Web easy pro 9 winsock error please reconnect and try again
Dns probe finished no internet
Issue is with your internet connection or network adapter. Suggest you follow the steps listed below to fix this BEST FIX DNS PROBE FINISHED NO INTERNET
Mar 11, 2014 | SVP NEW
Tip
Network sharing issue
In Multiwindow platform normal,sharing folder and printer is always big issue.
Error type:
ex:
\\server is not accessible. You might not have permission to use this network resource. Contact the administrator of this server to find out if you have access permissions. The network path was not found.
This method can be used for many network error
Solution:
1)Fixing the winsock and tcp/ip .
On the run command :
for winsock run:
netsh winsock reset
to reset tcp/ip run:
netsh int ip reset c:\resetlog.txt
or
run winsock fix from www.snapfiles.com/get/winsockxpfix.html
2) Enable NetBIOS over TCP/IP
open up Network Connections, under Control Panel.
Right click on your network adapter and click on Properties.
Click on Internet Protocol (TCP/IP), then click on Properties.
Click on Advanced, and click on the WINS tab.
Even if it is set to Default, set the radio button to Enable NetBIOS over TCP/IP.
Press OK on each screen until everything’s closed.
Go back to the client machine and try again.
You should be able to connect!
3)dnsflush
Open Network Connection
Check box File & Printer sharing > ok
Disabled NIC
Enabled it back
Open CMD > ipconfig /flushdns
ipconfig/registerdns
4) Make sure windows firewall and antivirus firewall turn off
on Apr 21, 2010 | Computers & Internet
Tip
WinXP Tips And Tricks, Winsock 2 repair
Repairing Damaged Winsock2
The symptoms when Winsock2 is damaged show when you try to release and renew the IP address using IPCONFIG...
And you get the following error message:
An error occurred while renewing interface internet': An operation was attempted on something that is not a socket.
Also Internet Explorer may give the following error message:
The page cannot be displayed Additionally, you may have no IP address or no Automatic Private IP Addressing (APIPA) address, and you may be receiving IP packets but not sending them.
There are two easy ways to determine if Winsock2 is damaged:
From the XP source files, go to the Support / Tools directory
Winsock Test Method 1
Run netdiag /test:winsock
The end should say Winsock test..... passed
Winsock Test Method 2
Run Msinfo32
Click on the + by Components
Click on the by Network
Click on Protocol
There should be 10 sections if the Winsock2 key is ok
MSAFD Tcpip [TCP/IP]
MSAFD Tcpip [UCP/IP]
RSVP UDP Service Provider
MSAFD NetBIOS [\Device\NetBT_Tcpip...
If the name are anything different from those in this list, then likely Winsock2 is corrupted and needs to be repaired.
If you have any 3rd party software installed, the name MSAFD may be changed.
There should be no fewer than 10 sections.
To repair Winsock2
Run Regedit
Delete the following two registry keys:
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Winsock
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Winsock2
Restart the computer
Go to Network Connections
Right Click and select properties
Click on the Install button
Select Protocol
Click on the Add button
Click on the Have Disk butoon
Browse to the \Windows\inf directory
Click on the Open button
Click on the OK butoon
Highlight Internet Protocol (TCP/IP)
Click on the OK button
Reboot
on Dec 27, 2009 | Computers & Internet
I'm getting an Error 106: (net::ERR_INTERNET_DISCONNECTED): The Internet connection has been lost message when I try to connect to the internet, I'm using another laptop to send this query, how can I Fix...
(Remember to Rate)
Sounds like a few things, but lets get most of the problems out of your way.
So you want to download a few programs as it sounds like a virus/malware/etc. As its affecting your browser Google Chrome (maybe its just that one or all the browsers on the one system). Youve verified that everything is working ok on another computer, which helps narrow this down to virus/malware. Either way, you want to run these 4 programs :
Emisoft Anti-malware Kaspersky Removal Tool Super anti-Spyware Spybot (Immunize) and scan.
right off the bat, please go to super anti-spyware and under tools you will see the option to repair or restore winsocks. This is usually the main cause why your error happens.
Winsock is short for Windows Sockets API. It describes a standard way for Windows programs to work with TCP/IP. You use WinSock or the more recent Winsock2 if you directly connect your Windows PC to the Internet. This feature is mis-used by a few hijackers to facilitate their own monitoring. Data packets outward bound from your computer to a legitimate destination on the web can be intercepted by a malware LSP and sent somewhere else, other than where you had intended it to go.
again, if that doesnt fix, run all the scanners (update them before running, run as admin). Reboot, repair winsock, use Marcos Valasco Registry Cleaner Freeware. And reboot, you should be mint.
Thank you
Rhos Barnes, MCSE, CCNA Squamish BC rhos_2k@yahoo.com
Feb 10, 2011 | Google Chrome
My IE 8 will not open any web sites
Is your Network Connections working properly?
If your networking adapters are functioning OK, try this,
Open IE
Tools tab > Internet Options > restore Adanced Settings and Reset Internet Explorer settings.
Restart IE.
Other options are:
1) Uninstall the Network adapter
Open Device Manager > Expand Network Adapter > Right Click on your internet network adapter and Uninstall
Reboot
If it doesn't work, try it again and then reinstall the driver. You may have to get the new driver from the device website.
2) Winsock and Tcp/Ip Fix
Start > Run > Type CMD > Type the following:
Reset TCP/IP stack to installation defaults,
type: netsh int ip reset reset.log and Press Enter
Reset WINSOCK entries to installation defaults,
type: netsh winsock reset catalog and Press Enter
3) Run sfc /scannow (This will restore your system files back to original state)
Insert your XP disc
sfc /scannow
Hope it helps.
Jul 15, 2010 | Microsoft Internet Explorer 8
OUTLOOK EXPRESSS OX8OOCO133
hi jang_my171, this is a winsock error, try to reset the winsock .
click start > run > type cmd then press OK
type netsh winsock reset on the black screen, then hit ENTER
then restart pc, and try to check Outlook express if you can receive.
Hope this help...
May 07, 2010 | Microsoft Windows XP Professional
There was a problem accessing your account. Please try again in a moment. Error #1
Force the Global DNS
start - run - cmd - netsh winsock reset
Apr 29, 2010 | Yahoo Mail
I can't use my wireless to my laptops
Try the Winsock XP Fix utility. This will reset your Windows winsock settings to defaults. Since the wireless is establishing a signal and other devices work, it has to be an error in one of the host layers.
Mar 19, 2010 | Acer Aspire One PC Notebook
Card only connects for a few seconds then disconnects
Start-> Run -> CMD [Enter]
ipconfig [enter]
list this information...
Try switching the key to WPA-PSK WPA2-PSK TKIP/AES which will allow for the usage of either types of encryption protocols, hence more chance for a successful connection. The repair feature in windows hardly ever works and all it does usually is:
ipconfig /release
ipconfig /renew
But if nothing else works you could try resetting winsock in a cmd prompt:
netsh winsock reset [enter] [restart]
Dec 04, 2008 | Computers & Internet
Region Error
please try if this helps:
1. Remove disc from tray.
2. Switch off player and unplug from mains.
3. Wait 30 seconds, then reconnect mains.
4. Turn on player with remote. Wait for player to finish loading and display 'no disc'.
5. Press enter on remote. (There will be no on-screen response.)
6. Press 8, 4, 2, 6, 9 on the remote. (There will be no on-screen response.)
7. Press enter on the remote. Player will automatically shut off.
8. Turn player on.
9. turn off.
10. Turn player off then on again.
11. Player is now region-free.
Nov 02, 2008 | Samsung HT-X250T Theater System
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
