Question about Performance Teknique ICBM-9778
POWER HARNESS STEREO POWER HARNESS
IBR-WHCR2 wire harness extra yellow wire
The wire to which you refer applies power to the radio with the ignition switch in the ACC position and also maintains power flow to the memory when the radio is off. The proper connection should be apparaent from the installation instructions that came with your Metra adapter.
Dec 21, 2013 | Metra Car Stereo Wire Harness IBR WHCR2
1998 sunfire installed stereo and now dash lights and tail lights blowing fuse
Get a wiring harness connector for your 1998 GM car - THEN carefully follow each wire color on the harness. Do NOT connect anything to the GM orange wire except "Memory". Do NOT connect anthing to the harness for "Lights" or "Dash" or "DIM" - you will blow fuses. Only connect the Power, the memory and the speakers - period. Then you'll be safe.
Jan 12, 2012 | 1998 Pontiac Sunfire
Aftermarket stereo wiring harness does not fit oem connectors. ordered stereo and harness together fom online car stereo.com. calledout a metra #70-1761. plugs will not fit either male plug. factory plugs...
Theres a standard amongst most stereos, so if these colors apply, then you will be right,
Red is Ignition power
orange is direct power
Black is earth
blue is for phone
White is for electric arial
then there will be four coloured wires with matching color trace wires, these are the speaker wires.
Hope this gets you going, good luck.
Jan 01, 2010 | 1995 Toyota Avalon
Not enough power to stereo
have you checked all your connections and is your power wire big enough to transfer that amount of power
Aug 11, 2009 | JC Whitney - Amplifier Installation Kit...
Stereo turns off when headlights turned on
Sounds like you have the ground for the radio hooked up to the illumination ground wire. Check for orange or orange/black wire coming from the radio harness. Did you buy the harness for the car as well? If so then just match all the colors of wires from the car harness and the radio harness. By car harness I mean the harness that plugs into the harness that the original factory radio plugged in to.
Thanks
Mar 29, 2009 | Car Audio & Video
2003 silverado z71
You could get a stereo installation kit for your year, make & model, that comes with a pigtail plug that would plug right into the existing harness plug and prevent you from having to hack up your original wiring harness.
If not....
Car Radio memory Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Good luck
Aduz
Mar 21, 2009 | Alpine iDA-X200 Car CD/ MP3 Player
New Car Radio, New Harness but no power, Nissan P/U '95
here is the factory harness wires and what they do, recheck thayt it all matches up.
1995 Nissan Pickup Truck Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Blue
Car Radio Ground Wire: Gray
Car Radio Illumination Wire: Red/Blue
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Black
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Violet
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Pink
Mar 10, 2009 | 1995 Nissan Pickup
97 dakota installed radio harness have power no sound
If you still haven't fixed this, look at your wiring harness. The blue wire that comes off your factory harness is the external amp in the Infinity stereo. I found this out when I hooked my Pioneer head unit up. Coming off the aftermarket stereo should be a blue wire that says remote. Hook those up and you should be good to go.
Jan 18, 2009 | 1997 Dodge Dakota
Color code for 01 acura integra factory stereo wiring harness
Battery BLUE/WHITE (+) RADIO HARNESS
Accesory YELLOW/RED (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination RED/BLACK (+) RADIO HARNESS
Power Antenna YELLOW/WHITE (+) RADIO HARNESS
LF Speaker (+) BLUE/GREEN
LF Speaker (-) GRAY/BLACK
RF Speaker (+) RED/GREEN
RF Speaker (-) BROWN/BLACK
LR Speaker (+) BLUE/YELLOW
LR Speaker (-) GRAY/WHITE
RR Speaker (+) RED/YELLOW
RR Speaker (-) BROWN/WHITE
Steering Cntrls NO
Speed Cntrl NO
Radio Security YES
Dec 28, 2008 | Pie Hon03 F/Mm Car Stereo Wiring Harness...
Performance Teknique ICBM-9778 Logo
46 people viewed this question
Top Performance Teknique Car Audio & Video Experts
George Nalley
Level 1 Expert
Joe Alexander
Joe Alexander
woodzowl307
Are you a Performance Teknique Car Audio and Video Expert? Answer questions, earn points and help others
