Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage door opening/closing problem
I have a craftsman 1/2 hp garage door opener.My hand held remotes / keyless entry pad work infrequently.Sometimes they open / shut garage door and mostly they dont function.
Could you please help .Thanks
  • Joseph Chapman
    Joseph Chapman May 11, 2010
    If you put the remote 2" from the antena do the remotes work?
  • Vince Heuser May 11, 2010
    Do they work with the door up and rarly when the door is down and you are outside?
  • 504 Answers
Could be a bad wall button or a smashed wire.
Anytime a door opens and/or closes by itself, or remotes work intermitantly I look for a smashed wire between the motor unit and the wall button or a bad wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door or interfere with the remote.
Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone’s purse that gets the button pushed by other stuff in the purse.
The test is to disconnect the push button wires at the power unit. If the self operation / interference stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button.
HOPE THIS HELPS
Posted on May 29, 2010
I have a Craftsman Keyless entry model 132B2386-6 with flashing lights, wont open. Already put in new battery still doesn't work
Why would my Keyless Entry close but not open the garage ...
www.shopyourway.com > Manage My Life > Questions
Mar 27, 2008 - I have a Craftsman Security+ Keyless Entry, P/N 139.53684 purchased with my ... However, the door will not open, but the keypad flashes as before. ... Check if there is a flashing green light on your wall control in the garage. ... The 2 remotegarage door openers won't open or close the garage door; but the ...
Craftsman garage door opener won't open or close, why ...
Hi, I have a Craftsman 1/2 HP garage door with keyless entry (P/N ... When I click theremote or the wired button, the main lights come on, the motor moves ... Five flashes means that the RPM sensors has most likely stop communicating.
LiftMaster - Support - Videos ' LiftMaster
https://www.liftmaster.com/Customer-Support/Videos
Chamberlain GroupHow to program a wireless keyless entry using your garage door opener's LEARN button. How to ... Why the LED or light on the door control is blinking and my remotecontrol is not working? Why isn't ... Why won't my door fully open? How to ...
Feb 08, 2016 | Building Materials
Craftsman 3/4 hp garage door opener
not sure, but see the users manual here:
http://www.manualslib.com/manual/32293/Craftsman-139-5399.html
Aug 14, 2012 | Craftsman 3/4 Hp Garage Door Opener System...
Which Keyless Entry Pad should I purchase for the Craftsman 1/2 HP garage door opener model # 53920 ?
The only models I can find that are close to yours are 53920D and 53920DM which are fairly new. They both call for keypad model 53754.
Sep 02, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a Craftsman 139.48847 1/2 Hp garage door opener. I can get either the remotes to or the keyless entry pad to work but not at the same time, Any suggestions?
If you have more than one remote and they all work but when you try to program the keypad it causes the remotes to quit working then your keypad is bad.
Nov 21, 2010 | Sears Craftsman LiftMaster Chamberlain...
Ladies / Gentlemen: I have a Craftsman 139.53975SRT1 Garage Door Opener. What is the correct keyless entry pad for this opener? Will a 139.53876 keyless entry pad work with this opener? Thank You! ...
The correct keypad for your opener is 139.53684. The 53876 keypad is an older technology and will not work correctly. If you program it you will find your remotes no longer work and if you reprogram your remotes the keypad will not work.
Sep 08, 2010 | Sears Craftsman LiftMaster Chamberlain...
Remotes don't work, keyless entry won't work, wall remote some
Check to make sure the door sensors are pointed at one another and the small light on each one is lit and not flickering. If you cannot get both lights to come on then your sensors have failed.
Jul 13, 2010 | Sears Craftsman LiftMaster Chamberlain...
Trouble with programing garage remotes and keyless entry pad
Either the keypad is the wrong model for your opener or it has reverted to an earlier technology and needs to be replaced. It is important that you get the model number off your motor unit so you can be sure you get the right keypad for your opener.
Oct 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Reset Craftsman keyless entry pad.
What you are asking for is not possible. You need to call a garage door repair technician. They will drill a hole through the door and using a special tool can pull the rope to release the door.
Sep 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Antenna/distance
The receiver which is part of the logic board is going bad.
Jul 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
376 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
