Question about 477L Ask RXTX HHU Remote
Starts need manual for 477lstarter
Want to shut off auto start
04 pt cruiser auto. start engine put in gear and drive shifts fine. eng light is on from time of start.
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Jan 06, 2017 | Chrysler PT Cruiser Cars & Trucks
Tip
Copiers Sharp AL-1631 AL-1641CS DESCRIPTION OF SPECIAL FUNCTIONS
Toner save mode
Reduces toner consumption by approximately 10%.
Power save modes
The unit has two power save modes of operation: preheat mode and auto power
shut-off mode.
Preheat mode
When the unit enters the preheat mode, the power save indicator will light up
and other indicators will remain on or off as before. In this condition, the fuser in
the unit is maintained at a lower heat level, thereby saving power. To copy from
the preheat mode, make desired copier selections and press the start key
using the normal copying procedure.
Auto power shut-off mode
When the unit enters the auto power shut-off mode, the power save ( ) indicator
will light up and other indicators except the ONLINE indicator will go out. The auto
power shut-off mode saves more power than the preheat mode but requires a
longer time before starting copying. To copy from the auto power shut-off mode,
press the start key. Then make desired copier selections and press the star key using the normal copying procedure.
Auto clear
The unit returns to the initial settings a preset amount of time after the end of copy, or
scanner job. This preset amount of time (auto clear time) can be changed.
Stream feeding mode
For description of the stream feeding mode, see "Stream feeding mode".
Resolution of AUTO & MANUAL mode
You can set the copy resolution used for AUTO and MANUAL ( ) exposure
mode.
on Mar 14, 2010 | Office Equipment & Supplies
Bizerba SE12 slicer with the auto slicing. When on manual it runs for 30 seconds and shuts off. Start it again right away, after 30 seconds it shuts off. Manual slice it does not shut off Suggestions?
turn up auto operation time (knob on side) not thickness knob to a time more acceptable to you (or it can be malfunctioning too) just by noting auto slice mode tells you it runs on a timer , as it auto advances product to make even thickness slices each time
Aug 13, 2016 | Kitchen Appliances - Others
My auto start will start my car but when I turn the key on and press the brake to shift into drive it shuts down. Also will not start with the key. It is a 1994 Honda Accord
Do you have manual transmission? This issue may have something to do with that. Auto starters may signal that the ignition switch is faulty. Check the following link for info regarding this auto switch and how it interacts with the car in the event of an ignition switch use:
Can get Remote Car Starter on Manual Transmission
Feb 12, 2015 | Honda Cars & Trucks
Pride mobility where is the auto shut off
hi, what happens is the controller does a countdown when the wigwag is not touched for a period of time, then shuts down, so turning off then on again starts the controller again...
Regards
Rob
www.gewizrepairs.co.uk
Mar 11, 2014 | Pride Health & Beauty
Well i was trying to see why is my car cutting off everytime i try and start it.????
http://ezinearticles.com/?Find-the-Free-Auto-Repair-Manual-You-Need-Online&id=92717
May 02, 2010 | 1994 Ford Taurus
Sharp al 1631 need drum roller reset code
enter code 42 start 1 start.
(press C auto C auto 42 copy1 copy)
Apr 28, 2010 | Sharp AL 1631 Copier
Turning alarm on and off
I'm afraid I don't have a manual, but I could walk you through the steps...
1. Press the clock/sleep/timer button twice.
2. Press enter button.
3. Turn dial to set hour for alarm to start.
4. Press enter button.
5. Turn dial to set minute for alarm to start.
6. Press enter button.
7. Turn dial to set hour for alarm auto-shut off.
8. Press enter button.
9. Turn dial to set minute for alarm auto-shut off.
10. Press enter button.
11. Turn dial to select either Radio or CD alarm setting.
12. Press enter button.
13. Turn dial to adjust volume of alarm.
14. Press enter button.
15. Press standby button. Alarm is set.
I hope this helps! Best of luck finding a manual if you still need one. :)
Jun 03, 2009 | Sony PSYC CFD-E90 Radio/Cassette/CD...
Fire tripping exhaust fans
check wiring properly
Nov 09, 2007 | Heating & Cooling
477L Ask RXTX HHU Remote Logo
21 people viewed this question
Top Avital Vehicle Parts & Accessories Experts
D. E. Hev
baire
Billy Mac
Are you an Avital Vehicle Part and Accessory Expert? Answer questions, earn points and help others
