Question about Oster Health & Beauty
Oster 78970-100 clippers-
Putting on blades
wormosa1
  • 4 Answers
SOURCE: blade installation
i had the same problem and i fixed mine ( it is not broken) ... the tongue is the thing that is silver and has grooves that face upward, the tongue should be up compared to pressed against the shave, take a small screw driver or a kitchen knife and get under the tongue and lift it up, once this is done you need to slide it on the blades and snap it down, i found that i did not need to have the clippers on to put it back on.... at first i got confused in thinking that the tongue was the red thing at the top, and in actuality this is the thing that moves the blades to clip.... i hope this helps, once you get the tongue up the blades are on in 10 seconds...
Posted on Aug 14, 2008
  • 5 Answers
SOURCE: how to sharpen oster clipper
In order to sharpen these blades you must first dis-assemble them (paying particular attention to the way everything fits together), Next you need to get a piece of glass or something as flat as possible and tape a sheet of 180 grit emery paper with the rough side up. Then you put the upper blade on the emery paper wih the flat side down and stroke it back and forth in a straight line at least 100 strokes each way. Turn the blade over and examine the surface with a magnifying lens to see if you have honed the blade flat all the way across. Next turn the blade 90 degrees and again stroke the blade back and forth in a straight line. Turn the blade over and examine again to see if you have removed all the first series of strokes and the new set is flat from edge to edge. If so then put that blade aside and do the same thing to the lower blade until it is flat across and up and down. After reaching this stage you need to remove the 180 grit paper and go up to 230 grit paper and repeat the whole process. After completing the second stage you progress to 400 grit paper and repeat once again..
Make sure you keep the blades straight so the hone marks are up and down and from side to side and you should have an almost razor sharp cutting tool. Also DO NOT USE SAND PAPER only emery paper or cloth. I know this sounds like a lot of work but after you've done it a couple of times you can whip out a blade in about 20 minutes.
Posted on Oct 01, 2008
SOURCE: NEED PARTS FOR OLDER OSTER CLIPPERS
I gave it a shot and it worked!!!....
No need to bother with the universal guards. They looked bulky for the task, and after careful (visible scrutiny) decided to gamble on the "fast feed clipper" guides. Check them out here:
http://www.cache-beauty.com/oster0541.html
There are surely other people who sell them - you might shop around, but I bought from these guys. Warning, the shipping price is kinda steep. But like I said in my last post, I've tried other clippers and these are just the best. It was worth it to me.
Anyway, I am now confirming that these guards fit this old clipper brand of ours. Perfectly!
Posted on Feb 03, 2009
SOURCE: pet hair clippers blades move but dont cut.
Do not use regular oil on the clippers.
Instead use OSTER KOOL-LUBE.
We were told the blades become to hot with regular lubricating oil such as 3 & 1.
We bought some KOOL-LUBE from our neighborhood PetsMart and it corrected the problem on both sets of our clippers (one heavy duty clipper for dogs, one regular clipper for humans).
Here is a link to KOOL-LUBE on the PetsMart web site:
http://www.petsmart.com/product/index.jsp?productId=2752831&utm_source=googleproduct&utm_campaign=2011235&utm_medium=cse&mr:trackingCode=A9C8D151-4519-DE11-B0EA-001422107090&mr:referralID=NA
Jan
Posted on Jul 25, 2009
philschneide
  • 448 Answers
SOURCE: Bought Oster Golden A5 clippers new but did not
There is a small gun-metal colored bar at the very rear, just below the back of the blade. It pushes inward, in the direction of the blade. Push it firmly in and pull up on the teeth of the blade. It should pop upward. You can then remove the blade from the tongue that it sits upon. When you want to put it back, slide the blade back on the tongue, then, WITH THE MOTOR TURNED ON, push the blade down to its seated position. It will click into place.
Terms regarding these devices are all too often assumed as understood. For most purposes, these are what you have to know for the A5 Oster. The cover plate is the part with two screws that has the name and other info on it. If you remove the two screws and the plate, you will see a nylon part that moves the blade back and forth--that is the lever. The other end of the lever, with a hole in it, is connected to a metal part called the link. Both parts are easily removed by simply pulling them upward from the device. The bakelite gear is the part that the link sits on (the larger hole in the link). It too can be simply pulled up off the metal shaft that it rides upon (careful not to lose the washer under it). That gear is turned by the armature gear of the motor (which is where things get much too involved to cover here, but from that point on the device very rarely has problems). Incidentally, the lever, the link, and the gear can all quite simply be replaced. They are available quite inexpensively at Amazon under Oster A5 Clipper parts (note that the one speed and the two speed take different bakelite gears, but the lever and the link are the same). If you were to replace parts such as these or simply lubricate them, remember that a good white lithium grease is recommended in light application for the gear and the shafts (lever and gear shafts and armature gear). Also, the gear shaft has a hole down its middle (and two small holes that lead to the outside of the shaft. The shaft should be filled with grease so that grease can get through those small holes to lubicate the inside of the bakelite bearing. The two pads (one on each side of the lever) should be oiled. The simple way to tell if you need to replace parts is to grip the blade end of the lever while all parts are in place and try to move it back and forth, as though it were running the blade. If there is any more than the slightest movement, replace the lever (replace that anyway if the part that contacts the blade is rounded off) link and gear.
