Question about Lavazza Espresso Point Capsule Machine
Lightning bolt stays lit - Lavazza Espresso Point Capsule Machine
What is the red lightning sign my dash mean i have a 2005 jeep grand cherokee unlimited 4wd 5.7
You need to take it to a shop and have it scanned so you know the t-case fault codes (transfer case)
Mar 05, 2015 | Jeep Cars & Trucks
Maytag front-loading washer - all lights on indicator panel stay lit unless it is unpluged
1) Change the defective board, and call to the factory for exchange board return.
God bless you
Jun 18, 2012 | Maytag Washing Machines
Scanner is locked with red lightning rod lit on front of printer. How do I unlock?
I am having this same problem today, urgent issue. AC204 will not perform copy function, says "scanner locked" and red lightening bolt lit up. This my first time at this site, i do not see where this answer is ..
Please help me, thank you
May 20, 2010 | Ricoh AC204 All-In-One Laser Printer
Turn flash off
Press Right on the four-way selector (marked by a lightning bolt icon) to cycle through the flash modes. The modes are Auto (marked with a lightning bolt and the letter A), Flash On (marked with a lightning bolt), and Flash Off (marked with a lightning bolt in a circle with a slash through it).
Mar 11, 2010 | Canon PowerShot A560 Digital Camera
Presario c306usLaptop will power on, display flickers. The laptop
Do you have a question?
wow your laptop has a lightning bolt!!! cool, thanks for the info!
Oct 07, 2009 | Computers & Internet
Micron Trek 2 laptop won't start on battery or AC (NBKU375)
The lightning bolt is used to indicate an electrical problem but then, you know that already :-( Try removing the battery pack and start it from AC only; some battery types don't like to be ignored, they can have individual shorted cells.
Sep 30, 2009 | Computers & Internet
When i power up my cf51 it doesnt boot.
Load Ubuntu LiveCD and mount the windows HDD and save all personal files onto a DVD. And then reinstall windows. This will fix it. Thank you.
Sep 17, 2009 | Panasonic Toughbook CF-51 Notebook
2006 Chrysler 300C rides rough when I start it .
the lightning bolt was your alternator symbol your computer needs what they call flashed ie: reprogrammed take to the dealer most shops cant do this.it may never happen again if it does then have it done thanks please rate this answer.
Jan 30, 2009 | 2006 Chrysler 300
Palm v
the lightning bolt indicates that the battery is being charged. I will stay on as long as it is being charged either in the cradle, or using an external charger. If it stays on after it is removed from any external power source, there is a problem with the unit and it needs serviced.
--Randy Miller
Aug 25, 2008 | Palm TX Handheld
Turning the flash off
Set the mode dial to Camera (normal) then by pressing the Up button on the control pad, you may switch between the different flash settings. The settings are:
  • Forced flash (lightning bolt)
  • Slow synchro (bolt plus SL) - this is forces the flash to strobe out of sync so a dark background can be lit up.
  • No flash (no bolt)
Please rate FixYa! ThankYa!
Oct 26, 2007 | Sony Cyber-Shot DSC-P10 Digital Camera
Lavazza Espresso Point Capsule Machine Logo
82 people viewed this question
Top Lavazza Coffee Makers & Espresso Machines Experts
ray gallant
nikolay nikolov
Tom Chichester
Are you a Lavazza Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
