Question about Dell 1700n Laser Printer
Paper only half loads into machine then stops
There are no jammed sheets in the machine but it only feeds in about half way then stops - please help. Thanks
  • 1 more comment
  • canteralong Jan 27, 2009
    Wow that was quick - Many Thanks, will give it a go. Cheers
    It worked -10/10 -Thanks! Are they called paper feed rollers - i'll get some new ones?
  • Anonymous Feb 01, 2009
    I will try the cleaning with soapy solution.
  • 55 Answers
Hi it sounds to me you paper feed rollers are worn down, these are the rubber tire looking things that pick up the paper, you may have to have them replaced or you could clean them with warm soapy water.
Posted on Jan 27, 2009
Paper feeder stuck
If the paper feeder stuck, do the following:
  1. Gently pull any jammed paper out from the output tray or sheet feeder.
  2. If paper is stuck inside, open the printer cover and remove the jammed paper, including any torn pieces. Then close the printer cover.
  3. If paper remains near the sheet feeder, press the paper feed roller lever inside the paper feeder to release the jammed paper, then carefully pull it out.
  4. Load the paper correctly.
  5. Press the cp_button_14.gif stop button to resume printing.
  • If the printer continues to jam or misfeed paper, and you are certain that there are no foreign objects lodged down inside the paper feed area, your printer may require service. Please call Epson technical support for further assistance.
  • Jan 29, 2011 | Epson Office Equipment & Supplies
    I removed a jammed sheet of paper through the front opening, Had to pull real hard. Since then, when printing or copying, printer feeds up to 4 extra sheet with each printed page. I suspect some piece of...
    Please see this solution from Canon. It is recommended you check your manual for the proper procedure for clearing paper jams. Incorrectly removing jams could damage your printer. Trust the following helps resolve your current issue.
    If you do not have a manual it can be downloaded from here:
    http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx300#BrochuresAndManuals
    Issue: More than one sheet of paper feeds while printing
    Solution: Clean the paper feed rollers using the MX300 operator panel
    sikaku.gif Cleaning the Paper Feed Roller (Roller Cleaning) Clean the paper feed roller if paper is not fed properly. Cleaning the paper feed roller will wear the roller, so perform this only when necessary.
    1. Make sure that the machine is turned on, and then remove any paper from the Rear Tray.
    2. Clean the paper feed roller.
    (1) Press the Menu button repeatedly until MAINTENANCE appears.
    (2) Press the l_mark_s.jpg or r_mark_s.jpg button to select ROLLER CLEANING, then press the OK button.
    The paper feed roller will rotate as it is cleaned.
    3. Repeat step 2 twice.
    4. Open the Paper Output Tray.
    (1)Put your finger in the rounded indent beside the Paper Output Tray and open it gently.
    (2) Open up and set the Output Tray Extension completely by pressing down the hollow on its front side.
    5. Make sure that the paper feed roller stops rotating, then load three or more sheets of A4 or Letter-sized plain paper in portrait orientation in the Rear Tray.
    Set the Paper Thickness Lever to the left.
    6. Repeat step 2 three times.
    The paper cleans the paper feed roller as it feeds through the machine.
    If the problem is not resolved, wipe the paper feed roller (A) located on the right side inside the Rear Tray with a moistened cotton swab or the like. Rotate the roller (A) manually as you clean it. Do not touch the roller with your fingers; rotate it with the cotton swab.
    Dec 25, 2010 | Canon MX300 Office All-In-One Printer
    E2 error code on Xerox work centre xd series 120f copier
    e2 is a paper jam problem. check that the paper guides in the cassette are positioned aginst the paper properly. Also remove the toner and drum cartridge. Clean all rubber rollers that you can get to with a damp cloth ( water). You are especially trying to clean the upper and lower registration rollers that "pinch" the paper. I hope that this helps.
    Nov 05, 2009 | Xerox Office Equipment & Supplies
    HP laserjet 4L paper jam after printing one page.
    You need the pick up rollers replaced. Call your service centre to replace pick rollers as these are feeding the pages crocked
    Aug 31, 2009 | HP LaserJet 4L Printer
    Sir, can anyone help me with my fax (canon fax l295)for a problem, it was always indicating that "load paper" even though i put paper on the tray once it was start feeding it makes an paper jam error and...
    You either have a paper path blockage or your feed rollers are worn. You'll need to take it apart to check though. Try removing paper, turning machine off and on and re-inserting paper. Remember to fan (separate) paper before loading, it could be static causing the sheets to stick together and jam in the machine.
    Jun 11, 2009 | Canon L295 Plain Paper Laser Fax
    Paper doesn't feed
    It could be a few things, but the times I've had similar problems it was either caused by the feed/gripper rollers in the paper trays being worn out, thus not feeding any paper or feeding half a sheet and then jamming.
    Or, it could be that the elevator in your paper tray isn't lifting, but if it's taking paper it's probably the rollers.
    Jan 12, 2009 | Canon Office Equipment & Supplies
    Paper Jam Error when there is none
    look in the rear of of the printer for an access door with a big knob to remove it.
    Jan 02, 2009 | HP OfficeJet 6210 All-In-One InkJet...
    Hp psc 1315 paper jam
    . Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
    2.
    Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
    3.
    Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
    4.
    Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
    5.
    Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
    6.
    Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
    7.
    Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
    Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
    Riso GR3770 Paper Jam, Check paper feed
    Sounds like you forgot to plug the High voltage transformer or a sensor back
    Dec 11, 2007 | Office Equipment & Supplies
    Paper jam light is on
    Hi! I have the same issue. The only solution I still use: select print from document with no paper in the hp's feeder. Let the printer go on "paper out" message, now put the paper into the feeder and press the print button on the printer. Success!
    Oct 05, 2007 | HP Photosmart 7450 InkJet Printer
    Dell 1700n Laser Printer Logo
    253 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    jasbo
    jasbo
    Electro Med Services...
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
