Question about Music
Roland va7 storing midi files
When I load a midi song into the va7 is there a way to store and then recall it from internal memory or do I have to load it off the disk every time?
Turn it into a style (see Manual)
Posted on Jun 16, 2009
Does the gt10 have an internal battery for the user memorys if so how long does it last
Generally, any unit such as this will have a backup battery for the user changeable areas' memeory. The normal span is 6-8 years, but i change all mine at 5. You should read the manual for your device and/or contact Roland customer service. Here's the info-
http://lib.roland.co.jp/support/en/manuals/res/1810803/GT-10_e2.pdf
Roland Support
Mar 17, 2016 | Music
How do I change MIDI Channels to coincide with my MIDI controller
Your best bet would be to ask Roland. Here is their link-
https://www.roland.com/us/company/contact_us/ Roland Company Contact Us Contact Us
Feb 27, 2016 | Roland Music
I have yamaha PSR-i425 keyboard.can i conect it with my pc to play midi files stored in computer memory?
Yes. You will need to have a MIDI interface on your OC and also select in the sounds control panel of windows that you are using the external synth. The MIDI will expect the PSR to respond to the "general MIDI" assignments.
Sep 08, 2010 | Yamaha YPT400 61 Key Portable Keyboard...
I NEED TO KNOW HOW TO SET UP MY ROLAND JUNO D WITH MY AKAI MPC 1000, PARTICULARLY HOW TO SET UP THE MIDI ON THE ROLAND.
Simple way is MIDI out from Juno to MIDI in on MPC, then (depending on how you want to work), connect MIDI out from MPC to the in on the Juno. If you do this you MUST turn local control off on the Juno or else you'll get double triggers (internal + msg in from MPC). Now to record sequences on MPC , set MIDI to as track in setup window (on the 2500, this is accessed by pressing MODE then pad 9, then press button under the corresponding tab [on LCD]) then set your MIDI channel by port, meaning if your MIDI cable is physically connected to out A, in your LCD in bottom right corner it will show as follows: 1A. This indicates you are transmitting on MIDI channel 1; port A. Remember, MIDI IS NOT AUDIO!!!!! Since the Juno is a synth and not a workstation, all transport controls are handled by the MPC, that's pretty much it... Hope this helps a little, enjoy!
P.S. Go to mpc-forum.com its THE sh**! They also have links for their e-book I have one for the 2500 and its awesome!!!
Aug 16, 2010 | Roland Juno-D
I have PSR-i425 Keyboard from Yamaha. I stored the music piece played by my in the keyboard memory. After that I downloaded the stored file to my PC The file is in this format: 06PK61.BUP. Kindly tell me...
The BUP is an archiving format proprietary to the Yamaha apparently containg styles as well as note data and conversion is really not easy.
If you can get the instrument itself to spill out MIDI and use a MIDI interface and software to capture it on the PC is the best plan.
Once it is in SMF format you can play it on the PC.
Jun 25, 2010 | Yamaha YPT400 61 Key Portable Keyboard...
Roland U-20 no sound
you need to check your midi connection into the unit, check the cable and the channel that you are sending.
Dec 17, 2009 | Music
How can i record songs with juno d ? what can i do with D BEAM ???
record songs with a midi sequencer. the d beam is fun but not very useful!
Dec 14, 2009 | Roland Juno-D
How do i edit and store midi files on my tyros keyboard.
Storing is easy... editing is NOT so easy and is better done using a PC with an editing program.
Not knowing which model Tyros you have, either bring the MIDI files on floppy disk or USB stick.
Select the floppy or the USB source on the Tyros while in the song mode. Find and COPY a file or files, then move back to the place you want to store them like hardrive or user space and PASTE. You can create folders before each to keep the things seperate.
Oct 28, 2009 | Yamaha Full-Size Keyboard
I have just aquired a Roland E-20 synthesizer which I am very pleased with, however, it doesn't have acoustic piano in the tone settings. Is it therefore possible to programme 'acoustic piano' onto the...
They use pre-programed chips. You will have to use the midi out feature to control another midi capable sound module or midi in to a computer and use the internal sound card.
Oct 24, 2009 | Music
None of my programs are receiving midi commands from the FC-300, it's linked into an M-Box II.
I have a FC-200. I don't know by your post what you are trying to do but think of the pedal as a device that can alter a communication between two other devices or one device which transmits info which the pedal receives, alters and then transmits to whatever is on the receiving end. In this case your program. The pedal has to have sysex info transmitted to it or midi info such as a sequence etc. I use mine to control the parameters on my wind syth module. I go from midi out on the module to midi in on the pedal and from midi out on the pedal to midi in on the module. There is also a battery onboard that you might want to check that stores your pedals programmed parameters. Hope this helps.
Aug 30, 2009 | Roland Fc300 Guitar Foot Controller
Music Logo
783 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