Good luck.
Posted on Oct 03, 2009
Oster blade no. 913-50
http://www.ebay.com/itm/Oster-Blade-Set-913-50-Fits-Fast-Feed-17-tooth-76913-506-New-/130803957423
Mar 09, 2014 | Oster Corporation Pet Oster Performance...
Oster Blade 918-306 Size Texturing Fits Oster Classic 76 Clipper, Power Pro, Power-teq And Star-te: Oster class 76 clippers....had them for a week and...
70ca16d.jpg Hope this helps, this is a tongue guide, you hopefully recognise it on your blade. If they are not paralell, then adjust them with pliers, both need to be perfectly vertical. When you put it on the clippers push the latch in as you close the hinge.
If it still wobbles then the next fe wthings need checking
1. The hinge screws on the clipper are tight, located either side of the hinge on the clipper.
2. The drive lever may be worn, thats the maroon peice of plastic sticking up at the top of the clippers, it moves from side to side when clippers are running.
3. If all seems fine up to now, your clipper should be fixed under warranty as it will involve changing parts covered by the warranty.
www.sheareaseltd.com
May 17, 2010 | Sunbeam Oster Blade 918-306 Size Texturing...
Blades fell off oster dog clippers but can't fit them back on. Please help !!
With the hinge of the clipper facing you:
Make sure hinge is open, if it is not, prize it open with a flat head screwdriver.
Slide the blade on with the blade siz/number faceing you.
Snap shut.
If this fails, try again, but push the latch in as you snap them shut.
If this fails, you may need repair!
May 15, 2010 | Oster Golden A5 2-Speed Universal Motor...
Oster A5 clippers blades stop moving when put into the horses hair. checked without the blades, everything moves fine. Put new blades on, cleaned the silicone off with blade washed and have lubricated with...
How old is your clipper, Oster clippers need to be adjusted for more power and speed, also what clipper blade are you using to cut the horse hair and how long is the horse hair, Also the blade may not be sharp, some new blade are sharp maybe defective.
Feb 25, 2010 | Oster Golden A5 2-Speed Universal Motor...
Run but will not cut
Are you sure you have Andis A5 or did you mean Oster A5 Clipper, if this clipper is A5 Clipper, You need to check the Lever for wear, The front of the Lever show wear on both side, Like white color and is not squad this Lever is worn. Need to replace. This Lever moves the blade side to side fully. if the Lever is worn the blade will not move fully side to side and the cutter blade the smaller blade will stay in the middle with hardly no travel to side to side and will not cut the hair even if you purchase new blades. Also I would like to mention if the Oster Locking Hinge is worn out and don't have the require tension to hold the blade in place the blade will not cut. How do you test the Oster Hinge on a Oster A5 Clipper,
(1) first close the hinge, in close potion with your finger nail try to open the Hinge, if the hinge slightly open or opens loose the Hinge is worn. if the Hinge is good it will not open or move and your nail may just brake your nail.
Many of my customers run into this type of problem, and the problem can be solve easily by checking these parts first.
One more item I would mention here if replace the A5 Hinge make sure you get the A5 Hinge not the Oster 76 Hinge they are driferrent, The A5 Hinge has on the back two wire's sticking out that fit on the Oster Latch for the A5 Hinge, the Oster 76 Hinge would not have these wire's on the back. I recommend replacing the Latch when you replace the Hinge. I hope this helps any body that have a A5 Oster clipper or A Oster 76 Clipper.
I have over 20 years in the repair business of Sharpening & Clipper repair. Mannys Sharpening 323 263-4697
b61c252.jpgOster Hinge
Jun 10, 2009 | Andis Outliner II Hair Trimmer
Newbie Clipper needing advice
This is from the Oster book:
Changing Blades
To Remove: IMPORTANT- stop motor; push latch with thumb while lifting blade away from clipper and slide off tongue.
To Replace: turn motor on; insert blade on tongue fully and then snap blade into place.
Note: if the hinge is flush against clipper, lift it up with a screwdriver.
From me - Never take your blades apart to clean them. You can slide them one side to the other to get the hair out. (One little hair, can stop them from cutting.) You need to buy a can of clipper blade cool from oster or andis both are good, and it really helps to lubricate the blade and keep them cool while clipping. If you live near a dog groomer, petsmart or something of the like. Ask them to show you how to remove the blade and I know they will be happy to show you. I tried to submit an image from the book, but I don't know if it will get here or not.
Mar 31, 2009 | Oster Golden A5 2-Speed Universal Motor...
Oster clipper blades get red hot and won't cut.
see this link, its for the A5. The A5 is the animal version of the 76.
http://www.peasridge.co.uk/clipper-advice/clippers-products-oster-a5.shtml
I dont know what model you have, but if you need schematics for YOUR model see this link.
http://www.clipperrepair.com/parts.htm?brand=8
Jan 10, 2009 | Oster 76076-010 Hair Trimmer
Health & Beauty Logo
194 people viewed this question
Top Oster Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Chuck
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
