Harbor Breeze -Rosemont 2 13 watt GU24 #0057823
SOURCE: MAXIMUM WATTAGE FOR FAN LIGHTS??????
those bulbs are candelabra type. if they came with the fixture then I wouldn't go to a higher wattage bulb. the sockets are probably bakelite and mounted with the base up so any heat off the lamps would be directed upwards. higher wattage bulbs may shorten the lifespan of the sockets. bakelite is a modified plastic. it won't melt but it will get brittle.
SOURCE: light bulbs burn out
Use bulbs specifically designed for ceiling fans - they say "ceiling fan" on the package (Home Depot, Lowes both carry). The slightest regular vibration (like a fan rotating) causes normal incandescent elements to burn out within days or weeks.
If you wired black to black, white to white and green or bare to ground, you wired it right. Sometimes there are two blacks (hots) one for the light and one for the fan, but most of the time you hook the light wiring parallel to the fan wiring unless you install a remote switch.
SOURCE: How do i remove the light to change a light bulb?
i looked it up online and they called it a:
Single Bowl Twist and Lock Light Kit.
Some things i would suggest:
please comment my solution :) thanks
SOURCE: I am having trouble removing the glass cover on my
Try pulling down on it. There are some clips that will release it. It's not screwed on.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: I need to find a light kit for a harbor breeze
You should be able to pick these up at Lowes if I'm not mistaken. I just bought a Harbor Breeze ceiling fan from there and saw the light kits around the same area. I also believe that, you dont necessarily have to get a Harbor Breeze light kit and that some are interchangeable.Hope this helps some.
