Question about Reddy Heater-170,000 BTU Kerosene Deluxe
Fuel mixture problem
Have a 200,000 btu ready heater that has the air mixture adjustments out of wack. I have no owners manual with it and need to know the initial and final adjustments.
  • Anonymous Feb 04, 2009
    Strong kero smell. How can mix be adjusted.
  • pcdoc63 May 11, 2010
    A make and model would be helpful!
  • 92 Answers
You need about 6psi. I believe it is originally set at 7psi.
Posted on Jan 28, 2009
100,000 btu reddy heater runs but smokes alot and you can smell raw fuel what's wrong
It sounds like the fuel is contaminated,if it is not k 1 kerosene ,or grade A diesel fuel,this could be the problem,clean the tank,and start with a k 1 kerosene,and see if it clears up,then go back to the grade A diesel fuel,if this does not work,replace the filter in the tank,and check the intake air filter,make sure it is not cloded up,or behind the filter,last thing ,only after checking and doing all of this,the pump pressure may need adjusting,but do not try this with out a pressure gauge,and a manual .You can break the pump easy.I have a manual for the ready heater,just let me no if you need it,please rate,thank yopu,> roniecon@gmail.com
Jan 05, 2011 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
Kerosene torpedo heater starts and runs well but ONLY with the cover off. What the...?
You have a problem with the fuel pump air mixture. I have a tip at this address http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters which explains how to solve your problem in detail and where to get the parts and gauges you will need. Let me know if you need more help.
hardrocko
Thanks for using FixYa
Feb 27, 2010 | Desa International Reddy Heater R200BT...
Nose not getting red just a little
You need to adjust air/fuel mixture. At the back of the heater there is a plastic slotted set screw. That is the air mixture adjustment screw. Turn it in clockwise a 1/4 turn at a time until the nose cone gets to be about 90% reddish orange. The heater should also burn cleaner. Hope this helps.
Jan 11, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
Got a 200,000 BTU that won't light. Replaced the rocker switch and igniter. Igniter glows and I can see the fuel going past the igniter, but it won't fire up.
You must start troubleshooting by setting the air pump pressure. Low pump pressure or air leak can cause the problem that you are experiencing. If you check the pressure and it's up to specs, then the nozzle may need replacing.
Troubleshooting tips for ignitor type heaters
http://www.reddyparts.com/HSI_tips.htm
Nov 05, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Ready Heater 200 BTU Kerosene
Try a part from a similar heater like Mr. Heater Most of the parts are identical they just mount a little different, put the new part on your old mount. Had a similar problem with my dyna glo and with a little rigging it works like new.
Jan 22, 2009 | Desa International Reddy Heater R200BT...
Reddy r200b keroseen heater will not ignite
CAD flame sensor is bad, also check your air inlet line for the fuel mix, could be cracked.
Jan 20, 2009 | Desa International Reddy Heater R200BT...
Ready heater jet setting
Remove plug on left and install low pressure air gauge. Adjust right screw to 3.4 psi on the gauge. See web site www.Desatech.com Manuals with parts breakdown are available on line.
Apr 04, 2008 | Reddy Heater-30-55,000 BTU Variable
Air fuel mixture screw adjustment, forced air kerosene heater
Most ready heaters have a fuel pressure setting on the back of the heater near the fan. There should be two small plastic covers, looking directly at the back, the one on the left can be removed and a pressure gauge installed. The one on the right is slotted for adjustment of pressure. I think the correct pressure for that model is 3.0 lbs.
Jan 06, 2008 | Reddy Heater-30,000 BTU Propane Forced-Air...
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
101 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
