Have an amp when i first hooked it up light came on green then it changed to red then light went off completely off so is my amp toast or is there a way to reset it?
SOURCE: My Power Protector Light wont turn Green
switch off the amp then take off all the wires off including the speaker wire and then reconnect the wires on like before the problem is that the amp is on protection and if that dont work then get it repaired another thing is make sure ur amp fuses havent blown.
SOURCE: Amp LED light turns on then off
You need to use a multimeter to confirm that you have both B+ and remote voltage at the amp.
SOURCE: amp wont turn on
It's possible the ground is not a good connection. Sometimes it may look good but dirt or corrosion builds up resistance creating a voltage drop where the wire is grounded to the frame.
SOURCE: RED Port light on AMP?
are you sure its not PROT?
the amplifier is protecting itself from fire because of something.
Disconnect the subs. and turn on.
if it comes on normally, the subs are at fault and will need attention. If the light still stays on, you hafe probably blown an output on the amplifier and it will need repair.
