Question about Wolff Sunvision Pro 24S Tanning Bed
I have an ESB avalon 24 tanning bed that only displays flashing 13 on screen, it will not turn on
The bed turned on one time, but since then the bulbs will not turn on and the screen only shows a flashing number 13. I don't have a users manual so I am not sure what the problem is or what I should check. HELP!
1987 sca 24 series 1tanning bed manual
I have 1987 SCA-24 series 1 wolffsystems tanning bed how do I change the bulbs or where can I get owners manuel?
May 29, 2014 | Wolff Sunquest Pro 24RS 220 Volts
Tanning bed
Check the bulb you adjusted, you probably got it in wrong, and shorted stuff out. Reset the bulb, and replace the fuses. At least you had fuses.
Nov 30, 2013 | Remington S 1007 Tourmaline Straightener...
How to remove and install ballast in sunquest 24 taining bed
I have a question for someone who knows about a Sunquest 24 r tanning bed? Involving bottom bulbs not lighting at all?
Feb 02, 2013 | Wolff Sunquest Pro 24RS 220 Volts
Need a manual for esb 16 tanning bed free
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
This is for car and truck problems related to factory installed systems not add on aftermarket systems.
This post can't be removed or moved, please re-post the question in the correct product category. Thanks
Oct 11, 2012 | Cars & Trucks
2003 SUNQUEST PRO 24RS MANUAL TANNING BED
I Have a m2 24rs8 tanning bed. I loved it . I have moved it was in storage for 2 1/2 years. Moved to a new house. I hooked my bed up. the only thing it does kinda turn the fan on. what have I done wrong....It is on a 20amp bracker. Wire is 12 2 with ground. HELP PLEASE
Aug 25, 2012 | Wolff Sunquest Pro 24RS 220 Volts
My ESB tanning bed lights won't come on when turning on bed
my tanning bed comes on but wont light up
Jul 24, 2012 | Cars & Trucks
I have a ESB HOME TANNING bed when turning it on the timer works but lights won't come on. Have tried everything to find a fuse but can't find it. Is their a fuse, if so where's it located
INCORRECT PRODUCT CATEGORY
I'm sorry but I believe you have this posted in the wrong product category? Please re-post the question in the proper category if this is the case, otherwise you have my apologies. This is the car and truck problem category
Jul 20, 2012 | Cars & Trucks
I have a E.S.B. home tanning bed turnecbit on timer works but lights won't come on? Any suggestions PLEASE!
Which timer do you have?
Many timers are not rated for sunlight bulbs, either because the bulbs draw too much amperage, or the timer is not made for that type bulb.
Look at rating plate on timer, and look up the product manual for more clarification.
Copy following links to help identify timer and download manual and possibly select timer rated for the amperage, and/or possible exposure to heat.
For example appliance timer, or above ground portable pool pump timer with GFCI might be best choice.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#appliance
http://waterheatertimer.org/Woods-timers-and-manuals.html
http://waterheatertimer.org/How-to-set-timers.html
Jul 18, 2012 | Hardware & Accessories
Wolff Sunvision Pro 24S Tanning Bed Logo
43 people viewed this question
Top Wolff Health & Beauty Experts
ka4iup
ka4iup
Andrew Taylor
Andrew Taylor
Are you a Wolff Health and Beauty Expert? Answer questions, earn points and help others
