Question about Acer Aspire 7720 Notebook
Cpu overheats hello there, I have an acer 7720 laptop CPU Intel core 2 duo T7300 @ 2.00 GHz Intel 965GM chipset BIOS version v1.07 the machine was bought in april 2008 as new. Problem(s): the cpu overheats and system shuts down. cpu overheats using simple applications, no hard gaming, no video editing etc... the fan is working, i can hear it. I installed cpu temp monitoring softwares to check the temp. cpu temp is constantly around 50-55 Celsius right after system boots not running any applications. (the software i use is hardware monitor and everest) Second problem: I tried to double-check the cpu temp in bios, but in my version of bios there is no any section like "advanced" "pc health" "power" "hardware monitor" anything like that to check cpu temp. Only I can see are "information" "main" "security" "boot" "exit" My bios setup utility is InsydeH20. I checked every section in bios but found nothing. Could bios flash/upgrade solve this problem? Do I need to upgrade my bios at all? (i have never checked/altered bios before.) the latest version is 1.45 mine is 1.07 So the main problem is still the overheating cpu. Ventillation slots are not blocked. Fan is working. What is the optimal working temp of this cpu, anyway? i tried to remove the back panel of the laptop but it seemed quite difficult to do so I gave it up. i wanted to undust the fan and check that the heatsink sat properly. I would be really appreciated for any suggestion. thanks pete
  • LouisL1 Feb 24, 2009
    My Acer Aspire 7720-6681 is overheating and shutting off. With very low CPU load I normally see a temperature of 45°C. Occasionally, with little to no CPU load the temperature races to 65°C. The system shuts off when the temperature reaches about 70°C. However, I can sustain the system at 50% CPU load for 8 hours with no problems.
    Any ideas?
  • justaddice Mar 09, 2009
    I'm also having the same problem (I know this doesn't help!), but I have experience with opening the back panel. It takes quite a lot of force (to the point where you think you might almost break it!); from the grove work your way counter-clockwise, try to leaver it open slowly with something as you go. I opened mine, but couldn't really get to the cpu (as ClickRight said) and there wasn't much dust to get rid of. My laptop has started to have this problem after about 1 year of operation and heavy travelling (to and from China, India, etc!). Other than the overheating problem, its fine!I'd suggest you upgrade the BIOS also.. I had 1.07 and upgraded to 1.45 (It was very easy!), no it seems to handle the fan differently (I guess in a better way); although still didn't stop the overheating (if its clogged, no amount of software upgrading will do!).
    Best of luck,
    Daniel
Guys i have two acer laptops and both of them do the same thing 1 is aspire 7720 and the other is a more of a normal laptop version the 7720 was refusing to run for more then 30minutes with windows 7 and xp so i put ubuntu linux on which isnt so bad but its not so leapard or windows 7 its a bit different i've got used to it but i'm just going to put them both on ebay and upgrade to a new 1 with 4gb of ram. your very right they overheat and become soooo hot it is quite dangerous actually but if its been over a year acer want to charge over £50 just to look at it, it's not, worth it, yes its nice but its too big and bulky, give your legs a break mines are starting to hurt the other laptop is slimmer and is a windows 7 dual boot with leapard it runs ok but the mouse thing, is beyond hopeless hope i've helped someone if you want to contact me im on alessia@live.co.uk xxx
Posted on Dec 21, 2010
I'm also having the same problem (I know this doesn't help!), but I have experience with opening the back panel. It takes quite a lot of force (to the point where you think you might almost break it!); from the grove work your way counter-clockwise, try to leaver it open slowly with something as you go. I opened mine, but couldn't really get to the cpu (as ClickRight said) and there wasn't much dust to get rid of. My laptop has started to have this problem after about 1 year of operation and heavy travelling (to and from China, India, etc!). Other than the overheating problem, its fine! I'd suggest you upgrade the BIOS also.. I had 1.07 and upgraded to 1.45, it seems to handle the fan differently; although still didn't stop the overheat (I guess if its clogged, no amount of software upgrading will do!)
Posted on Mar 09, 2009
  • 3 Answers
Hi Pete,
How high does the temperature go before the system shuts down? You can check this with Everest. 50-55 Celsius on startup is normal, but it should not exceed 90C at max load. I have had these Acers in for repair before and it's not uncommon for the heatsink to be heavily blocked. Unfortunately on these systems, that means disassembling the entire system, which unless you know what you're doing, I wouldn't suggest you attempt it by yourself. Brining it to a qualified technician should cost between $100 - $200 as it's quite a lobour intensive job.
