Kensiko dual scrolling mouse manual - Computers & Internet
Mousepad scroll unlock button
restart your computer
or go into control panel the find mouse and settings,your pad might need replacement
May 08, 2015 | Gateway NE56R41u Dual Core B960 4GB 500GB...
How do i fix my scrollomg problems!
Wireless Keyboard-Mouse (890552559985) is not listed anywhere as an actual model number so it's hard to say what it even looks like.
Is it a "scroll wheel" in the middle of the mouse? Are you sure it's not the properties or configuration of the mouse in Windows Control Panel?
If you can take a mouse apart, rubbing alcohol on a Q-tip rubbed on sensors as well as a wheel could help.
Feb 08, 2015 | HEWLETT-PACKARD Hewlett Packard Compaq...
Put batteries into Targus amw1603eu mouse
The battery cover is the part of the top of the mouse on the opposite end from the scroll wheel. Turn the mouse upside down with the scroll wheel away from you. On the end closer to you is a latch (called a "hinge" in the user manual) for the battery cover. Depress the latch and slide the battery cover off of the end.
The user manual is at
TARGUS AMW1603EU User Manual
Dec 28, 2010 | Targus AMW05US Mouse
Scroll pad not working on hp laptop mouse still works though
Need to enable Scroll function on the notebook.
Scrolling function is not working:
  1. The scroll function may stop working if the scrolling feature is disabled in Mouse Properties. To enable the scroll function, follow the steps below.
  1. Click Start , Control Panel . Select Classic View from the left side of the Control Panel window.
  1. Double-click Mouse in Control Panel, and then select the Device Settings tab in the Mouse Properties window.
  1. Click Settings , Virtual Scrolling . Select the boxes labeled Enable vertical scrolling and Enable horizontal scrolling .
  1. Click OK to save and exit the Mouse Properties window.
  1. After changing these settings, the scroll function on the touchpad will be enabled.
Jul 24, 2010 | HP Pavilion dv5000t Notebook
Scroll speed goes to fast.
  • Try "uninstalling the "Mouse, next (Rollback Driver), and restart the computer. Reinstall the "mouse device" "update drivers: automatically, or "manually." *Note: "The Manual (option) will reinstall the original drivers. "Did this solution help? "Helpful Rating Feedback" appreciated, thank paul7of9"
Feb 06, 2010 | Logitech Cordless Mouse
Need Mouse Driver for Mac Leopard
Without the drivers the mouse runs great. The only thing you can't do is use the second scroll wheel to scroll left and right. Instead the mouse scrolls in the opposite direction than the first scroll wheel. The side buttons can be configured within OSX and Windows for whatever you might want.
Aug 21, 2009 | GE 97985 Mouse
Don't have scroll lock on wireless keyboard/mouse combo, what other hot keys can i use?
You can try CTRL CTRL instead of scroll-lock. it was working for me. It is not mentioned in the manual.
Mar 10, 2009 | Belkin F1DK102P 2-port KVM Switch
Scroller goes up when scrolling down
This works for all mice.
click the scroll button and movie it up and down for a while and it will work just fine.
i had the same problem with my acer mouse but when i looked at a forum for the mac os x mouse someone said this tip and it worked
Oct 27, 2008 | Dell U0636 Mouse
Erratic mouse
did you uninstall old drivers first
also check for virus some viruses stuff up mouse operation
Jul 24, 2008 | Logitech Cordless Mouse
Driver
you don't need a driver. to switch pc, use keystrokes below.
' Scroll Lock / Scroll Lock / 1 or 2'
'1 or 2' being the pc location on the switch.
hope this helps.
Mar 04, 2008 | KTC IntelliView KC102P (DSKTCKC102PS2)...
Computers & Internet Logo
David Payne
David Payne
