Question about Brother MFC-8840D All-In-One Laser Printer
Erro 78 brother 8085
Error code 48
There is a problem on the print head, Please Contact Brother Printer Experts Brother Printer Support
Feb 25, 2014 | Brother DCP 165C Compact Color Inkjet...
Print unable 78
Error 78 indicates a mechanical malfunction from within the printer. Not6 really anything you can do as the end user. I would recommend getting in touch with Brother or a printer technician.
Jan 23, 2013 | Brother MFC-8480DN All-In-One Laser...
Brother sx-16
The keyboard is bad try my tip under WW1000 or contact Geo. Beyers Co. @ 800-392-8085 for a rebuild.
DickyO
Jan 02, 2012 | Office Equipment & Supplies
GETTING MACHINE ERROR ERROR 78 , PRINTER NAME BROTHER MFC 8840D
Machine Error 78 indicates a mechanical malfunction of the Brother MFC-8840D. 78 represents the error number. You have to contact Brother Customer Service 1-877-BROTHER.
Dec 22, 2010 | Brother MFC-8840D All-In-One Laser Printer
How do I fix a machine error 78 on my brother MFC 8300?
unfortunately that specific error is pointing to a problem with the thermistor. here is the error code from Brother:78 Heater thermistor harness disconnected or broken. - SOLUTION: REPLACE FUSER UNIT
HERE is a link to other error codes and possible solutions.
Aug 30, 2010 | Brother MFC 8300 Laser Printer
Brother mfc490cw printer show offline and erro
Hello there:
for the document you want to print click on print and your printer should show up now just click on the printer and look down where it says use printer offline and click on it again and than it will say use printer online and just print from there ok please dont forget to rate this solution for me
best regards mike
Aug 06, 2009 | Office Equipment & Supplies
Brother mfc 8440 error 78
This refers to a error with the fuser temperature you need it repaired by a service technician. Parts can be as little as $15 for the thermistor sensor or as much as $100 for a new fuser.
Jun 07, 2009 | Brother MFC-8440 All-In-One Laser Printer
Machine error 78
It means you need to replace the fuser. Depending on what model it is it may be cheaper to replace the fax.
Apr 09, 2009 | Brother Office Equipment & Supplies
Machine error 78 offline
You have a bad FUSER. There's nothing you can do. A dealer must replace the fuser.
Jun 26, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Brother MFC-8840D All-In-One Laser Printer Logo
126 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
