Question about Gestetner C7417 Laser Printer
Error code sc486 - Gestetner C7417 Laser Printer
The code ER CO keeps coming on, on the display panel. The fridge and freezer still work but the code keeps coming up. Any info on that?
LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
Select
Use our model number finder
Choose your product type
Common model number plates
Close
LG Refrigerator Error Codes
These error code explanations can help you diagnose a problem with your LG bottom-freezer refrigerator. For repair how-to help, visit the PartsDirect repair help section, which includes repair help for washing machines, other major appliances, lawn and garden equipment, garage door openers, vacuum cleaners and more. You can also search for owner's manuals, get advice from an expert and find refrigerator replacement parts. Error Code
Er FS Error Code
Er rS Error Code
F dS Error Code
r dS Error Code
Er HS Error Code
Er IS Error Code
Er SS Error Code
Er rt Error Code
Er It Error Code
Er gF Error Code Error Code
r dH Error Code
Er IF Error Code
Er FF Error Code
Er CF Condition
Condenser fan motor is defective Check/Repair
Condenser fan motor, wiring or the control board Shop Parts
Condenser fan motor, Power control board, Wiring harness Error Code
Er CO Condition
Communication error Check/Repair
Communication error between main board and display board Shop Parts
Display control board, Power control board, Wiring harness
Jul 16, 2015 | LG LFX25974ST 24.7 cu. ft. French Door...
Why does error sc486 power off/on occur when printing
Something inside printer is blocked. There is a magnetic clutch that sometimes could be a reason. Check that Waste Toner bottle is not full because in that case many bad things can happened.
I can tell you this for sure:
it's time to replace the printer with new one!!!
Maybe you will be able to buy cheep SPC410, SPC420. They are perfect
May 21, 2014 | Ricoh Aficio CL2000N Laser Printer
My Printer Aficio C7417n is displaying error SC486
Open the front door , The blue clips {} on each side
hang them up and remove the paper which stucked into your printer
then put down the clips
and close the front door
it's done 4 me , hope it'll be the same for you
and sorry for my bad English :)
May 26, 2011 | Gestetner C7417 Laser Printer
Sc-486 on the Ricoh Aficio CL3000 printer
sc486 is a problem with either the engine control board or the drive unit, or the connection between them. One or the other will probably have to be replaced, depending on exactly what's causing the problem.
Mar 22, 2011 | Ricoh Aficio CL3000 Laser Printer
Code sc486
BK Solenoid Error : The BK solenoid cannot drive the black PCU
Engine board or Drive unit is probably broken
Jan 22, 2011 | Ricoh Aficio CL2000N Laser Printer
Printer jams when printing and I ricoh cl2000n error code sc486
sc486 is a solenoid error with the black drum unit. The most likely culprits are a bad engine board and a bad drive unit, neither one of which is cheap unfortunately. You should contact your local service technician and have them take a look at the printer to see which component is causing your problem.
Dec 10, 2010 | Ricoh Aficio CL2000N Laser Printer
Ricoh CL2000 SC486
it is the problem your cartridge sensor chip.You change cartridge unite & buy new cartridge than solve it
May 30, 2009 | Ricoh Aficio CL2000N Laser Printer
Ricoh CL2000 SC486
Realizar a troca do BK Solenoid.
Ele está localizado dentro do driver onde estão as engrenagens, ao lado esquerdo da impressora atrás da placa BICU
May 21, 2008 | Ricoh Aficio CL2000N Laser Printer
Richo cl3500n error code sc486
Reinstall the driver again.
Regards,
Ashok
Feb 13, 2008 | Computers & Internet
Gestetner C7417 Laser Printer Logo
64 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
