Question about Hotpoint FFA60 Bottom Freezer Refrigerator
Hotpoint 8496p fride not working
I discovered the fan is not ruuning to circulate the air, when i tested the fan directly to power it was running. so the freezer works but the upper fridge chamber doesnot and sfter some time the high temperature light comes back p'se advise on which parts i can replace .
  • Alfred Watuwa Jul 22, 2007
    The fan is free and tested ok
  • Anonymous Dec 02, 2007
    Our problem is very similar - the temperature on both the fridge and the freezer is very eratic but the fridge is the main problem because the temperature is currently running at 21 degrees and doesn't seem to be going down. We have taken off the back panel from the freezer section to remove the built up ice, but this still hasn't worked. We don't know what else to do and we would welcome any advice otherwise we will have to consider buying a new one which is not an option at the moment with Christmas around the corner.
    Debbie
I had a similar problem with a top freezer and it was discovered that the fan had actually slipped down on motor shaft and was stuck against the freezer wall. Check to see if there is enough clearance for the fan to actually spin.
Posted on Jul 22, 2007
SOURCE:
We have an Amana bottom load freezer with fridge on top; the freezer maintains its temperature but the fridge does not. What might the problem be?
Start by checking the circulation fan located in the back of the freezer. You may also want to check to see if the vents in the freezer are clear of debris and ice build up. If the fan is not running, remove the fan motor and test it by applying power directly. If the motor runs with power applied directly then you may need a thermostat.
Nov 23, 2016 | Amana Refrigerators
Hotpoint FFA90 fridge not cooling - freezer working perfectly....
Check to see if the fan is blocked or not functioning. The air is sent to the fridge from the freezer usually with a small fan and if the opening is blocked that will happen. The fan could also be bad or it is not getting any power.
Oct 04, 2014 | Refrigerators
Got a hotpoint ffa97, freezer was still cold and no alarm had gone off to say that that there had been a power cut yet the fridge temp had risen enough to curdle milk??\r\ntemp gauge was still showing...
Milk can sometimes curdle in a working fridge. But it does sound like your defrost system may be malfunctioning. Can you empty your freezer and inspect the defrost system behind the air circulator fan?
I know that defrost elements sometimes go bad and the controllers can pop too. You should check your operators manual and see how to put the fridge into manual defrost. *(it usually involves turning the fridge light on and off by hand. See if the freezer drains during manual defrost. If you have lots of food that dries out in a frost free unit the moisture contains a lot of contaminants that can plug the defrost drain. Which leads to a blocked air passage between the freezer and fridge sides.
You might want to get a small backup fridge for a while to run this down.
Or just use up the food in your fridge before running the tests.
Good luck and be careful.
Jun 28, 2010 | Hotpoint Refrigerators
Fan underneath frig is running but no cold air is coming into the frig or freezer
The fan that is under the frig is the condensor fan(the fan the cools the condenser coils and the compressor. It does not have a direct effect on the chilled air circulation inside of the frig. The evaporator fan is the unit that circulates the chilled air thru your freezer and frig. I am not sure what make model unit you have, but I have found that this fan motor is 90% of the circulation problems i have seen.
Jul 31, 2009 | Refrigerators
Freezer is cold but bottom of refrigerator is not
Replace the fan - it's called the evaporator fan. It circulates cold air evenly in the freezer and blows cold air into the refrigerator section. Its failure would cause the symptoms you describe. Good luck with the repair.
Jan 10, 2009 | Hotpoint HTS20GCNWW / HTS20GCNCC Top...
Not cooling
hi thanks for the question is the compressor running hot if its not hot and the fan by the compressor is running the problem is that the compressor is not starting check the compressor you might need a new start relay mounted on the compressor thanks the appliance doc
Sep 24, 2008 | Hotpoint HSS25GFP Side by Side...
Fan not shutting off
The freezer fan will run at all times with the exception of when the system is in the defrost mode. This is a normal condition. The air circulation fans use very little power and are of low wattage. The fan by the compressor cycles on and off with the compressor.
May 31, 2008 | Hotpoint HSS25GFP Side by Side...
Hotpoint 8496p
this fault is very common for this model but not something that you can do if you r not an engineer the part you will require is an evaperator thermistor to any engineer that is unfamiliar with this it is the green one good luck
Jul 20, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Hotpoint FFA60 Bottom Freezer Refrigerator Logo
182 people viewed this question
Top Hotpoint Refrigerators Experts
Sal De
Steve Allison
Steve Allison
Carmen Mikulic
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