Ben
Posted on Jan 27, 2009
    Brigadier General:
  • 5,158 Answers
The alternative but not the best solution is to buy one of those usb powered laptop chillers
Robert
  • 46 Answers
My best suggestion is to contact Acer immediatly for a warrenty replacement. This is dangerous to you life because overheating can cause an explosion if not handled properly. This should FixYa!
What is the fastest compatible CPU for upgrade Asus X50GL series laptop
changing chips most time requires a mother board up date to cater for the extra chip pins
best advice here is to take it to a computer repair shop and they will be able to tell you right off if what you want to do is possible with that board
point of interest here
chips are only as fast as the hard drive and rams will work
if your unit has a disc type hard drive consider upgrading that to a solid state hard drive which handles data much much faster than a disc type
just a bit of info when you are talking to the computer geek
Oct 05, 2016 | ASUS Computers & Internet
What to do next after upgrading CPU
Hey;
Start your computer and right after the hp logo, keep pressing the F8 button until you see a large list of options.
Select
"USE LAST GOOD KNOWN CONFIGURATION"
and press enter. Let windows load and it should work just fine.
Feb 03, 2014 | HP Compaq 6720s Notebook
I need to know how to turn up the speed on my laptop
Turn off SPEED STEP in the BIOS. The system automatically throttles the CPU to lower speeds until there is a demand for more power
May 15, 2010 | Intel Core 2 Duo T5500 / 1.66 GHz...
Processor
I told you my opinion, If I was in your shoes I won't upgrade the CPU.Professionals do not do works against Factory specifications, and I fixcomputers for living.
Acer says Pentium dual is not supported on Acer 4315, I can only tell you not to do such an upgrade.
Itwould be the same as if you ask me if you can mount a Jaguar engine ona Mini, yes, for sure there is the way to mount it, but the car won'twork as it is supposed to, and risk to blow at first corner.
If you really want to replace your CPU consider the following.
Acersays pentium 2 dual core is not supported on 4315, if you do ityourself you risk to damage the computer. Do not do the CPU upgrade ifthis is your only laptop, or if you care of this laptop, chance ofdamaging laptop are high. This kind of upgrades are done more as anexperiment.
I know Core 2 Duo T5300 1.73 Ghz had been installedsuccessfully on Aspire 4315, Acer says not to install any core duo, Iknow for sure Pentium duo T5200 1.6 Ghz works on Aspire 4315 with noneed for replacing cooling system.
Both chipset are difficult to find, best place to find them is Ebay.
Check this link for an extensive report on this matter:
check also: Is it worth upgrading the CPU on Acer Laptops?
Aug 10, 2008 | Acer Aspire 5100 Notebook
Difference b/w Core to duo and daul core
Core 2 Duo is a Brand name by intel to identify his class of Dual core CPU
a Dual core CPU is basically two CPU in one package, which dramatically improves performance over previous architectures.
Pentium Dual Core is another brand name by Intel to identify his new entry level CPU offer.Basically Pentium dual-core are similar to Core 2 Duos except they(pentiums) are slower and cheaper.
they both are dual core CPUs.
I would prefer a core 2 Duo having to choose a laptop because of better performance, but the prize is different for the two solutions.
Jun 28, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Re aspire 7104 being upgraded to duo core processor
No it cant be updated
Your acer aspire is based on the 910GML chipset
The Mobile Intel® 910GML Express chipset is optimized for the Intel® Celeron® M processor.
Here you can compare the 910gml chipset and 945 which is used by the core 2 duo.
http://compare.intel.com/pcc/showchart.aspx?mmID=22210,7419&familyID=7&culture=en-US
As you can see on the page there are key difrences between the chipsets other runs on ddr2, yours on ddr. the FSB support is 400 on yours and 533 / 667 on the 945.
also you can see the supported processor familys right there.
you can look for a
Intel® Celeron® M processor,
Intel® Celeron® M processor Ultra Low Voltage (ULV)
Upgrade cpu with maximum FSB of 400MHz
Apr 28, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Acer Aspire 7720 Notebook Logo
898 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
