Question about Westinghouse SK-32H540S 32 in. LCD TV
SOUND BUT NO PICTURE
TV COMES ON WITH SOUND BUT NO PICTURE, AND THERE IS LIGHT IN THE SCREEN, AS IF THE BACK LIGHT WAS WORKING Picture comes on for about 3 seconds, then screen goes blank. Sound is fine, just no picture. Back light is supposed to last 50,000 hours. Doubt they will cover it, anyone know proper tools to replace it myself?
  • motzkoman Jan 28, 2009
    I had the same problem in October with a 7 month old unit and I sent it to El Paso for repair under warranty...they decided it could no be repaired and I got the first replacement Thanksgiving, but it was cracked, so it got sent back and mid January I got another replacement. This one works OK, but it turns itself on every morning at 8 am. I have reset it to factory settings, but it still does it, so based on experience, I will put it on a power strip and dump power to it to turn it off between uses (being used as extra TV in bedroom)....good luck...
  • admmck81 Feb 07, 2009
    I didn't come here to get such a generic and completely unhelpful response. That is hardly a solution I would need to ask for. I see you responded to someone else with the same problem by copy-paste. Really classy there. Anyway, I am not responding to bash your "solutions" what I am looking for is for someone familiar with LCDs to tell me what part I will need to replace and if there are toolkits to replace said parts. There is a very specific tool my TV needs to open it up, one I do not have. I don't go to repair shops without knowing exactly what I want done, as that way there is less chance of being roped into further repairs and charges. If anyone can provide this information, it would be greatly appreciated.
I had the same problem today with the same symptoms. I tried a power reset, removing the cables, checked all inputs and got the same symptoms.
I found a temporary fix. When I turned the TV on, I immediately press the backlight but on the remote until the bar appears then lower the setting down to 10. This may take a couple of tries of powering the TV off/on. Once I got the setting lowered to 10, the picture stayed on. If you invoke any of the presets it will change this setting. I'm going to call someone and try to get more information on a permanent fix.
I hope this helps, at least I got the picture back.
Posted on Oct 05, 2009
    Scholar:
  • 21 Answers
I had this problem on my 42" Philips. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
Hope this helps, may not apply to your situation.
Posted on Sep 18, 2009
  • 679 Answers
You almost certainly are between a rock and a hard place. If you have to come here to ask this question (and no offense is intended or implied), you probably won't be able to do anything to repair the unit yourself. What you can do is call around to some local shops and describe the problem and see what kind of repair costs you might incur having it repaired.
Posted on Feb 07, 2009
  • safram Apr 08, 2011
    Had the same problem. Bought a Westinghouse 56.04073.011 Power Supply / Backlight Inverter for my Westinghouse SK-32H540S from Shopjimmy for $82-00 http://www.shopjimmy.com/westinghouse-56... Pulled the black cover off the TV. Then I loosened the 6 little screws that holds the board, plus I unplugged the little plugs, screwed the new board in place, reinserted the plugs, closed the back panel, reconnected the TV and WALLAH.... it works perfectly. It took me all of 10 minutes
    Quick Reply
My LG tv will go on then after a few seconds the screen goes from black back to picture of and on a few times then shuts off. Help!
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
7 days ago - My 32' LG LED TV has suddenly lost picture! The sound is all right but theScreen is pitch black. After switching it on the picture flashes for a second and thenthe ... LG LED TV has no picture (black screen) but still sound - can it be fixed? Tags: ... a touch on the screen reveals nothing so it's not the back light.
Monitor going black after 2 seconds [Solved] - CCM.net
ccm.net > Forum > Hardware
Oct 9, 2012 - Brightness goes down, display draws less juice, and you can at least use .... it's the LCD's Inverter ... you have to replace it for it to go back to ... If the screen is turning off every two seconds or so and then it comes ... i turn my tv on it comes right on, but then after a few minutes turns off, .... Digital Trends for LG. No display in monitor
Jan 11, 2013
Ps3 and hdmi cable
Oct 8, 2012
More results from ccm.net
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
Dec 20, 2015 | LG Televison & Video
Picture freezes, sound continues for 5-10 seconds. tv shuts off and comes back on after 5-10 seconds. problems reoccurs with increasing frequency.
In these cases you might be able to see a picture by shining a bright light right next to the screen front. Do not put the light there for very long or you will end up with a permanent bright spot burt onto the screen. I have discovered that applying light pressure with a 3/8" thick rubber or plastic shim corrects a panel inverter/driver board/card solder problem with many flat panel TVs. (Removing the TV back is required, try light pressure against the inverter board while wearing rubber gloves and tv is then powered on.)
Jun 14, 2010 | Toshiba 32AV500U 32 in. LCD HDTV
Maganavox flat screen tv no pic, red light blink codes...
Those blinks are fault codes. To know more visit the site linked here. http://electronicshelponline.blogspot.com/
Mar 25, 2017 | Televison & Video
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
No Picture & No sound. Red LED, Green LED, Red LED.
If the power supply outputs are good! Then I would say the back light inverter is bad! If the screen stays black and does not come on.
Jan 14, 2009 | Akai LCT2660 26 in. HD-Ready LCD...
My Sony comes on then both sound and picture goes black.
After being on a little while, the screen goes black (no audio as well) for 20 to 30 seconds. Green light stays on. Then, picture comes back on and takes a couple of seconds to get up to full brightness. About 5 seconds or so after the video comes back, the audio returns.
Until this morning, has only happened a couple of times a day, now happening more often. About 3 times in last 20 minutes.
KDF-E55A20 is about 3 years old.
May 03, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
No picture, but power light is on
THE POWER SUPPLY OF YOUR TV WAS THE PROBLEM,YOU COLD SOLDER THE MAINBOARD OF YOUR TV,AND THE CRT SOCKET CONNECT TO THE TUBE IS ALSO COLDSOLDER,.
Mar 13, 2008 | RCA 27F530T 27" TV
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Westinghouse SK-32H540S 32 in. LCD TV Logo
932 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
