Question about Nintendo Wii Console
My wii doesn't respond to my controler
It areadly has batteries and they're are full and they're new and it is the number 1 contrler.
  • 4 Answers
I had the same problem if your wii is still under the 1 year warranty you can call up nintendo they will try to fix it on the phone if still doesnt work you can start a repair with them. This is free only if you're under the one year warranty.
Posted on Jan 28, 2009
It you mean your wii hand or somthing will not show up ether turn off all the lights, and if that dose not work than go to this senser thang,,, it is the one thing when you first get your wii and swich 1 to 2 to 3 to 4 to 5
Posted on Jan 27, 2009
If the wii remotes aren't working, responding, or charging, can the remotes be reset or do I need new batteries?
First you will meed 2 try new batteries then you will need to press the 'Red' button
located on the Wii console to 'Re-tune' in the Controllers
How to Sync the Wii Remote Standard Mode Wii and Wii mini Nintendo...
May 11, 2014 | Video Game Consoles & Games
Tip
How to snychronize a Wii Remote to the Wii console
A lot of people have trouble synchronizing their Wii Remotes to their Wii console. I have written a short tutorial on how to do this.<br /><br />Figure out which scenario is similar to yours and proceed with the solution-<br /><br />1) When you turn on the Wii console and press any button on the remote no lights light up at all. This is because the remote is dead, you must replace the batteries in the battery compartment on the underside of the remote. If the controller is using a charge pack you need to put the controller on its charger.<br /><br />2) When you turn on the Wii console and press a button on the controller all four lights blink a couple times then turn off. This means the controller is not synchronized. If your controller has ever been previously synchronized all you need to do is press the 1 and 2 buttons at the same time and it will sync up.<br /><br />3) If option 2 doesn't work then this means you are preforming a first time synchronization with the remote. While the Wii console is turned on you should open the little compartment that is just below the disc tray. Then you should press the little red button. After pressing the red button you should open your Wii Remotes battery compartment, remove the batteries and press a similar little red button inside of the compartment. Put the batteries back into the controller and the controller should be synchronized! <br /><br />If none of these solutions are working then the problem is a technical issue with either the Wii remote or the Wii system, you should contact technical support for more information.<br /><br />I hope this helped with the synchronization of Wii Remotes!<br />
on May 16, 2011 | Nintendo Wiimote & Nunchuk Controller...
How do you charge your wii console
The Nintendo Wii is an innovative video game system and much like other video game systems within the Wii's generation, the controllers are all wireless. Because of the wireless technology, the controls must function on batteries in order to operate. Instead of having the game pause in the middle of the action, there are plenty of methods you can test to make sure your Wii remotes are fully charged.
instructions:
  • Charge you're the batteries to your Wii remote by opening the back clip and pulling out both AA batteries. If the batteries are the standard set that came with the Wii, you should upgrade them to rechargeable batteries to save time, money, and garbage waste.
  • 2
    Let the batteries charge for as long as the charger says. In most cases a full charge could take 6 to 12 hours, but fast chargers can fully charge batteries for an hour. Check the charger's manual detailed times.
  • 3
    Use a Wii Charging station for easier charging access. These stations avoid the process of opening and closing the Wii remote every time you need to charge the batteries and they work as a Wii remote stand as well.
  • 4
    Place the batteries back into the Wii remote once the charging has completed. With both the charging stations and rechargeable batteries, lights should indicate when the charging has completed.
  • 5
    Power up the Wii and press any button on the Wii Remote in order to turn it on and connect with the Wii.
  • 6
    Press the "Home" button the Wii Remote control. This button is in the center of the controller and features a small picture of a house on it. A pop-up menu will appear over the screen.
  • 7
    Look at the menu and find your controller number. Right next to the assigned number is a remote battery meter. It will feature 1 through 3 bars to indicate battery level. If it has 3 bars, then the Wii remote is fully charged and ready for use. If it has any less bars then the remote can be used, but is not fully charged. If the battery meter is in red, the remote will shut off soon because there is not enough battery power.
  • Dec 06, 2011 | Nintendo Wii Console
    After pressing the red sync button on the console for about 10-15 seconds, and syncronizing the remote, the remote stars to work, but when I start a game the remote is no longer working. Then when I...
    There are two ways to sync the Wii remote with the Wii console after pressing the red sync button like you did:
    1) Press the "1" and "2" buttons on the Wii remote until the lights begin to flash. This method provides a temporary connection to the Wii.
    2) Open the battery cover on the Wii remote and press the red button next to the batteries. This creates a permanent connection or "pair" between the Wii remote and the Wii console.
    Based on your description, it sounds like you are using method #1. In order to power on the Wii when the Wii's red light is on (meaning the machine is turned off) and start playing games like you want, method #2 must be used.
    Imagine method #1 as "guest mode". If a friend comes over with their Wii remote and wants to play a game, you would open up the game first, use method #1, and your friend would temporarily be connected to the Wii. Using method #1 is like "owner mode" that lets the Wii remote turn the console on and off and always stay connected to it.
    Hope this helps!
    Mar 10, 2011 | Nintendo Wii Console
    Our wii is not responding to the remote controls although they ARE BRAND NEW.
    Have you synced your Wii remotes to the Wii yet? To sync, you have to take the battery cover off of the wii remote and the little vertical rectangle door on the front of the Wii and hold both red buttons. Your Wii remotes should work afterwards.
    May 02, 2010 | Nintendo Wii Console
    I just put new batteries in my Wii controller & it won't turn on. The Wii itself is on, but the controller won't turn on. How do I sync it back?
    1. Press the Power button on the Wii console to turn it on.
    2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
    3. Press and release the SYNC button on the inside of the SD Card compartment on the console. Press and release the SYNC button just below the batteries on the Wii Remote.
    4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through
    Nov 30, 2009 | Nintendo Wii Console
    The ON button on the Wii remote doesn't respond. Tried new batteries but still no response. No blue lights, nothing! Tried patting it, reset button, all instructions as listed in troubleshooting. Had since...
    Try reseting the wii console. This is done by removing the battery from the botton of the console. There is a small battery bay held in by 1 screw. Leave it out for a day and after you install it make sure you press the conect button on the wii. (located under SD card reader door). And the connect button on the controller (located in battery compartment on back of controller). Good Luck.
    Nov 24, 2009 | Nintendo Wii Console
    Will not respond to controller
    You have to open the battery cover on the controller and press the red button as well as open a small cover/door on the front of the Wii system and also press that red button. This will sync that controller to that specific Wii system. You will have to do this when ever you buy a new controller or try to use any of your controllers on a different console.
    Jan 23, 2009 | Sony Playstation 3 (PS3) Console
    Wii remote not responding well
    Send the Wiimote in to Nintendo for replacement. That is your best answer if it's under warrenty.
    Apr 08, 2008 | Nintendo Wii Console
    Nintendo Wii Console Logo
    23 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Raj Patel
    Julian Wainwright
    Martin Murray
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
