Question about Microwave Ovens
GE Spacemaker model #: JVM1339BW 003 - Microwave Ovens
jsrock516
  • 5911 Answers
SOURCE: Our handle broke off our GE Profile Spacemaker Oven
You can easily perform this repair on your own and save the cost of labor charges and a service fee. Go to appliancepartspros.com and type in the model number you provided. The door handle is located under Section 1 as item number 1801. Make sure you order the correct color.
To access the door handle mounting screws, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to simply pry the plastic up and work your way gradually around the perimiter of the glass. Most microwave ovens have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
If you have questions, please let me know. I hope you find this information helpful.
Posted on May 12, 2009
  • 70 Answers
SOURCE: JVM 1660WB 003 GE Profile Microwave humming sound/burning smell
the magnetron the unit has gone bad.sometimes there is burning smell as u mentioned.it is little expensive repair arond $ 150.00.find out the price of new unit plus iistallation/delivery chg and then make a decision.
Posted on Aug 18, 2009
jsrock516
  • 5911 Answers
SOURCE: The door handle on my GE Spacemaker XL model
If the outer door is not broken. All you have to do is replace the handle. You will need to access the door handle mounting screws and remove them to replace the door handle. To access the screws on MOST microwave ovens, you must remove the inner door panel that goes around the perimeter of the glass. This can be accomplished by using a small screwdriver or putty knife and carefully insert along the seam of the inner panel and pry the plastic up. Work your way slowly around the perimiter of the glass to pop the panel loose. Use care not to pry against the glass. The glass is tempered and also has an RF shield that shields you from harmful microwaves.
With the inner panel removed, the door handle screws are visibile and can easily be accessed with a screwdriver. Simply remove the broken handle and install the new one. Re-insert the inner door panel, gradually working your way around the perimeter of the door glass to ensure it snaps back into place and seats properly.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. On some microwaves, you may have to remove the upper grill cover over the door (if equipped) to accommodate door removal. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
NOTE: Some doors have a hinge pin that needs to be removed, or screws holding the door in place at the hinge.
You can view an exploded view diagram of your microwave at pcappliancerepair.com for reference. Just type in your model number and locate the parts listing for the door. The part number for the door handle is WB15X10020. If the outer panel is damaged, you may have to replace the entire door. The part number is WB55X991. The cheapest web source I have found the handle listed is appliancepartspros.com for $47. The entire door, however, sells for $110 at pcappliancerepair.com.
The RF inside the cavity of a microwave oven is actually controlled by the RF shield in the glass. As long as the glass is intact and the inner door facing is not bowed, warped or cracked, you will not have to worry about RF leakage (even with the handle broken off).
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
Posted on Nov 03, 2009
Testimonial: "A great resource"
  • 18 Answers
SOURCE: GE SPACEMAKER XL1800 MODEL: JVM1860BF001
MAGNETRON, 99% of the time with your complaint
Posted on Nov 21, 2009
Testimonial: "thanks. I just hate to replace whole unit but it looks like it is going to cost 125 for magentron and 100 for service call plus. "
MicrowaveSvc
  • 9098 Answers
SOURCE: F3 error GE Spacemaker XL 1800: Model JVM1851CD.
F3 on a GE / Hotpoint microwave means you have a shorted membrane keypad (aka membrane switch).
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs nationwide.
Either way, we can let you know what your options and costs would be and send you other helpful info.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me
directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Posted on May 06, 2010
GE SPACEMAKER MICROWAVE OVEN MODEL J VM64 003 LIGHT SWITCH BROKE HOW DO I REPLACE IT?
Unfortunately it appears none of these parts are avail anymore. The physical buttons, key panel assy, touch pad support are no longer available. The smart board (WB27X5239) seems to floating around, but this does not appear to contain either of the 2 buttons or switches as part of it's assembly. Pleazer Appliance..
Jan 11, 2015 | GE Microwave Ovens
J,VM59 003 Feb '84 date GE Spacesaver-My display went dark. Otherwise it is fine.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 13, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Need to remove a Spacemaker Microwave oven Model J VM 46 003. Made 1979
Remove from wall dispose of correctly. Manual may help if you can get one to see how it was installed..
Jun 10, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Aug 17, 2009 | Microwave Ovens
Clock timer volume too low
The beeper sound level can be adjusted.
Press the "BEEPER VOLUME" pad on the keypad, then select 0–3 for mute to loud.
Your owner's manual is here.
Jan 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Need GE Spacemaker parts..
SEE http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 20, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Disassembly
Very good.
There should also be a very helpful "mini-manual" hidden inside the unit behind the control panel. It's very helpful when troubleshooting.
If you still need troubleshooting help. feel free to reply back top this discussion.
Jan 26, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave's timer counts down but doesn't turn on to warm food
The only motors would be the Magnetron fan cooler and turntable. Is there no heat at all?
Oct 07, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
152 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
