Question about Epson Stylus C88 InkJet Photo Printer
C88 stylus printer does not print
No red lights show on paper or ink, green lihjt shows printer on. When wanting to print, paper feeds through but no print on the paper. I tried cleaning the nozzles as shown in diections but to no avail. Is there a solution to this problem short of having to replace the printer?
  • 353 Answers
When did this failure to print occur? Was it sudden e.g. after changing cartridges, or did the print quality slowly deteriorate to nothing? Are you completely confident that you have good ink cartridges containing plenty of ink. What the Status Monitor is showing you in terms of the quantity of ink remaining may well be incorrect. If not sure, try a new set of cartridges, making sure you use the proper cartridge replacement procedure so that an ink charging cycle takes place. If ink starts to appear on the paper, do not carry out head cleaning cycles willy-nilly. Leave it for 24 hours to disperse air bubbles then do a couple of cleaning cycles. If it's still not perfect leave it for another 24 hours etc. Patience is required here.
If you have already done lots of head cleans with no result, and you're sure you have a good ink cartridge properly installed, then you can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head fully into its parking position so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean again. If still nothing, report back
If this information has been of use to you, please rate it
Posted on Feb 15, 2009
I am having trouble changing the cartridge on the printer. The
im so sorry for the inconvineince that your having on this printer but let me help you.
if :
Red paper.jpg paper and red inkout1.jpg ink light flash alternately and green power.jpg power light is off possible problem: Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. If the lights are still on, that means the printer is having a hardware issue if: Green power.jpg power light is off; red paper.jpg paper and inkout1.jpg ink lights flash (quickly) possible problem: The printer may have an internal error. Turn off the printer, wait a few seconds, and turn it on again. If the lights are still flashing , that means the printer is having a hardware issue
Feb 10, 2010 | Epson Stylus C88 InkJet Photo Printer
Epson C88 shows red alternately blinking lights
the problems are :-
  • cartridges are not recognised or installed
  • there is a paper jam.
Feb 05, 2010 | Epson Stylus C88 InkJet Photo Printer
Epson C88 will not print, is flashing both paper and ink lights
I think you need to reset the counter, you can either take it into a epson service centre & have them reset it, or download a programme online.
you just need to google it, just type in service reset C88 that should do the trick.
Nov 06, 2009 | Epson Stylus C88 InkJet Photo Printer
Epson Stylus C88 plus
Make sure that the head can move on the carriage bar as this indicates a head assembly lock or jam. Make sure all the paper paths are clear and there is no tiny piece of paper stuck. Power it back on. If this does not resolve then you will need a visit to the repair shop or buy a new printer which is probably cheaper!
Sep 11, 2009 | Epson Stylus C88 InkJet Photo Printer
Red light constantly on and not printing. changed
do you print CD or plain paper, red light is mean jamed paper or change cartridge. Open the top door >press drop ink symbol> look at printer head show on ink ink tray.
Aug 01, 2009 | Epson Stylus Photo R200 InkJet Printer
My ink is jammed fro epson stylus c88.
i would download the ssc and try reseting your printer
Mar 03, 2009 | Epson Stylus C88 InkJet Photo Printer
Epson Stylus C88 show an error
I have downloaded the SSC service from the site ie. http://inkjetprinterhelp.us/epsonSSC.html
and done the setting according to the said instruction. And it was cool simple.
Thanks for you help too.
Jan 31, 2009 | Epson Stylus C88 InkJet Photo Printer
Printer will not print
Which of the two red lights is on? If it's the red paper light, it simply thinks it's out of paper. Make sure your stack of paper is properly seated in the Automatic Sheet Feeder. If it is the red ink light, it means that during a print task (printing, head cleaning, ink charging), an empty cartridge was detected. Go through the cartridge replacement procedure as described in your User Manual. If you don't have one, see:
http://files.support.epson.com/htmldocs/sc88__/sc88__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
"Replacing an Ink Cartridge.
If this information doesn't answer your question, please post a new comment with more information on what you want.
If this information was a help, please rate it.
Jan 25, 2009 | Epson Stylus C88 InkJet Photo Printer
Nothing comes out when I print
Epson 777 will not print. No paper jam. Power light flashing; red error light on steady. Paper does not feed; if paper supply is placed deeper in feed, entire paper supply (about 12 sheets) feeds thru as one sheet normally would , without printing.
Feb 27, 2008 | Epson Stylus Color 777i InkJet Printer
Will it ever print again?!
mine did that. it was a full cartridge and it was still saying it was empty. tech support told me i had to reset the chip but mine was a refilled cartridge. then everything worked fine but i had the reseter
Feb 05, 2007 | Epson Stylus C88 InkJet Photo Printer
Epson Stylus C88 InkJet Photo Printer Logo
144 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
