Ht-4503 remote control - Audio Players & Recorders
Samsung HT-P38 remote will only turn TV on and off won't control the stereo receiver, why?
If stereo recieiver is part of your Samsung HT-P38, remote should have a function to contole it. Check user's manual
Samsung HT P38 Instruction Manual
If you are following correct steps for use of your remote and still can't manage your stereo receiver, probably something is not working correctly., most probably your remote. Maybe you could get it checked with an authorized SAMSUNG repair service
Jul 14, 2014 | Samsung TV Remote Control
Insignia Remote Code Needed for Samsung HT-X40
Many remote control codes can be found at InsigniaProducts.com. Search for your Insignia product model number and click on the Support tab.
Dec 27, 2009 | Samsung HT-X40 System
Samsung HT-A100 Home Cinema system plays cd only with tv on!
You need to put away the remote for your TV and use only the remote for your HT system. Your HT remote should work on your TV by default. Your Samsung HT remote should have a TV button and a DVD/Receiver button (or HT button). When using only the TV, press the TV button and then use it for just the TV and when using the HT system, press the DVD/Receiver button and then you can use the HT system.
If for some reason your TV is not set on the Samsung HT remote by default, your HT users manual should have a list of codes that you can use to program your HT remote. Hope that helps you. Gary
Mar 18, 2009 | Samsung HT-A100T Theater System
Region Codes
1. Disconnect your player from its power source for thirty seconds
2. Reconnect your player to its power source
3. Press the Power On button on your remote control
4. Press the Enter button on your remote control
5. Press the 8 button on your remote control
6. Press the 4 button on your remote control
7. Press the 2 button on your remote control
8. Press the 6 button on your remote control
9. Press the 9 button on your remote control
10. Press the Enter button on your remote control
11. Your player should now place itself in Standby mode
12. Press the Power On button on your remote control
It should also work for HT-Z310T and HT-510T and its variantes...
Apr 12, 2008 | Samsung HT-Z310T Theater System
Samsung program codes for ht-q100 Remote
You can try any of these 006, 011, 014, 015, 019, 027, 036, 037, 077
Hope this helps..
Nov 30, 2007 | Universal Remote Control Activity Based...
53 people viewed this question
 Grubhead
Grubhead
