Question about Compaq Presario 1655 (347550-003) PC Notebook
When I switch on, my Comp will not boot,giving a white screen. although my H/D attempts something. pse help
  • 31 Answers
Try these 2 things. first remove power (battery, charger) now remove the panel that has the HDD and remove it, now put it back in and make sure it makes contact. now remove the panel that has the RAM/memory and remove and re insert them. power it up. if this does not work, that points to a hard ware failure. if there is any beeping noise made by the laptop, make a note of it (how many beeps, if they are short or long)
Posted on Jan 27, 2009
What now
From the boot manager screen you have to go
Change defaults or choose other options.
Then select Choose other options.
Then select Troubleshoot
Then select Advanced options
Then select Startup Settings
Then click restart.
This will restart your computer and will give you a list in which you will select from. It should be option 4
May 18, 2013 | HP 15.6" Compaq Presario CQ58-A10NR Laptop...
I have compaq presario 2100 i was using for 7 months now the screen is black can give me any solution
Try booting in safe mode by pressing the f8 button after the bios post choose safe mode and if you see the display just go to device manager through right click on the my computer and manage and display driver right click and uninstall and restart the comp and should be fine\
Thanks
Dec 05, 2010 | Compaq Presario 2100 Series: 1170B01-90...
I have a compaq presario v5000 that gives me white screen help!!?
have you remembered to reconnect that small wire under the screw on the hinge?
hope this helps
Jun 06, 2010 | Compaq Armada 1700 Notebook
My compaq presario f700 laptop boots when it wants
Your system is damaged. You need to have Vista cd. (or xp, or linux, etc) Then you must get to Bios, or bootmenu. When laptop boots, it is on a screen what key to press to make bios or menu running. Maybe f2 or del, maybe f12. When you in Bios, search something like bootmenu, or advanced bios features, then - first boot device. Make it as -cdrom. Press enter or maybe page up/down to change it. Now you must save this by pressing f10 or some key for save, and pressing y. Comp will boot again and run from Vista cd. In its menu you have option repair, but not always this will work (If you doing it with xp, forget to repair Vista). Try this, and if not working, reinstall system on the same partition. Dont format drive, just install, it will give you no loss of data (with xp, i dont think so, you just have to format system partition, but if you have something on second and more, non system partition, dont format it, data on this second will be ok). This it for instalation. After, you will have old vista in some folder (With xp you dont). You should delete this folder when everything works. Do not delete the new one :) No, no, you will find it easy, it should be something like -oldwindows. Better to remove it, cos' it takes a lot of hd. After it all try to find some good antivirus to avoid situations like this.
Apr 09, 2009 | Compaq Presario 700 470024-192 Notebook
Compaq Presario SR1920NX will not enter boot process
From your description, the BIOS is not recognizing any drives or does not hand off from BIOS to a bootable drive.
Start off by simplifying the system down to keyboard monitor and power cable. Remove *everything* else.
If no boot, unplug power cable, monitor and keyboard. Hold power button in with no power for 15 seconds. This may clear a corrupt BIOS. Reconnect and see if it boots.
If no boot, unplug power again and on the power supply somewhere near where you plug in the power cord look for a small recessed voltage selector. Flip it to 250 then flip back to 115 (these are approximate numbers and may be slightly different on your system). Your system may not even have a voltage selector switch.
If still not booting or no drives are being recognized, we can open the case if you feel comfortable with that.
I have talked a grandmother through replacing a mother board over the phone so we can do this if you want to give it a shot.
Honest1abe
Dec 30, 2008 | HP Compaq Presario SR1920NX PC Desktop
Compaq presario evo 1015v
sounds like a bad screen this might be able to be remedied by hooking the laptop straight to a computer monitor threw the ports provided in the back
also you could have bumped something loose inside like a video card if any cards or memmory comes loose this will give you black screen of death the laptop will have to opened and cards pressed down gently
theres the solution of your power supply on the laptop went out and you need a replacement
if power supply went out it doesnt hurt your comp it just makes it hard to run
May 21, 2008 | Compaq Presario 900 /1500 Series EVO...
My comp doesnot boot
sounds like something was spilled on it
Mar 29, 2008 | Compaq Armada 1700 Notebook
Black Screening
It could be under warranty have the motherboard checked and or the processor. Something is wrong it shouldnt freeze up like that.
Sep 29, 2007 | HP Compaq Presario V2000 Notebook
Compaq Presario 1655 (347550-003) PC Notebook Logo
211 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
