Question about Cell Phones
Nexus drivespeach pro
Hi i have just got the hold of a nexus bluetooth hands free kit for the car and in having trouble pairing it to my phone i have no user guide could you help me please the phone is a sony erricson k800i
SOURCE: bluetooth headset hb600 does not pair up to k800i
My Motorola V557 will not connect to the Akoo HBH-602 the search returns no devices found. My Motorola 365 returns the same result. Please give me the steps to make these phones recognize the signal.
Posted on Oct 07, 2007
  • 111 Answers
SOURCE: nokia 6300 will not bluetooth my visorlite hands free kit
if your 6300 pairs fine with others and your visor does too maybe they just aren't compatible..
Posted on Jan 27, 2008
Rayborn
  • 92 Answers
SOURCE: Connection code for nokia CK-7W hands free car kit ..to my c902
here is the user manual for the CK-7W car kit
http://nds1.nokia.com/phones/files/guides/Nokia_CK-7W_UG_en.pdf
Cassay100 the code should be 0000
Posted on Jan 24, 2009
  • 740 Answers
SOURCE: nexxus bluetooth car kit
To pair you must first turn bluethooth feature ON on Sony phone. This usually has an indication on lcd display when it turned ON (it looks like a headphone sign) the you must turn visibility of your phone ON making it ready to be paired. Following instruction that came with bluetooth kit put bluetooth in pairing mode when its in paring mode led lights will rapidly fash. At this point you phone should pick up bluetooth if it doesn't then do a search for bluetooth devices with your phone and it will find the bluetooth (make sure its in pairing mode) It will display the bluetooth type and model number. It also may ask for security code if it does it 0000 set by default. Then pairing should be complete just save and you should be good to go. Good luck and thanks for using fix ya
Posted on Jan 28, 2009
SOURCE: Can't pair nexus text to speech with my I phone don't have instructions either can anyone help??
Press and hold the 'Call' button on the Nexxus handsfree for 5 seconds. It will then go into Pairing mode. Set your phone handset to search for Bluetooth devices.
Pass-code = 1234
Good luck.
Andrew
Posted on Jun 23, 2009
How do I pair my phone to my blue tooth
Connecting a Bluetooth headset or car kit You can listen to music over a Bluetooth stereo headset, or have hands-free conversations using a compatible Bluetooth headset or car kit. It's the same procedure to set up stereo audio and hands-free.
  • For you to listen to music with your headset or car kit, the headset or car kit must support the A2DP Bluetooth profile.
  • Before you connect your headset, you need to make it discoverable so your phone can find it. You can find out how to do this by referring to your headset manual.
  1. From the Home screen, press MENU, and then tap Settings > Wireless & networks.
  2. Tap Bluetooth settings.
  3. If the Bluetooth check box is not selected, select it to turn Bluetooth on.
  4. Make sure that the headset is discoverable.
  5. Tap Scan for devices. Your phone will start to scan for Bluetooth devices within range.
  6. When you see the name of your headset displayed in the Bluetooth devices section, tap the name. Your phone then automatically tries to pair with the headset.
  7. If automatic pairing fails, enter the passcode supplied with your headset.
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls.
Jun 21, 2011 | Jabra Bluetooth Headset with Adjustable...
Tip
Jabra Bluetooth Headset Pairing Instructions
<span><span>Connecting a Bluetooth headset or car kit</span> <span> You can listen to music over a Bluetooth stereo headset, or have hands-free conversations using a compatible Bluetooth headset or car kit. It's the same procedure to set up stereo audio and hands-free. <ul> <li>For you to listen to music with your headset or car kit, the headset or car kit must support the A2DP Bluetooth profile. </li> <li>Before you connect your headset, you need to make it discoverable so your phone can find it. You can find out how to do this by referring to your headset manual. </li></ul> <ol> <li> <span>From the Home screen, press <span>MENU</span>, and then tap <span><span>Settings</span> &gt; <span>Wireless & networks</span></span>. </span> </li> <li> <span>Tap <span>Bluetooth settings</span>. </span> </li> <li> <span>If the <span>Bluetooth</span> check box is not selected, select it to turn Bluetooth on. </span> </li> <li> <span>Make sure that the headset is discoverable. </span> </li> <li> <span>Tap <span>Scan for devices</span>. </span> Your phone will start to scan for Bluetooth devices within range. </li> <li> <span>When you see the name of your headset displayed in the <span>Bluetooth devices </span>section, tap the name. </span> Your phone then automatically tries to pair with the headset. </li> <li> <span>If automatic pairing fails, enter the passcode supplied with your headset. </span> </li></ol> The pairing and connection status is displayed below the hands-free headset or car kit name in the <span>Bluetooth devices</span> section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls. </span></span>
on May 23, 2011 | Cell Phones
I have a parrot CK v3.13 bluetooth car hands free system. Works fine with my Nokia. I have changed phones and now paired my iphone 4 with the parrot CK v3.13 successfully but do not have any volume...
Press and hold both the red and the rotary buttons for some 3 seconds, until the indicator light flashes alternately in red and green. It is in pairing mode now, thus visible for other devices, for the next 3 minutes. Then, make your phone's bluetooth application search for new devices. After a little while, your car kit should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '1234'. If the pairing process is successful, the car kit should sound a beep. By the way, if your car kit's user guide happens to be missing, feel free to download it from this location. You will find many details about settings for your car kit there.
Please, let me know if I can help you any further. Regards, Carlos
Nov 16, 2010 | Parrot MINIKIT Bluetooth Hands-Free Kit...
Hey will samsung hkt300 pair and work trouble free with iPhone 4. Chris
How do you pair a zte telstra mobile phone to a Samsung HKT300 handsfree car kit and what is the passcode,tried 0000 and 1234 and still can't connect.Will work with a Samsung Phone.
Oct 12, 2010 | Nokia Ck - 7w Bluetooth Wireless Hands -...
Hi i cant get it to flash so i can pair up.it just keeps beeping at me when i hold the button in on my ck-7w bluetooth car kit
you may need to find the main junction box and disconnect it for a few minutes to reset, they commonly lock up and need to be powered down, then hold down the nokia button for 10 seconds till you hear a bleep and it will allow new pairings, the passcode is 0000
Feb 11, 2010 | Nokia Ck - 7w Bluetooth Wireless Hands -...
I have ck-7w bluetooth hands free kit in my car been working fine till today now not working
the kits commonly lock up, you will need to remove power from the main junction box behind the dash, this will power down the kit and reset, then hold down the nokia button till it bleeps and try pairing your phone again.
Dan
Feb 03, 2010 | Nokia Ck - 7w Bluetooth Wireless Hands -...
Hi I cannot pair my new phone by bluetooth My new
try deleting some of the paried devices from the settings menu to make room for a new phone.
Dec 27, 2009 | Parrot 3200 Ls Color Handsfree Bluetooth...
Pass-code = 1234
Good luck.
Andrew
Apr 29, 2009 | Cell Phones
Nokia 6300 will not bluetooth my visorlite hands free kit
Hi
I had the same problem go to this web address you will find a manual for a similar model.
http://www.mobilefun.co.uk/graphics/misc/btvisorl.pdf
Just hold down the green dial button on the speaker open the speaker slide to power on the unit hold the green phone button down for two to three seconds the light will flash from blue/red continuosly and then pair it from your phones bluetooth menu.
The 6300 is def compatable with the visor lite 1.60 My firmware on the phone is 7.21.
Regards
Steven
Jan 24, 2008 | Nokia 6300 Cellular Phone
Cell Phones Logo
156 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
