Question about General International Saws
Shuts off while cutting
While cutting a sheet of ply saw will shut off ?
Saw runs for awhile then shuts off and continues to run.
i always have to start the saw and then pull the trigger like every 5 seconds for about a minute then it works for me
Sep 18, 2013 | Stihl Concrete Cutoff Saw Carburetor Ts...
Ryobi rbs3080 motor stops when using
Try to install new blades. I've used 201 Haltbar blades in cutting pine before. Please get the right TPI too. But you may want to check the belt if it's slipping and try a slower feed rate.
Feb 27, 2013 | Ryobi Saws
Is this table saw safe for sheet metal cutting
No. A table saw IS NOT safe for sheet metal cutting. I have seen bar stock aluminum and copper cut on a table saw (at least 1/4 inch thick) but trying to cut thin sheet metal would be a bad idea. The two main problems are that the sheet metal is too flexible and the teeth are much larger than the material is thick.
Dec 19, 2012 | Craftsman Sears Table Saw Manual Model...
Hi,my stihl ts 410 saw cuts out after about 10 minutes work,it restarts soon after then cuts out after about 10 minutes again? any ideas,thanks dave
Sounds like an overheating problem.
Are you working in a well-ventilated area or in direct sunlight?
Check, if you can, the temperature of the motor case.
You might have to take a break more often.
This hot summer has stressed a lot of motors and electronics.
When it shuts off you know it is trying to save itself from burnout.
Aug 29, 2011 | Stihl Ts 410 420 Cut Off Saw...
8amp Super Saws all-shuts off after a minute of use-no power
It's probably tripping the thermal overload. You may try blowing it out good, might be full of saw dust if your cutting lots of wood.
Jul 12, 2009 | Milwaukee Tool 10 Amp Sawzall Plus with...
Idle is off??
hi leobowdy
disassembly the carb and carefully clean it.Check the air filter,the fuel line and fuel filter,check the needle,lever,small spring and the screen filter from the carb.Check the sparkplug.
high speed H=2 turns,low speed L=2 1/2 turns,adjust T
When chain saw starts adjust H,L and T accordingly.
cheers savumihai71.
Nov 22, 2008 | Ryobi Factory Reconditioned 18" 40cc...
Shuts off
hi Icestorm
check the piston rings,the seals .the cilinder and the gaskets.Clean the air filter
yours savumihai71
Jan 05, 2008 | Remington Polesaw Wizard
Saws Logo
32 people viewed this question
Top General International Saws Experts
Tom Chichester
ray gallant
Are you a General International Saw Expert? Answer questions, earn points and help others
