Question about Broan-NuTone Kitchen Ranges
Broan bp 100 range hood fan replacement
BP100
SOURCE: Broan Allure II
my range hood lights would only work on highest setting. nothing on low or medium setting. fan working fine. I tripped the breaker off then on again at the electrical panel and behold, everything works perfectly fine now. don't know why it worked but it did!
Posted on Dec 02, 2007
  • 171 Answers
SOURCE: WS3 Broan Allure Range Hood Premier 36 inch
Hi shealy,
I'm Harvey the Master Plumber.
Your problem is: This hood worked fine until a light bulb blew out. Put in a new light bulb, but the lights will not turn off. Is the light switch bad or is there a problem with the control panel? The fan still works fine but the lights will not turn off or adjust dim or bright.
You're on the right track. The light control switch needs replacing. You might try utilizing the Repair Directory to find a repairman. If you have the tools and ability just remember to turn off the electric first.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 13, 2008
SOURCE: 42" Allure II Broan Range Hood I put a new bulb to replace
hey guys
These are halogen bulbs, so you must be very careful not to touch them with your bare hands. Use a paper towel, or even better latex gloves. The smallest bit of oil from your skin/ hands will cause the bulb to blow as soon as they get warm
Posted on Nov 25, 2009
SOURCE: Broan Allure QS3 push button switches for lights not working
you need a new set of controls,
Posted on Feb 24, 2010
SOURCE: Broan Allure QS2 Range Hood
Had same problem & fuse fixed it.
Before buying a new control board (approx $160), check the 3 amp fuse located on the inside of the vent on the control board. You have to take the light/bottom housing & black plastic air chute off to see control board/fuse.
Posted on Mar 11, 2010
Brian range hood model CJD130SS fan light on display flashes with fan off or on.
I believe that's the "change or clean filter" indication. Clean the aluminum filters in the dishwasher, replace the charcoal filters if non-ducted, press the fan light over 3 seconds and it should reset.
Sep 02, 2013 | Broan-NuTone Broan Elite E661...
Broan Allure range hood fan will not turn off, no matter which button is pushed.
The fan switch contacts are probably welded together or the actuator mechanism is broken. Your best bet is to replace the fan switch, probably with a similar type having a higher current rating so the new one won't also be susceptible to contact welding. If you have an industrial electrical supply dealer or electronic surplus parts store in your area, those would be good places to look for a replacement.
May 19, 2011 | Broan-NuTone Allure III QS330SS Kitchen...
Lights on hood fan will not shut off.
It sounds like your switch is getting stuck internally. It most likely needs to be replaced.
Here is a break down of your unit. http://parts.broan-nutone.com/broan/Shop?DSP=30200&PCR=1:1000&IID=QS330AA&imagesequence=
Also, you can order parts directly from Broan, here. http://parts.broan-nutone.com/broan/Shop?actn=quicksearch&searchtype=all&indextype=7&keyword=QS330AA
Hope this helps you somewhat, please post back if you need more help.
Mar 07, 2011 | Broan-NuTone Allure III QS330SS Kitchen...
Fan turns on and off since turning hood light on a few days ago
If it is a Broan, there is a delay button that was also depressed. It will turn the fans off after a few minutes. If not, then you're shorted out either in the control panel or the wiring in the range hood.
Sep 23, 2009 | Broan-NuTone Allure II QS230SS Kitchen...
Broan range vent fan not working; motor humming but will not turn, light works fine, not the fuse.
The motors will go bad from time to time. I would check Broan's web site
www.broan.com
or fill out this form
http://www.centralvacuumstores.com/fan_help.php
Sep 12, 2009 | Broan-NuTone Broan Range Hood Accessory
Need replacement part for Bravetti food processor
I have a Bravetti Platinum Pro model # BP100 and I need a new bowl and lid. I hope you can help
Apr 29, 2008 | Bravetti Quad Blade Food Processor
Broan allure II range hood
Did you ever find out what blew the fuse originally? Do the lights have a dimmer feature on them? If so, the reostsat may be bad, or the switch that controls the light intensity, 1,2,3. ect. Something caused the fuse to blow, maybe a wire on the bulb or switch somewhere.
Dec 20, 2007 | Broan-NuTone Broan Range Hood Accessory
Kitchen Ranges Logo
104 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
