Question about Canon PIXMA iP4000R InkJet Printer
Ip4000r not printing cyan
My printer is not printing in cyan. I have put a new cartridge in it and run the the printer clean several times but it still is not printing cyan very well on the test sheet. Please help!
  • 2 more comments
  • Anonymous Feb 10, 2008
    SAME PROBLEM - CHANGED CARTRIDGE, RAN DEEP CLEANER, BLUE STILL PRINTS AS PURPLE.
    NEED HELP.
    THANKS
  • iJamesS Feb 22, 2008
    The test sheet seems to print fine, but when I print a photo, it's all muddy yellowish I think because cyan is not printing?!?
  • mia moore Jun 12, 2008
    No blue nor green (naturally) Have deep cleaned several times. Do I need a new head (for the printer)?
  • merlepoet Jan 22, 2009
    my printer stopped printing cyan a couple days ago. when I print a test page, the line for cyan (blue) is completely blank. - any ideas
  • 164 Answers
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your printer in new condition.
Hope this helps. .
Posted on Feb 07, 2010
  • 1 more comment
  • JM Alvis Feb 07, 2010
    Supplies needed:
    paper towels
    latex gloves
    warm water
    PROCEDURE:
    Hope this helps. .
    Supplies needed:
    paper towels
    latex gloves
    warm water
    PROCEDURE:
    Hope this helps. .
    Supplies needed:
    paper towels
    latex gloves
    warm water
    PROCEDURE:
    Hope this helps. .
SOURCE:
Inkhead clogged. Have tried deep cleaning several times. Cyan just won't print even though it is a new cartridge
Inkjet printers do not like being left unused.
The print head may be blocked. Try several deep cleaning of the print head to see if it can clear the blocked print nozzles.
If none of this works then the print head needs to be replaced.
A new cartridge will not solve this problem.
NOTE the print head is not a cheap item, you may consider putting the money towards a new and better printer.
Nov 14, 2010 | Lexmark Prospect Pro205 Wireless...
Will not print cyan
The cyan print head may be blocked. Try several deep cleaning of the print head to see if it can clear the blocked cyan print nozzles. Also check the cyan cartridge, make sure it is not empty.
If none of this works then the print head needs to be replaced. NOTE the print head is not a cheap item, you may consider putting the money towards a new and better printer.
Nov 13, 2010 | Canon I960 InkJet Photo Printer
Hello my 7590 printer will not print in cyan
The chances are you have a defective cyan ink cartridge. If you are using an aftermarket/reloaded cartridge and the cartridge chip is defective. First try a new cartridge. The best bet is a new OEM cartridge, run the deep cleaning utility 3 times. The nozzle may be clogged and this will clean the nozzle.
Aftermarket/reloaded cartridges ink do not always meet the specifications for the printers that use the finer inks.
Let me know if this works for you. Thanks.
Mar 07, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
OUR BOTHER MFC-240C, DOES NOT PRINT THE BLACK CARTRIDGE. IT IS A FULL CARTRIDGE, AND GOES THROUGH THE MOTIONS AS IF IT IS PRINTING, BUT COMES OUT BLANK. I HAVE HAD THE MACHINE RUN THE CLEAN FUNCTION...
i have the exact same problem! i have a brand new cartridge i took of the yellow thing it says to remove, and i put it in properly. it recognizes it, it has cleaned it several times. i have restarted my computer and the printer, i have unplugged and replugged. when i did the test print only the yellow cyan and magenta showed up. i am very frustrated! any help would be appreciated.
Dec 26, 2009 | Brother MFC 240C All-In-One InkJet Printer
Cyan cartridge prints spotty.
Your print head is probably clogged. If you have already tried the cleaning cycle, it's time to take the printer into an Epson repair center to find out what the problem is. More than likely they will have to replace the print head.
Jul 11, 2009 | Epson Stylus C84 InkJet Printer
Cyan Ink cartridge Not printing correctly
After all these tests, then it's defective.
Swap out the cartridge before it damages the printer permanently,
Regards
Ric.
Apr 17, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Cyan will not print
Try replacing the cartridge. Sometimes they do get clogged and won't clear no matter how many cleaning cycles you run.
....John
Mar 07, 2008 | Epson Stylus Photo R1800 InkJet Printer
Print problem with Cyan cartridge
i had to run 10 cleaning to get a printer to print magenta. finally it cleaned it self..it gets expensive..leaving your printer on keeps the in nozzles clean..when its off for long periods it dries in the nozzles.
Oct 14, 2007 | Epson Stylus Photo R320 InkJet Printer
Canon PIXMA iP4000R InkJet Printer Logo
52 people viewed this question
Clive
Clive
old marine
old marine
