Question about Vapor 2300 LadyBug XL Steam Vacuum
Vapor 2300 won't heat - Vapor 2300 LadyBug XL Steam Vacuum
My unit heats up, has plenty of water, but will not spray, pressure is at 4
Sounds like a blocked nozzle. I would soak it in line Away or used a safety pin to clear it
Apr 28, 2016 | Vapor WhiteWing Steamer Canister Vacuum
I just bought a bissell pro heat shampooer it worked the first time now it won't **** up water
go please to the web page:http://www.bissell.com/maintenance-tips/
and proceed according with the videos for troubleshooting+fix it.
God bless you
Aug 02, 2012 | Vacuums
Won't heat the water
Continuity check from the input to the output. If open, then check from the heater element to the out put and then the other side, then the switches and other safety switches. When you find an open component that shouldn't be you have found your problem. You need and ohmmeter or continutiy checker. If don't know what I am talking about get it looked at by someone who does. If you do, then I should have to tell you any of this.
Nov 11, 2011 | Hoover SteamVac F5914-900 SpinScrub...
I have a euro model s3325 and when i turn on the power switch it says its steam ready but will not heat up
I think it may be from the same issue stated above--the thermal fuse blew. I have the exact same problem. This is what someone posted earlier:
There's a thermal fuse inside. If it gets too hot, the fuse will blow and the thing won't turn on.
It has a 216 C temp limit. You can find thermal fuses at radio shack for less than 5$. If you're adventurous enough, you can find the fuse in line of a white wire under a fiberglass outer and heat shrink inner shielding screwed against the bottom of the tank.
Now to figure out how to get to it!!!
Aug 12, 2011 | Euro-Pro S3325 Handheld Steam Vacuum
The vacuum won't start. I used it for about an hour and then turned it off and when I went to turn it back on ..there was no response. I cleaned every compartment on the machine and it's still not...
Sorry to hear you're having difficulties with you're DC07. If the cleaner won't run at all, it's probably best if you get in touch with us directly so one of our experts can run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 1866MYDYSON - or if you email your details to askdysonUS@dyson.com, someone will be in touch with you as soon as possible. We look forward to hearing from you.
Kind regards,
Jack
Dyson Customer Service
Aug 11, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My polti vaporetto 2300 is belching with steam,have changd the safety cap seal,but hasn't helped --any ideas
My polti 2300 vaporetta is heating the water but not getting up to steam, could the problem be the safety cap?
Nov 17, 2010 | Polti Eco Pro 3000 Canister Steam Vacuum
My mini steam zapper heats but produces no heat
you should get steam in the amount of time it take to boil water
Feb 18, 2009 | EuroSteam Vapor Steam Cleaner Vacuum
My Bissell Pro-Heat 2x 12 amps Model 9200-2 The rollers wont turn and the water wont release
my bissell 9200 won't release water or solution when the trigger is pulled.
Sep 16, 2008 | Bissell 9200 Upright Vacuum
Vapor 2300 LadyBug XL Steam Vacuum Logo
Top Vapor Vacuums Experts
richie46
ray gallant
Tom Chichester
Are you a Vapor Vacuum Expert? Answer questions, earn points and help others
