Question about Fahrenheat Electric Convector Baseboard Heater, 240 Volt
Unit will not run
Unit has electric thru the reset switch to the temp. regulator block terminal but no farther Fahrenheat Model#NPH4AB
Problem solved by electrician
Posted on Jan 31, 2009
Installed new battery charging system not charging had problem before installing battery
I will have to guess which system you have without the make and model and engine . I will assume you have a electric clutch on the blade engage which tells me you have a high output charging system. This system would have a Regulator / Rectifier on it. Most times it is bolted to the flywheel shroud .
installed-new-battery-charging-system-p2i0p3ef132mr30dht4rndtd-4-0.jpg The two outside terminals will have a white wire on each of them from under the flywheel, this will be A/C current , the center wire will be red and it will be D/C current.To recap the A/C current from the altenator goes into the two outside terminals and inside the Regulator / Rectifire it is changed to D/C current and regulated to not be more then 13.8 up to 15 volts and goes to the battery .
You will need a volt meter to test this to find out if it is your charging system or if your tractor has a problem with a fuse or ignition switch. Wiggle the plug on the regulator down just enough to get your voltmeter on the terminals,Start engine run at full throttle, set meter on A/C 20 touch one wire to the engine block and the other to the outside terminals one at a time, should read + or - 18 volts,if you have this that will tell you your alternator is good, next change the meter to D/C 20 and one wire to engine block and other to center terminal on the regulator it should read 13.8 or a little higher and can come down as the battery charges. If you only see 12 volt or less there is no output from the regulator to charge the battery and the voltage you are seeing is the voltage in the battery.
Apr 17, 2016 | Garden
Heater won't relight after shutting down, but fan continues to run
Roger, you either have a gas supply issue or a voltage problem.
Since I don't know your aptitude and abilities pertaining to LP gas troubleshooting/testing procedures, I don't know how detailed you want to go...basically, make sure your propane tank isn't empty; or that the pressure regulator didn't freeze up. Make sure that it is rated and set for 28" of water column output.
Check to make sure all the wire connections are secure to the flame control terminal block and to each of the hi-limit switches.
Isolate & perform continuity checks to each electrical component, including the gas valve.
You'll need a manometer to test and set the gas input & output water column levels.
When the unit is running,, what color is the flame?
Is there a roaring sound?
Is the flame small and weak?
Dec 25, 2013 | Mr. Heater MH170FAVT Open Flame Gas...
Don't know how to switch from 4-prong to 3-prong power supply
Your new 3 prong power cord needs to be wired up just like the 4 prong you just dont have the seperate ground . in the use of a three wire cord ground runs thru neutral .Hook black to black on the terminal block on unit. hook red to red on the other side of block and white to white or green in the middle reinstall the cover ....Plug in and your ready to dry
Aug 14, 2010 | LG DLE2532W Electric Dryer
I have a fahrenheat wall mounted heater, 120 v model,(can't find a model number on the unit) with a dial temp control. No matter which number setting it is on, the unit cycles off after about 50 seconds....
UNIT SOUNDS LIKE ITS SHUTTING DOWN ON A LIMIT SWITCH IN HEATER. THEY LOOK LIKE ROUND BUTTONS OF DIFFERENT SIZES. THE HAVE 2 WIRES GOING TO THEM AND THEY ARE A NORMALLY CLOSED. THERE IS A FAN DISK NORMALLY OPEN TO UNTILL IT GETS HOT AND CLOSES TO TURN ON FAN.  IF THE FAN SWITCH TAKES TO LONG TO CLOSE THEN LIMIT OPENS TO PROTECT FROM OVER-HEATING
Apr 23, 2010 | Fahrenheat (FFH1614) Wall Mounted Panel...
Fahrenheat fuh 54 b does not run long enough to get garage warm
have you checked what the operating amps are vs. the amps provided by the outlet. Sounds like you are trying to pull to much load and the machine probably has a saftey to where it shuts down bofore it buns itself up. Hope this helps. You have to be real careful about overloading circuts.
Dec 19, 2008 | Fahrenheat Ceiling-Mount Industrial Heater...
Add line thermostat to fahrenheat space heater
Just disconnect the other thermostat. You can leave it there just disconnet the wires
Nov 30, 2008 | Marley Electric Hydronic Baseboard Heater,...
Fahrenheat wall unit
your on-off switch is faulty - need to replace it.
Dec 07, 2007 | Fahrenheat ECP1524 Wall Mounted Panel...
Fahrenheat 4000 watt wall mounted heater shuts off and needs reset
the reset is probably an inline circuit breaker. if you can get hold of am amprobe clamp around ammeter, check the current when the unit is running at full power. the reading you get check against the current rating of the inline breaker. your fan motor bearings may be dry increasing the current draw of the unit and tripping the breaker. try oiling the fan bearings with a light oil NOT WD-40.
Dec 06, 2007 | Fahrenheat (FFH1614) Wall Mounted Panel...
Fahrenheat Electric Convector Baseboard Heater, 240 Volt Logo
147 people viewed this question
Top Fahrenheat Heating & Cooling Experts
paulcarew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
