Question about Dryers
Maytag dg712 dryer won't shut at end of cycle.Timer advances.
Units drys fine, but won't shut off at end of cycle. Timer advances to just about zero and stays there. Replaced timer-same problem.
watugot
  • 290 Answers
SOURCE: Trouble with Maytag Legacy gas Dryer
Please provide the model number and I will see if I can figure something out.
It sounds like you have covered the common problems. Usually a motor is the cause for this problem, it gets hot and shuts down until it cools off. I have had some problems with the auto dry controls on the Maytags also.
Are you equiped to do some voltage checks if we need too? This would help in knowing where you have power when it quits.
Thanks/Mike
Posted on Dec 12, 2007
Illeagle
  • 525 Answers
SOURCE: dryer won't cycle
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
http://www.repairclinic.com/0088_8_1.asp#Level1_18
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
    This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 25, 2008
SOURCE: maytag electric dryer won't stop running.
temp selection switch is defective, replace.
nbcrca:)
Posted on Apr 11, 2009
TheMobilian
  • 8220 Answers
SOURCE: Maytag Neptune MDE5500AY Electric Dryer.
Must be a stuck keypad is all I can think of.
Posted on Aug 21, 2010
jumptrout51
  • 3361 Answers
SOURCE: I have a Maytag Atlantis
It would help to know why you replaced the original timer.
Otherwise,you should unplug the dryer,take your wiring diagram and re-check every wire for accuracy.
Take a volt meter after you resume power and start the dryer. Carefully touch the meter leads to the 2 timer wire leads to make sure the timer is getting power.
A bad auto-dry sensor and or a bad control thermostat will stop the timer from advancing.
Posted on Sep 03, 2010
Dryer won't shut off.
Will the timer advance in the NO HEAT mode? If it does advance you would know it has something to do with the temp alright but if it don't advance in No Heat then the timer motor is bad in my opinion. And it can fail by more than one way. Open winding OR stripped motor gear.
Aug 30, 2012 | Maytag Dryers
Timer won't advance on autosense,seems to work normally otherwise. timer advances fine on all other settings. was thinking it was the cycling thermostat, but the blower seems to be cycling. puzzled
when on auto the heat comes on and then shuts off and then the timer advances,when the heat comes back on the timer stops advancing,when on time dry the timer will advance no matter what's happening with the heat.next time send the brand name and model number so i can help you better,if it's gas you could have bad gas coils,you'll have heat for like the first 15 to 30 minutes then when the coils get hot they fail and no heat until they cool down,also if the vent line and the duct that the lint filter goes into hasn't been cleaned out the heat will shut down and if that happens the timer isn't gonna move.check that out and let me know what you find and send the brand and model number.
Sep 24, 2011 | Roper Dryers
Kenmore gas dryer model 76812690 works perfect in timed cycle but will not advance timer and shut the dryer off in auto dry cycle. Vent is cleaned and it drys clothes but runs and does not advance timer...
Hi
I believe that everything else is fine rather it is the the thermal fuse that is located inside the rear panel to the exhaust duct that is bad and should be replaced. If you want you can test this fuse for continuity and if bad replace it as it cannot be reset. If the fuse is fine then it can be due to the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jun 28, 2011 | Dryers
DG712 cycle runs fine but will not shut off at the end of the cycle, just keeps spinning.
If you close the dryer door does it start by-itself without you pushing the start button?
If not then its your timer thats bad.
Jun 16, 2011 | Maytag Dryers
Dryer timer won't shut off at end of cycle. Dryer runs, but no heat. It is a Whirlpool model number LGR4634JQ2.
Since you say that the dryer runs but have no heat, plus the timer won't shut off the odds are the timer is bad. The timer would tell the burner when to be on and when to shut down.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=265840&diagram_id=28265980#d28265980
21 partimage.aspx?imgid=z3bqljbfahrfndg1njc5my9mufcvc290b2hwdhjhcc8%3d
Enlarge Photo
Timer
Part Number: AP3037407 made by WHIRLPOOL $91.55 In Stock
Order now and it will ship Today
Jun 09, 2011 | Dryers
Machine drys fine on timed cycles but shuts off before clothes are dry on automatic cycle.
First try cleaning the moisture sensors with rubbing alcohol, these are two silver colored strips located inside the drier just below the lint cleanout
Oct 31, 2008 | Whirlpool GEW9250 Electric Dryer
Maytag atlantis dryer model # mde6400ayw
sounds like the timer is not completing the cycle in this mode will the dryer shut off if you manuelly advance timer in that mode
Oct 21, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
MAYTAG SDE3606AZW ELECTRIC DRYER
Does the dryer dry fine? If your dryer is taking too long too dry you might have a venting obstruction that is not allowing the dryer too sense that the clothes are dry so the timer won't advance. Try disconnecting the vent from the back of the dryer and dry a load unvented and see if the timer advances.
Jun 11, 2008 | Maytag SDE3606A Electric Dryer
Dryers Logo
Top Dryers Experts
