Question about Car Audio & Video
I got a Sony CD CHanger for a car, and Got alot of static when it plays
    Scholar:
  • 116 Answers
Those damn FM modulators!! LOL. Yeah, here's some things you can try:
1: Make sure that the frequency o the stereo MATCHES the one you chose onthe FM modulator
2:Try differeny stations
3:make ure that the modulator turns on?
4: OKI. There is no #4 LOL.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Posted on Jan 28, 2009
Static sound
Try a CD cleaning kit and follow instructions if this fails it is more cost effective to replace the CD changer than have it repaired.
Apr 05, 2012 | Sony CDP-CE275 5-Disc CD Changer
When i turn the cd player on it had alot of static?
Unfortuneately, the cd lens worn out, the only way to fix the problem is replace the laser pickup assembly which is not cost effective to repair.
Mar 24, 2012 | JVC CHX1000 12-Disc CD Changer
My Sony MHC-RX30 3 cd changer will not play-- It says "no disc" when there are discs present. Someone told me that the laser lens could be dirty- Any help would be appreciated
Hi Tom,
First of all, thank you for posting your question here at Fixya.com.
The symptoms you've described "No disc Error" is a fault when the optical lens failed to read the disc on its assembly. Yes, one caused of this symptoms is a dirty optical lens due to fine foreign object build-up on the optical lens itself like dust and static electricity build-up.
I would advice you to clean the lens using the CD disc lens cleaner. Play it at least two times to the unit to clean the dirt and static electricity build up. Most of this symptoms resolve by lens cleaning alone.
However, after playing the disc lens cleaner on the unit and still the symptoms persist, this is an indication that the optical lens is faulty. You have to replaced it with new one. Click it here for the replacement.
Before you replaced the optical lens, observe the disc if will spin or not upon playing, if yes then the problem is the optical lens, if not, the fault is on the disc assembly, you have to replaced the entire disc assembly. Contact this LINK to inquire for the parts.
Hope I helped you.
Have a nice day!
Good luck and take care!
Rating and feedback are highly appreciated.
Kind Regards,
Mjsazon
Dec 10, 2011 | Sony 5-Disc CD Changer with SA-CD Playback
What is the best way to clean out dust out of my ony CDPCX455 400 Disc MegaStorage CD Changer by Sony
carefully remove the cover/top of the amp, usually held on by several screws on the 2 sides, and possibly a screw(s) on the back, towards the top. use a can of compressed air to blow the dust up and out. do not use a floor or shop vacuum under any circumstances, because it may produce static electricity and damage the electronics.
i am not responsible if removing the cover alone voids your warranty, but as long as you use only compressed air and DO NOT touch anything inside the changer, nothing will be damaged. again, do not use a vacuum, unless it is especially designed for anti-static electronics use.
Nov 06, 2010 | Sony MegaStorage CDP-CX455 400-Disc CD...
I hooked up my Sony cdx m-600, all works fine but radio does not work. at all. Why?
make sure the unit is hooked to the antenna correctly. This unit will not play the radio and will disable the static noise on the radio. So ensure the antenna is properly hooked in. For more info on how to use the deck click here for the manual. got this directly off sony's website for model cdx m-600. So let me know if that it is properly hooked up and we can figure out where to go from there.
Aug 31, 2010 | Sony CDX-M600 CD Changer
My Sony CD changer (CDX-454RF) won't play the first three slots, and I get error messages on other CD's and plays them when "it" wants to I guess
The changer has a mechanical slide system inside it. It may be binding up around those positions. You may want to take the cover off and reposition some of the excess grease into those slide tracks and try it again. Or you could just be happy with a functioning 7 CD changer.
Aug 05, 2009 | Sony CDX-454RF 10-Disc CD Changer
Sony CDX-727
yes is posible to be fix it but you need to take it to a repair shop request an stimet before they get it fix.
Mar 23, 2009 | Sony CDX-727 10-Disc CD Changer
Sony cd changer
IF IT'S A FIAT BRAVA ORIGINAL CAR RADIO WITH A SONY CHANGER IT WILL HAVE AN INTERFACE BEHIND THE RADIO WHICH MAY NEED RESETTING IF YOU DISCONNECT THE INTERFACE POWER FOR 2 MINS AND RECONNECT IT FAILING THAT THE SONY 6 DISC WILL BE JAMMED, WHICH IS COMMON
Nov 19, 2007 | USA Spec SCD-A88 6-Disc CD Changer
Car Audio & Video Logo
56 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
