Question about Whirlpool 5"x36" White Bathroom Drop-in Bathtub Spa Jet
I've been told by a plumber that the tubing to the jet is leaking
Is there any easy fix for a tube/pipe that goes to the jet of a whirlpool tub. i believe it's the 5X36 one. thanks
  • sondee page Jan 28, 2009
    thank you so much. is there a way to pull the jet out from the tub or do i need to go behind it?
  • 33 Answers
You could try Plumber's epoxy stick or paste if the leak is not to big!
The stick has the resin & hardener already in it. The paste you would have to mix equal amount together. I would recommend the paste because it would probably stick to the surface better for you application! Available at Lowes.
Posted on Jan 28, 2009
  • Ron Krysiewski Jan 28, 2009
    Dear sondee, It is always best to get the access you need to work on the problem. It think by pulling the jet you will be looking for another problem. I would use the epoxy paste! Lightly sandpaper where the leak is, this will make the epoxy adhere better. Make sure everything is clean. Take your time, and you will do a good job.
    TheePlumber
Leaking at jet to tub connection
You can fix that with a small amount of "plumber's putty". You have to remove the jet from the tub first, then smear the plumber's putty around the junction where the two meet each other, then reassemble.
Aug 04, 2014 | Jacuzzi Home
New whirlpool bath installed pump working no air coming through jets
I would guess there could be one of two problems. First, open the access pannel so you have acces to the motor and air tubes. From your actuator that turns on the jets, there should be a small tube (probably clear) that goes from the actuator to the motor. this tube controls the jets, make sure it is connected, finding the small nipple that this tube connects to on the motor can be difficult and they are often not connected when you buy the tub or come loose during instalation. If that is OK, check to make sure the Air Inlet pipe is not blocked. there should be one (maybe 2 but usually 1) of the large tubes that circle the tub undernieth that is open on one end. It is probably the tube that is the highest off the ground. this should not be connected to anything, it almostt appears that the water would rush out if you don't connect it to something, but that is where the air comes in for the bubbles. good Luck
May 07, 2011 | Home
Particles coming out of the jets.
This is caused by bacteria build up inside the pipes of the tub. You should use a product like System Flush, Jet Fresh, Jet Clean, Whirlout or similar to clean the tubing.
You can prevent that just as easy by using the tub 4 + times a week.
Jan 17, 2011 | Kohler Home
The bathtub drain pipe [below the tub] is cracked is there any easy fix without removing tub, etc  it maybe could be reached by cutting out part of the adjacent wall otherwise, the water spills onto...
You can do all your fixin underneath where you say it is leaking on the slab if there is room for you to crawl under why remove the tube, more trouble than it is worth.
Jul 18, 2010 | Home
What is oL code?
ol code is for over load. Too many clothes. Sometimes you will get this code with nothing in the tub and the water keeps filling then goes to drain. if this is why your asking then pull the back off the washer and pull the clear tube off the tub. Blow in the tube and then the washer will take off and start operating correctly, Well till you stop blowing. This is a pressure problem and air is leaking right there at the tub and tube. I suggest a little plumbers dope and put the hose back on. if machine does not return to normal then you got a little dope in the air way. Pull the tube and replace again. Wa La!
Apr 05, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Water leaks from around drain in our korral whirlpool tub. Also from around the light that is in tub. Our local plumbers say they cannot find replacement parts..can it be fixed by just using plumbers...
Use of plumber putty should do the trick. take it apart clean it well and apply the putty. For the light, use silicon glue. You can get a tube at any hardware store. There are many different kinds, just read the label and find one for bathroom use. clean around the light and apply. If your unit is white use white silicone, if it is a color use clear.
Hope this helps.
Aug 27, 2009 | Home
We've had a whirlpool tub with jets for 2 years. About a year ago, the jets stopped working--i.e. you push the button and nothing. Whe have it hooked up to one of those cool water circulator things that...
check behind the access door for a air tube that goes from motor switch to button if either side has come off you have to re attach it just cut off 1/4 inch of the tube before you do. that will make it fit tighter
Jul 20, 2009 | Jacuzzi - Bathtub - Alcove - Navona -...
Lasco whirlpool tub leaks. Water runs out on
Sorry, the tub will have to pulled out to find out what is leaking so it can be fixed. There is just no other way UNLESS you can open up the wall on the blind side of the tube. (but its probably and exterior wall...if the house is vinyl sided, it can be done. If brick, you'll have to pull the tub). If you just wanted to convert to a tub only, maybe Bathfitters has an insert solution...
Jul 11, 2009 | Whirlpool Lasco 7460621R Dossi-32 , White
Leaks from jets along outer wall
This is a hard fix, The jets are glued on to the back of the tub with an epoxy type material. the jets should spin on and off from the inside of the tub. You need to determine if it is the hole where the jet is that's leaking or if it is the jet assembly and tubing that is leaking. If it is the jet hole that is leaking, spin the jet off and use aquarium grade silicone (Lowes carries it)
spread this around the piece sticking thru the tub and spin the jet back on. This is a hit or miss fix. No easy fix if it is the tubes or jet assembly, full access necessary for this repair.
Apr 24, 2009 | Home
Parts for my pearl corner tub
any plumbing suply house would have it. good luck
Feb 18, 2009 | Whirlpool Pearl Navarre 7242 True Bathtub...
Whirlpool 5"x36" White Bathroom Drop-in  Bathtub Spa Jet Logo
238 people viewed this question
Top Whirlpool Home Experts
Donni Steen
john h
Mike
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
