Question about Averatec 3200 Notebook
Deleted software I mistakingly removed the Phoenix firstware 2004 recovery pro from my notebook. Is there any thing i can do? My laptop shuts down after a couple of minutes because it.
  • 537 Answers
Contact Averatec to get another copy of the recovery software.
Posted on Feb 20, 2009
How can i reset a toshiba satellite pro m15 s405
Most Toshiba laptops with come with the factory software recovery image stored in a special hidden partition on the hard drive of the laptop. The factory software recovery image allows the user to recover the laptop to its factory fresh condition as when it was new.
This partition may also be referred to as the Partitioned Recovery Method or Free Recovery option.
IMPORTANT: The recovery process deletes information stored on the internal storage drive. Be sure to save your work to external media before executing the recovery.
  1. Make sure the computer is turned off ("Shut-down" from the Windows Start menu)
  2. Remove any peripherals such an external mouse, keyboard, monitor, USB flash drive etc.
  3. Make sure the AC Adapter is plugged in and working.
  4. On machines with the F key numbers on the top edge of the keys and in White:
    • Press and hold the 0 (zero) key and power up the laptop.
    • Release the 0 (zero) key when the recovery warning screen appears.
    On machines with the F key numbers on the bottom edge of the keys and in Gray:
    • Power up the laptop.
    • When the initial TOSHIBA screen displays, press the F12 key to enter the boot menu.
    • Use the arrow keys to select the HDD Recovery option and press the enter key to begin.
  5. The TOSHIBA recovery wizard warning screen appears stating that when the recovery is executed all data will be deleted and the original factory software image will be rewritten. If the recovery process offers a choice of Operating Systems, select the appropriate one for you.
  6. After you are sure you have everything you want from the laptop saved, click Yes.
  7. When the Toshiba Recovery Wizard opens, the default and recommended option is "Recovery of Factory Default Software".
  8. After selecting your desired recovery method, select Next.
  9. On the next screen you may have recovery method options. The default and recommended method is to Recover to Out of Box state.
  10. Select next to continue.
  11. Follow the on screen instructions as you navigate through the system recovery steps.
  12. The laptop will restart multiple times and install the needed components.
Nov 25, 2014 | Toshiba Satellite Pro M15-S405 Notebook
Tip
Share hidden division of rapid delete
Several ways of rapid delete hidden division
We install the system, may encounter this problem computer can install Vista or install version of Windows xp, a Ghost installation of xp not contain is constantly to restart. The cause of the fault is that a series of PinPaiJi cabin hidden division. Sometimes the technical personnel to help us system, also can be in a hard disk, and you will see division, also not afraid you miss delete their recovery operation convenience. How to delete the hidden division, I collected many operation method, are as follows:
1, delete the ordinary hidden recovery
Disk management, drawing on disk partition in hidden division, right click delete disk partition ".
2 the notebook, delete Lenovo 42T3403 Laptop Keyboard LEOS
The new generation of LENOVO laptop, called "using a key LEOS" hard to restore technical data backup, restore, this function is integrated in the BIOS by a program and WINGDOWS one under the interface of software interaction, namely on disk to establish a division of division, the implication of the backup, (which is also usually say the disk C), in order to destroy a key file system, ordinary operation of the C can modify the area before 5G) to (approximately delete it, actually not difficult, first appeared in LENOVO reboot your computer, interface into the corner by the keyboard "resume/custom" button will appear a key recovery of concise interface, here only two options, one is the system restore, another is the software and drive, then click "order", and the Shift + B input password "LENOVO" will appear a key recovery in the interface standard interface, select uninstall backup. If the above methods cannot be solved, can use to start running under the Dos, CD LEOS management software. LEOSTOOL/DB, typing, then turn backup LEOSTOOL/DLEOS "type" can put lenovo backup system deleted.
3 and delete IBM Thinkpad G41 Laptop Keyboard HPA's
Currently the notebook HPA mostly by Phoenix First EareRecover - established in software, software component to delete, for a series of notebook, ThinkPad Recovery of Recovery CD directory is the component -- Fwdelete, want to delete HPA, must First in the BIOS setting, enter the BIOS ThinkPad notebook, select "Security -- Predesktop Area" will "Access" to "PredesktopArea IBM Disable". Then use CD to DOS, in Fwdelete input "DOS interface DRV = 0all" and enter, can be deleted, HPA stubborn zoning after you can use all the hard disk space.
4, delete the notebook HPA associations
Some of the Dell Inspiron 1501 Laptop Keyboard notebook to associate the hidden division by lenovo Hddfunc tools HPATool/unloading unloading, Hddfunc use simpler, with CD to DOS mode, and then run in the DOS commands "Hddfunc/d" can be hidden disk backups unloading, for Hddfunc not delete HPA zoning, need to use HPATool, under HPATool type "in the DOS CLR", can/could have removed the module record.
on Aug 09, 2010 | Computers & Internet
Tip
How to Recover Deleted Files Have you accidentally deleted your files from...
