Question about Compaq Presario 700 470024-192 Notebook
Laptop screen freezes in different color
I have a presario F700 and after using it for a while say half hour to a hour the screen goes to a different color back ground like a wall paper, its not a solid color it will have lines through it up and down or diagnally and it will be different color each time it does it and evenchually shuts down. The more I turn it back on and try to keep using it the faster it does it. Does this sound like its overheating?
  • weagledms Jan 27, 2009
    Boy I hope its not a motherboard that will cost more than what I paid for it. I bought it as a manufacture referbished for just a little over $300 it came with a 3 month warrenty and its just over that im going on 4 months. go figure.
  • weagledms Jan 28, 2009
    thank you for your response and for your help.
  • 31 Answers
This is definately an over heat issue. since laptops use on onboard graphics card, chances are you might need to replace the mother board, or may it may just need a fan replacement. also purchase a laptop cooling pad
Posted on Jan 27, 2009
  • Robert Jan 28, 2009
    your best option would be to try the cooling pad, it may keep it cool enough so you can use it longer, but this is no guarentee... :(
Compaq presario c700 starts up screen dont work i am using the laptop on a monitor it works fine but it froze up and the screen just turns different colors and you cant see nothing
There might be the issue with the VGA chip and inverter board as the LEd is not even blinking and it is freezing up on external monitor as well.Please get it checked with any local repair vendor.
Thanks
Dec 08, 2009 | HP Compaq Presario C700T
I have a Compaq Presario F700, how can I activate s-video out?
On most laptops it a simple case of pressing two buttons together, usually th 'FN' or 'Function' Key and 'F5' (press fn first, hold down then press f5) Yours maybe slightly different and use a different F key ie F3.
Nov 22, 2009 | Compaq Computers & Internet
When i open the lid of my presario F700 it does not automatically show the screen. I have to move the lid over and over and over again to different points to get the screen to show.
In this regard there is something happen on the video card cable underneath on the hinge of the laptop. I have also Presario laptop that has same issue that you encountered.If you can able to open the laptop's hinge to check the video cable connection then you can check on it by resetting the connnection though. If your not able to do so either to go in the computer shop or have to call HP/Compaq for assistance. Thank you.
Oct 15, 2009 | HP Compaq Presario F500 F700 and G6000...
Can i switch an lcd screen from a compaq f700 to a cpcq60?
You don't know if you can swap the LCD screens until you dismantle both screens and compare them side by side. The video and inverter connectors maybe different.
There are companies on the Internet that sell replacement LCD screens.
One of the ones I use is LCD Parts, use this link to their WEB site.
www.lcdparts.net
Aug 06, 2009 | Compaq Presario 700 470024-192 Notebook
Compaq Presario R4000 looses video and freezes after a while
The problem you describe can be caused by two different things. The two are not related to each other in any way.
The first, which is more common on desktop computers than laptop computers, is a thermal problem. The video chipset is overheating and causing a shutdown of the video. It is possible that this overheating is actually the cpu, but I don't think so, based on your description.
The second is the video power inverter chip. The power needed to keep the lcd screen lit up on a laptop is considerably more than what is needed to run the laptop itself. For this reason, a small power inverter chip is installed on laptops. It is usually found under the plastic bezal that surrounds the screen, and usually on the bottom. When this chip goes bad, the symptoms are as you have described.
Here's a couple things you can do before seeing a technician or teaching yourself to take apart your laptop. Plug in a different monitor; an external monitor and restart your computer. You should have a function option that will let you see two monitors at once. (that's the fn key, usually in the lower left of your keyboard). With two monitors showing exactly the same pictures, see if you can recreate your symptom.
If the problem is in the power inverter chip, the external monitor should remain on when the lcd monitor goes black.
If the problem is inside your computer (video or cpu overheating) then both monitors will go off.
good luck
tony
Jun 17, 2009 | HP Compaq Presario R4000 Notebook
Screen flashes on Compaq laptop
It may be the cable that attaches behind the screen is loose. If you type in your model# and "lcd replacement" in Google you will often find a tutorial on how to take it apart. Patience though our you will break something!
Apr 13, 2009 | Compaq Presario 700 470024-192 Notebook
if u want Drivers for Compaq presario F700 please use below link for win vista Os ..there is all drivers for u r laptop
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&cc=us&dlc=en&product=3629568&lang=en
If this link is useful for u please rate me...........
Jun 14, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq F700 Battery live very less
Giri,
Its normal, generally it comes with 80-90 min. You can use HP Power management to optimize the use of battery. Making screen less bright will increase the power backup.
Thanks
Iqbal
Apr 28, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq Presario 700 470024-192 Notebook Logo
138 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
