Question about Clarion DC625 6-Disc CD Changer
Unable to eject cd magizine. Error 2
Hi, recently brought a VT with this installed. When I open the CD stacker and hit the eject button, noise can be heard from inside it, but it fails to eject. Error 2 is displayed on the head unit. Any help would be great. Thanks, Justin
  • Justin Dun Jul 30, 2007
    Yep, I opened the stacker, ejected it by hand. I then took all the CD's out the magazine, put it back together and turned it on, after which I placed the empty magazine back in. Unfortunately it still would not eject the magazine by itself.
    At this point I'm playing to just tack it out and replace the head unit with an a new one with an inbuilt CD player.
  • Wendy McCauley Oct 21, 2011
    How do you eject by hand? The player sets tightly in the case.
  • 883 Answers
Power off. open the cd changer unit. look for the motor that, when turning, performs the eject mechanism. now turn this motor by hand in the proper direction until cassette is fully ejected.
Posted on Jul 23, 2007
  • Marty marty Jul 30, 2007
    I see you rated "almost there"...did the advice to spin motor work...did the cassette get ejected by hand?
Hi, this saturday i tried to change a cd from my honda civic copue 2006 stereo, but the cd didnt came out, it just made some noises and a message came up, mech error... please help!!! I push the eject...
If you gently push another cd in the cd player (not all the way but most of the way) it will either eject the cd or with your other hand hit the eject button and the other cd should come out. Mine did this but unfortunately it will not load cd's now so I don't if that made it worse or if it was already going downhill :(
Aug 16, 2010 | 2006 Honda Civic Hybrid
Cd error message on head unit on alpine r990,this is connected to a sony cd changer,has been working fine suddenly packed up.Now when cd button pressed no indication on radio screen,boght another stacker...
Hi John, when you think about it, it could only be one of two things either the bus lead or the RCAlead as everything is in them leads to run the cd unit, So check that all leads are secure to see what happens.
Feb 05, 2010 | Alpine CDA-9885 CD Player
My cds won't play and they will not eject. I have an in-trunk cd changer.
If your radio works and you press mode .Does head unit recognize cd,s
It should display no cd,s cd error etc
The reason i ask this is to confirm that connection is ok to stacker
To eject PRESS AND HOLD eject button,insert credit card under cartridge,push fully in and move left/right untill eject
This will locate micro switch,so you can check discs
Jan 25, 2010 | 2004 Mitsubishi Endeavor
Cd player in ford expedition quit showing CD
If you can not eject cartridge
Press and HOLD eject button insert credit card or similar under cartridge.Push firmly in and move left to right untill it ejects,this will locate micro switch.
The fuse is located on the back of the stacker,this is ok because your head unit recognizes stacker.
Nov 14, 2009 | 2003 Ford Expedition
Ford au fairmont 6 stacker cd player wont give back cd's it tries to eject, now red light ion load button all the time and wont turn on.
I had this problem...ignored it for a year then decided to have it fixed. No-one could fix it where I lived so before I went out and bought a replacement, I removed the top panel on the player (the one over the cd stacker) and had a look myself. There were 2 round discs loose in the player that I guessed were supposed to be attached to the 'arm' that takes the cd and spins it to make it play. I put them back on the 'pin' on the arm - the white disc first then the silver and black one on top and its playing again. I dont know how long for...it does tend to skip sometimes though. Better than nothing at all - and at least now I have a radio too. I'm just a girl who guessed were the parts went however....but maybe the parts inside have atendency to get loose and fall off? Good Luck.
Oct 22, 2009 | Pioneer Car Audio & Video
The CD ROM Drive is not ejecting properly
hi,
Locking device / software installed
First, verify no locking software is being loaded, which would allow the CD-ROM tray not to open. If you are unable to determine this, reboot the computer and as it is booting up, attempt to eject the tray. No power to computer or CD-ROM drive
If you have recently installed a new CD-ROM drive or you have moved the computer, it is possible that the power to the CD-ROM may have become loose or disconnected. Check the cable connections. Bad eject button
If you are running Microsoft Windows 95, Windows 98, Windows NT 4.0, Windows 2000, Windows ME, or Windows XP, open My computer, right-click on the CD-ROM drive and choose the option to eject. If this ejects your CD-ROM drive tray, it is likely that the button on the CD-ROM drive has become defective and it is recommended that the drive be replaced. CD stuck within drive
It is possible that a CD may have become stuck within the CD-ROM drive. If the CD-ROM drive has a small hole (that is not the head phone jack), using a paper clip, place the paper clip within the hole and attempt to manually eject the CD-ROM tray. If the CD-ROM drive is only partially able to be opened, attempt to pull the tray gently to see if it can be manually ejected. If it cannot be opened any further, it is likely that the gears within the CD-ROM drive have become bad, dislodged, or that a CD is positioned in the drive, which does not allow it to open. Incompatibility with IDE / ATAPI interface
If you have an IBM compatible computer and recently installed the CD-ROM drive and are unable to open the drive, attempt to temporarily disconnect the IDE cable to verify that you not experiencing an issue with an incompatibility between the CD-ROM and motherboard. Once the IDE cable has been disconnected, power on the computer and see if the CD-ROM drive tray is now able to be opened. If the drive is able to be opened with the IDE / ATAPI cable disconnected, it is recommended you use the interface card supplied with the CD-ROM drive or the ATAPI interface on the sound card / motherboard. Bad drive
Unfortunately, if after following the above recommendations you are still unable to properly open the CD-ROM drive using the button on the front of the CD-ROM drive, it is likely defective and should be replaced. Caution: If you are able to open the CD-ROM drive using a paper clip. We do not recommend that you continue using the CD-ROM drive by manually ejecting the CD-ROM using a paper clip. The drive should be replaced and this is not meant to be used as a temporary solution. Additional information and tips for buying a new CD-ROM drive can be found on our CD-ROM buying tips section.
Jul 02, 2009 | Computers & Internet
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds.
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 21, 2009 | iLO CA3000V CD Player
CD ERROR DISPLAYS
CD Changers
E01:
E02:
E04:
upside down
WAIT:
Jun 14, 2009 | iLO CA3000V CD Player
Error 99 displayed on cd player. CD player is a Denon DCH-520.
Normally you just hold down the eject button on your stock head unit and it resets the mico computer
Dec 12, 2007 | Denon Audio Players & Recorders
CD driver stuck
In the front side of the dvd drive you will see a small hole ...so to eject that cd put one niddle in that hole and .
Now press the button at just after that apply a force on niddle .suddenly you will notice that cd will come outside ,if not try more times and you will learn to eject the cd when you are unable to do it by pressing the eject button...
Low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not.
Thanks
Dilip Bagdi
Technical Associate
Dec 06, 2007 | Dell INSPIRON 6000 CENTRINO...
Clarion DC625 6-Disc CD Changer Logo
942 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
