Question about Hitachi (H3500U) 500 GB USB Hard Drive
The pc does not reconi - Hitachi (H3500U) 500 GB USB Hard Drive
How can i install nokia pc suit in nokia 3110c right now
hOw?
You need pc with suitable pc suite nokia for your phone.
Then you need Bluetooth or cable to connect between your pc and your phone.
If you have this then you open pc suite nokia on your pc.
Link PDF GUIDE PC SUITE
lInk to download pc suite 7
that new version pc suite.
After you have installed the pc suite to your pc, then connect, it will ask you to install at phone.
IF YOU HAVE BLUETOOTH DEVICE AT YOUR PC/LAPTOP, THEN YOU CAN CONNECT IT . TRY CONNECT IT FIRST USING BLUETOOTH. THEN IF IT WAS CONNECTED, USING PC SUITE.
May 28, 2011 | Nokia 3110 Cellular Phone
Tip
5 Ways to Speed Up PC
Are you fed up with your slow PC? Well you can Speed Up your PC by 3 times. In this post you’ll find some of the most significant ways to speed up your PC. For your convenience, I ’ll split this post into 2 parts.
1. Automatic Ways to Speed Up PC (Using PC Speed Up Softwares)
2. Manual Ways to Speed Up PC
Automatic Ways to Speed Up PC You can use a PC Optimizer Tool to automatically boost the Speed of your PC without the need to worry about the manual ways of doing it. These tools will automatically find and fix upto 99% of your PC errors by optimizing the Windows registry, cleaning up junk files, removing unwanted items from the start up etc. This can speed up your PC and Internet speed by upto 3 times. Here are some of the best PC Optimizer Programs that I recommend.
1. Perfect Optimizer
2. Registry Easy
Using a PC Optimizer is the easiest way to speed up your PC. This is because, most of the performance tweaks such as Registry Cleanup cannot be done manually.
Manual Ways to Speed Up Your PC 1. Free Up Disk Space to increase the speed of your PC
  • Remove temporary Internet files.
  • Empty the Recycle Bin.
  • Remove Windows temporary files.
  • Uninstall Programs that you no longer use.
2. Periodically Perform Hard Disk Defragment. This can Speed Up your PC significantly.
3. Clean Up your Registry (Highly Recommended)
Cleaning Up your Windows Registry is very much necessary to speed up your PC. Unfortunately you cannot do this manually. You have to use a Registry Cleaner to do this. Here is the best registry cleaner on the web.
Registry Easy
A complete review of registry cleaners can be found at Registry Cleaner Comparison
4. Clean Up the browser cache to Speed Up your Internet.
5. Install a good Antispyware software
Spywares can really hurt the performance of your PC. So, install a good anti-spyware to protect your PC from spywares and improve the speed of your PC. I recommend the following Antispywares to protect your PC.
1. Spyware Cease
2. Nodware Anti-Spyware
Which is the Best Way to Speed Up my PC? (Auto or Manual) The best way to speed Up your PC is by using a PC Optimizer such as Perfect Optimizer or Registry Easy. This is because, manual ways can only perform 30-40% of the tweaks to improve the speed of your PC, but the most important aspect of the Speed Up process such as Registry clean Up and other advanced performance tweaks can only be done using a PC Optimizer software. So if you are serious about improving the speed of your PC, then you need to use a PC Optimizer.
AKPC_IDS += "1167,";Popularity: 9% [?]
on Mar 30, 2010 | Computers & Internet
I've inserted SD card 2 GB and its not detecting...
hi
push the card in the sd slot
go to device manager
go to the top icons and hover mouse over them
one of the last ones on the top right should say scan for new hardware
so click on the scan icon
the compute may or may not find it
then leaving the sd card inserted
restart the laptop
and hopefully it will be reconiized if not
go start
programs
windows updates
check for updates
windows may offer you the update to install the sd driver
But make sure you do all the updates
before you do this
www.lenovo.com go to support/downloads
find your make model and operating system
then scroll down to find the sd card driver
download it
install it
restart laptop
and hopefully it will be ok
please let us know if fixya fixed it for ya
Feb 19, 2011 | Lenovo 3000 N200 T7100 1.8G 1GB 160GB...
After i install windows on my sony notebook computer model pcg-9251 it comes upin dos saying does not reconieds operating system
Please enter the BIOS and check that the hard drive is detected or not it seems that the PC can not detect the hard drive to enter the BIOS please look for the instructions when you start the PC like "Press F2 to enter setup.." etc..
Feb 16, 2010 | Sony Computers & Internet
I cant acces my pny.com/ngbonus for my bonus
my music is on the stick but my phone dont reconis it
Jan 01, 2010 | PNY 2GB microSD Memory Card
Software for connecting through data cable to pc
Hi Friend,
For connecting the PC and the Mobile through the Data cable you have to use the Nokia PC suite which has to be installed in your PC.
You can download the PC suite form the below link as follows,
http://www.nokia.com.sg/get-support-and-software/download-software/nokia-pc-suites/compatibility-and-download
1.Install the PC suite to the PC
2.Access the mobile from the PC through the Data cable
3.Now can transfer the datas through the data cable from PC to Mobile and from Mobile to PC
Check and revert back
Thanks for using Fixya
Regards,
Ayyasam
Jul 12, 2009 | Nokia Cell Phones
Updat to new sata hard drive from old idie hard drive.wont reconi
Hi, you will need to load the sata raid drivers when installing the OS. Some off the older versions of xp will not have these, when windows is installing it will ask if you need to install a 3rd party raid driver press F6. later on it will ask you to insert the raid driver disk. which you may have to do/make yourself if you haven't already got one.
Mar 01, 2009 | Computers & Internet
My pc dose not reconies my phone my phone dose not get reconized by my pc and i dont have my disc to upload so i can charge and upload music on my phone and i dont know where to go so i can...
There's no easy solution to this one. Motorola has blocked your ability to charge your phone and create ringtones without you buying their software. Breakdown and pay the $$ for the software or you're S.O.L.
Aug 31, 2006 | Motorola Mobility RAZR V3
Hitachi (H3500U) 500 GB USB Hard Drive Logo
24 people viewed this question
Top Hitachi Computers & Internet Experts
Fotis Papastamatiou
steve morris
steve morris
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