Have you accidentally deleted your files from the Hard disk? Do you desperately want to recover them back? Well you need not panic! It is possible to recover the deleted files back from your hard disk (even after you have Shift+Deleted) provided you act as soon as you realize that your files are deleted and use the best deleted files recovery software. In this post you will find a detailed information on how to recover the deleted files from your Windows PC or Mac. Today there exists hundreds of data recovery tools and softwares on the market which boast to recover 100% of all the deleted files back in the original condition. But in reality most of these softwares are neither effective nor capable of recovering your files back. So it is very much necessary to make the right choice of the file recovery software in order to recover deleted files back in the original condition. We recommend the following softwares to recover the deleted files
1. Stellar Phoenix Data Recovery (for Windows)
2. Stellar Phoenix Mac Data Recovery (for Mac)
Stellar Phoenix is one of the best company specializing in deleted files recovery services and solutions since 1993. Stellar’s Data Recovery Solutions encompasses a wide range of software for almost any data loss situation ranging from accidental formats to virus attacks to software malfunctions. Hence Stellar provides the best tools to recover deleted files with over 1,000,000 satisfied customers across 137 countries.
How the File Deletion Process Works?
When you delete a file from your computer (or even from the recycle bin) the file is not actually deleted. Unlike what most people think, the file is not permanantly deleted or dropped from your hard disk. Let’s take an example of a book containing 50 pages. Suppose when you delete the page 25, assume that only the entry in the index which points to the page 25 is deleted and not actually the page 25 itself. Likewise when you delete a file from your hard disk, only the pointer which points to this file is removed and not actually the file itself. This file still exists intact and is 100% possible to recover it back in the original condition. In this condition the file becomes invisible and hence appears to have deleted.
What are the Chances of Recovering my Files Back?
Since the operating system doesn’t immediately re-use the space from the deleted files, it is most certainly possible to recover the deleted files back in 100% original condition. It may take up a very long time for those files to be completely deleted since the modern hard disks have ample capacity. Hence the chances are too less that the space from the deleted files are re-used immediately. So, it is really worth to try out the file recovery softwares like Stellar Data Recovery for Windows or Stellar Data Recover for Mac. Some files are reported to have recovered even after years of it’s deletion. However for the best results, it is recommended that you use the file recovery software as immediately as possible to recover your files.
Recovering the Deleted Files
In order to recover the deleted files all you need to do is perform a scan (search) for the deleted files using a File Recovery Software. Please be informed that there is no manual way to recover the deleted files. The Phoenix Data Recovery software performs a thorough scanning of the hard disk sector by sector and will locate the existence of deleted files to restore them back in the original condition. It is the only software that supports 185 popular file types including Windows NT Registry, JPEG, MP4, GIF, BMP and MS Word files. The software offers rich graphical support and incorporates advanced scanning methods to completely scan and recover deleted files from your hard drive. With this you can
  • Recover FAT16, FAT32, VFAT, NTFS, and NTFS5 file system partitions
  • Recover deleted emails
  • Recover deleted documents
  • Recover deleted photos
  • Recover deleted music
  • Formatted Hard-Drive recovery
  • Recover files from USB Drives, CDs, DVDs and memory cards
  • Recover almost all the camera format files
Visit the following links for more information on Stellar Data Recovery
free software to recover data
1:Recuva
2:Pc file recovery
please rate the artical
on Mar 30, 2010 | Computers & Internet
Recover deleted file?
Here is a list of best data recovery softwares that I have found:
1. uFlysoft
2. Recuva
3. Disk Drill
4. Glary Undelete
5. Panda Recovery
6. SoftPerfect File Recovery
7. EaseUs Data Recovery Software
Mar 21, 2014 | Olympus LS-10 Digital Voice Recorder
What should i do if recovery partitaion delet from my laptop
Try Active@ Partition Recovery. I've used their boot disc software before. It easy to use.
http://www.partition-recovery.com/
Oct 06, 2012 | Lenovo G580 Laptop
I pressed the NOVO button on my Lenovo Y510 by mistake while tryng to power on the laptop. All the data in my C: is now lost. Is there a way to recover this data?If yes, how?
hi,
Pressing the NOVO button removes all the data from C: drive and reinstall the OS image from the hidden partition.
To recover the data you will have to take the help of some third party recovery softwares as you can check on www.recovermyfiles.com
Jul 27, 2009 | Lenovo IdeaPad Y510 Notebook
Nothing but wall paper hp pavilion zd 8000
hi,
might be that the recovery partition is modifies so now recovery is possible through cd drive only.
Jun 02, 2009 | HP Pavilion zd8000 Notebook
To recover my deleted msword files
hi,
see the below site which clearly explains about the deleted files.
http://www.easeus.com/datarecoverywizard/recover-lost-word-files.htm
http://www.tech-pro.net/how-to-word-document-recovery.html
hope this website links are useful.
Apr 17, 2009 | Computers & Internet
Damaged adobe reader 8 damaged
if you get this error message when you try to open a particular file. the problem could probably be in the .pdf file and not the software. if this is not the case, uninstall adobe reader completely and reinstall it. if this docent work. download the latest version of adobe reader from the adobe site and try installing it again.
Jun 10, 2007 | Adobe FirstWare Recover Pro 2004...
Averatec 3200 Notebook Logo
46 people viewed this question
Top Averatec Computers & Internet Experts
Avishek Samaddar
Avishek Samaddar
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
