing softwares trying to use the CD Drive at the same time.. ). you shouldnt have to worry about drivers for the CDROM, as the default OS ones should suffice. but they may be corrupt. you could goto Device Manager if you are on Windows, and uninstall and reinstall the driver for the CDROM. it should find it automatically in the install wizard.
ok at this point i don't see how software could cause any other issue , so we should look at it being a hardware issue:
if you have the ability, try changing the IDE Ribbon Cable that connects the CDROM to the Motherboard. if that doesnt work, try changing which plug in the IDE cable the CDROM plugs into. these plugs usually have a blue plug at one end (motherboard end), and there is two plugs at the other end, or master and slave. keep the jumper pin on the CDROM set to Cable Select, so you dont need to change it to slave, when its plugged into the slave port, or master pin if set to the master port.
finally, if none of that helps (and it probably won't ) you might find that the actual fault is due to the laser in the CDROM not focusing tightly enough and therefore cannot read the data on a DVD ROM because of this. the only way to tell if this is ok or not, is to plug it into another computer and see if it can read DVDs.
you might just be better off spending 20-50$ and buying a new CDROM Combo drive from your local computer hardware store.
Jul 17, 2009 | Computers & Internet
My DVD/CDROM is acting funny. DVDs play fine, CDs don't play at all. if this problem is unfixable, where can I find a replacement part. eBay has yeilded no results. are there non-Gateway DVD/CDROM products...
1. Try to gently clean pickup lens with q tip and 70% or lower alcohol or vodka. Don't push down.
If didn't help:
2. Compressed air (gently) around pickup lens.
DON'T do a short bursts. Just press, hold and move around the lens.
Mar 18, 2009 | Gateway MX3410 Notebook
Boot application from cdrom?
Recovery cds work only on the laptop at its original state, meaning not yet formatted, because the recovery disk is linked to the system to restore minor errors on the OS... Those cds have become useless since "he formatted the notebook", inside is not already the original files... Buy a windows XP installer and install it bu yourself... it is very easy....
Good luck....
Feb 02, 2008 | HP Pavilion dv6000z Notebook
Reading Data CD's
Hmmm... were the cd's originally burned using that laptop? Or were they burned on a different pc?
It could be as simple as your cdrom doesnt like something about those cd's. Or it could be a flakey cdrom.
My suggestion, try reburning them to a different brand of disk using a different pc. Then see if your laptop will read them. If not, may need to replace the cdrom. Though it reads commercially manufactured cd's, if its flakey, it will have problems reading custom made cd's.
Other option, get a usb flash drive and copy those files from that cd, in a different pc, to the flash drive.
You don't need any special drivers or programs in order to copy mp3 files from a cd to your hard drive. Yet, you would need something in order to play them. Which media player does just fine.
Flakey cdrom or flakey cd's... hope this helps.
Oct 29, 2007 | Dell Latitude D600 Notebook
CDROM drive does not read some CDs
best and most affordable solution - replace the cdrom drive.
Sep 23, 2007 | Toshiba Satellite P15-S479 Notebook
System recovery cds
I think the peoblem is that you need to set the cdrom as first boot device, go into bios (F2 or Del on boot up) and enter advanced cmos settings and you will find that the HDD (Hard disk) is set as first boot device, change this with up/down keys or + - keys to cdrom as first boot device. save settings and exit for a restart with cd in drive.
Aug 29, 2007 | Toshiba Satellite 2415-S205 Notebook
Computers & Internet Logo
David Payne
David Payne
