Question about Electronics - Others
No audio from my PS3 through the Onkyo 5100 7.1
Thanks for your reply
Maybe I have my digital optical hooked up wrong. right now I have this:
PS3 Playstation: HDMI cable to Onkyo IN1
PS3 Playstation: Digital Optical cable to Onkyo Assignable VCR/DVR 1
Any suggestions?
Mike
    Scholar:
  • 67 Answers
Have you assigned the audio to the optical cable? I am doing the same thing with awesome results. Simply go into your PS3 main menu under System Settings. You can then go to either audio or video options. I prefer to go the Video Options route, since it will ask if you would like to change the audio as well. In Video Options it should state something about the Video Output and to the right of that you will see you current resolution settings. Select this and set your resolution options. It will then ask you if you would like to assign audio options, and you will need to choose yes. In here it will let you assign what port the audio should be assingned to. Choose the Optical Out option and then click enter. From there you should hear the sound through your Onkyo.
Posted on Jan 29, 2009
Ps3 doesnt give out a surround sound output
Hi
In this configration you will not get surround sound. Because tv is not able to reproduse the surround sound through its out put from the HDMI input. You have to connect the HDMI of PS3 to the Onkyo receiver and the HDMI Monitor Out of the Onkyo to the TV. This can only done if the Onkyo AVR Have HDMI IN/OUT option.
If not the connect the Optical out of PS3 to any one of the optical input of the Onkyo receiver.
After that you have to goto the setup Menu the Onkyo and assing the optical input in wich you have conncted the PS3.
Aslo the following setting in PS3
Menu>>> Settings >>> Sound Settings >>> Audio Output Settings >>> Select the connector..= DIGITAL OUTPUT (OPTICAL)
Ajin
May 21, 2012 | Sony BRAVIA KDL-32S2010 32 in. LCD...
Hi i can't get any sound thru my speakers. I have hdmi from ps3 to tv optical from ps3 to receiver. i have tried dvd video 1 video 2 what setting am i missing? thanks
first: make sure you have the audio output setting on the ps3 set to digital optical output
second: make sure you select whatever the optical input is assigned as, probably dvd. i think there is a button on the front of the receiver that says digital input, make sure you hit that. A little light on the front screen of the receiver will say digital.
May 09, 2010 | Onkyo TX-SR503 Receiver
Separate video and sound on hdmi
yes it would be possible to separate audio and video from your PS3. You would need to go to the PS3 setting for audio and choose Optical instead of HDMI. You would need to connect and Optical cable from the PS3 to the receiver. Then on the receiver you would need to set the digital inut for your source(PS3) to optical.
Mar 10, 2009 | Onkyo TX-SR804 7.1 Channels Receiver
if you are using an HDMI cable dont expect sound to come out (even thought HDMI carries both audio and video) the onkyo HT-s5100's Receiver is the HT-r560. the 500 models of the onkyo receiver does not allow HDMI to carry both audio and video. it only allows the video signal to pass to the receiver.
if youre using optical for audio w/c is what you need then these are the steps you need to follow.
*first make sure that the optical connections are ok at the back of the receiver.
*make sure that your DIGITAL INPUT is set to either OPT1 or OPT2 whichever optical input you used to connect the optical cable.
*then go to your PS# settings : go to sound settings / audio moutput settings/ select digital out (optical).
then enjoy.....ü
Jan 27, 2009 | Onkyo HT-S5100 Theater System
No surround sound from my PS3 through the Onkyo 5100. Video OK
Unfortunately only the higher end Onkyo Reciever pass audio over HDMI for sound. 605,705,805,905 exc. Your reciever will carry Video over HDMI but you will need a digital optical cable for sound.
thanks.
Jan 24, 2009 | Onkyo Audio Players & Recorders
No sound with ps3, connected to a 7.1 av receiver & projection tv
Hi...the HT-R800 Home Theater system has the HT-R550 receiver which could only carry Video via HDMI. you would need to connect a separate audio cale(Optical Audio Cable) to be able to get audio out of the PS3 to the receiver. Once you have hooked up an Optical Audio Cable you would need to go in the PS3 setup and putin Bitstream and Optical in the Audio Setup menu.
Jan 10, 2009 | Onkyo HT-SR800 System
Digital Audio Input
On many ht receivers you must enter setup mode and tell it which digital input you are using for each digital source. i.e. you can choose optical for the DVD input and coaxial for CD, and vice versa.
Good Luck,
BB
Jan 06, 2009 | Onkyo TX-DS656 Receiver
I hooked up a fiber optic cable directly from a samsung hdtv to my onkyo surround sound system. Sound, however, does not come out of the speakers. Also, I am running cable directly to the tv from the wall...
Make sure that the place it is plugged into the TV is an output and not an input for the fiber optic cable, and the place it is plugged into the Onkyo is an input and an output for the fiber optic cable. This can be connected backwards very easy. Then you want to make sure that the Onkyo is properly set on the right function to listen to the TV. Check your owners manual on how to set up the optical input and have it assigned to the function you are trying to use. Sometimes these type of receivers have an input mode button that you can set to "optical" or "analog" or "digital" or "auto". Try changing those settings after you make sure the TV optical is an "OUTPUT" and the optical on the Onkyo is a "INPUT".
After you have these thing set right you should be able to listen to it like this.
I hope this helps, if you need more help just reply back on this post, but please give more detail about the connectors and on the TV and the Onkyo, and about the digital input settings on the Onkyo. It would also help to know the model numbers of both the TV and the receiver. There is no way to check out what each of your devices are capable of doing without knowing the model numbers to look up the specs.
Thanks,
Dave
Sep 07, 2008 | Onkyo Audio Players & Recorders
Optical output, no sound!
Have you selected Optical output from the audio setup screen of the TV? That needs to be selected to transfer TV audio to the optical out of the TV.
Jul 28, 2017 | Sony KDS-60A2000 60" HDTV
Hooking up a sony playstation 3 with digital optical cable
Here's one solution, if you have an audio output from your tv, you can go from the audio output on your tv to the audio input on your receiver that way anything that is playing on your tv for example, playstation 3, dvd player etc. Anything playing on your tv will have audio on your onkyo home theater system. The other thing I would try if you want to hook ps3 directly to receiver is go to your connection settings on your ps3 menu and change your connection method to digital optical cable.
Dec 27, 2007 | Onkyo HT-S790S System
Electronics - Others Logo
114 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
