Question about Reddy Heater-170,000 BTU Kerosene Deluxe
NO FUEL AT NOZZLE
MODEL R165DT-REDDY HEATER 165000 BTU-I HAVE PUMP PRESSURE-CLEAN FUEL FILTER AND NOZZLE IS CLEAR-SOME ONE HAS BEEN INSIDE THE UNIT BEFORE-DOES FUEL LINE GO NEXT TO BURNER HOUSING OR PUMP LINE-IT NOW HAS FUEL LINE NEXT TO BURNER HOUSING-I'M NOT GETTING FUEL AT NOZZLE-IGNITOR GLOWS-PUMP STARTS BUT NO FUEL-UNIT STOPS AFTER 5-6 SEC
  • go2guns64 Feb 21, 2009
    I have a reddy heater r55bt it starts and then quits after about 5 seconds using coleman lantern fuel. Any idea how to fix it? It worked great a year ago but was stored for 13 months.
FOUND THAT THE FUEL HOSE AND AIR PUMP HOSE HAD BEEN REVERSED AT THE NOZZLE-PUMP HOSE NEEDS TO BE CLOSEST TO THE BLOWER HOUSING-I USED A VAC GAUGE TO TEST THE FUEL LINE-WHILE THE AIR PUMP WAS RUNNING-NO VAC-REVERSED LINES AND STARTED UNIT-ADJUSTED AIR PRESSURE-ALL IS WELL
Posted on Jan 28, 2009
Reddy heater 40000 btu ker/forcedair plug it in it takes off for a little while then shutsoff
First thing is to download the service manual.
http://www.desaparts.com/service_manuals.html
You need to make sure the filters are clean and that you are getting the proper air pump pressure.
If the units starts up and runs good and slowly goes out it will normally be due to a lack of fuel getting to the nozzle. When there is not enough fuel being delivered to the nozzle from either a clogged fuel filter of dirty air pump output filter the unit will slowly shut down from lack of fuel.
If the unit shuts down while it is running properly and the nose come is orange then you probably have a problem with a photocell or the flame out control.
Thanks
M Cramer
www.allpartsinc.com
Jan 04, 2011 | Reddy Heater-70,000 BTU Kerosene w/T'stat
When unit fires i get a short burst of fuel then nothing
Clean, waterless fuel and correct air pump pressure are absolutely a requirement for a good running heater. Drain the tank, set the air pump pressure. Your problem could be more serious, such as losing air between the pump & nozzle, a worn nozzle, or a restricted fuel filter.
Nov 26, 2010 | Reddy R155D Utility Heater
I have a 55000btu heater when I first fire it up it burns red and really clean but after 5-8 minutes the red center turns dark and the smell get bad
This must be a kerosene heater? With a spark plug? If you will reply with the model number I can tell for sure.
I will list some of rhe causes for the problem you describe.
  1. a restricted or worn nozzle (Desa recommended annual replacement). Replace nozzle.
  2. a loss of air pressure. Air pressure from the air pump is directly related to fuel delivery. Check the pump pressure.
  3. pump pressure loss due to an air leak around the plastic cover, a crack in the cover, a crack in the air line.
  4. fuel delivery loss due to a restricted fuel filter or a cracked vacuum line.
  5. a crack in the nozzle adapter.
Click for some more troubleshooting tips
Use some soapy water for leak finding.
Nov 23, 2010 | Reddy Heater-30-55,000 BTU Variable
Reddy heater has spark but no fuel to ignite it?
the black hose that goes to the back hooks to a pump on back of motor take screws off back and filter clean when back together turn fan by hand and should hear a small vacum at back of motor , not pluged in clean nozzel
Apr 13, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
No fuel to my torpedo heater
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Apr 02, 2009 | Milwaukee Tool Master Heater 70,000 BTU...
70,000 BTU Ready Heater
If...the air pump pressure is right, the ignitor glows, the fuel is hitting the ignitor, then the unit will have combustion......unless.....
  1. there is an air leak on the pressure line
  2. there is a vacuum leak on the fuel line
  3. there is a leak at the nozzle adapter
  4. there is a restriction either in the nozzle or the fuel filter
  5. the nozzle is worn and is spraying fuel rather than fogging fuel
Feb 09, 2009 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Reddy Heater RM60 HSI Forced Air Heater: Pump Pressure Issue!!
ground wire on the circuit board needs to be checked and these units need to have a GOOD three wire cord with a proper grounded outlet
Jan 21, 2009 | Reddy Heater-30-55,000 BTU Variable
Not getting fuel
Check the pump pressure. If 0psi, the rotor (air pump) probably broken. If not set to factory specs.
If there is some pressure, then check for air leak between the pump & the nozzle or vac leak in the fuel line, or possibly a clogged fuel filter.
Jan 10, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy heater will not fire.
Your problem is most likely the lack of pressure from the air pump. Your pressure is extremely low. Pressure on a 100k heater should run 5psi. At 3psi there is not enough fuel and not enough air to atomize whats there. Bump the pressure up. If it won't come up, then you have an air leak. Test w/ soapy water. Keep your fingers clear of the fan!
Dec 04, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
238 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
