Question about Bosch Classixx WFC 2465 Front Load Washer
Noisy spin dryer
My Bosch front load washing machine seems very noisy with a knocking sound when it picks up speed on spin dry is this normal for the model
  • Anonymous Mar 12, 2014
    would like to know how to remove the lid from the machine model no. wml540 to access thedrum
Make sure the washer is level.there's locking nut for each legs sometimes thy become loose and the unit becomes unlevelled after a while. Level the unit side to side and front to back and relock the nuts by tightning it against the bottom frame. If thats not the problem,run it on spin only with no load and see if it would do the same if it does'nt then your problem could just be improper loading. make sure you have enough load to cover the drum when it spins.Other wise you may have shock/spring problem but very unlikely
Posted on Jul 22, 2007
Bosch classixx wvf 2402 at the end of the dry spinning cycle, 5-6 minutes the machine makes a terrible noise. What could this be?
Can you describe the noise? Is everything else working normally? From what you are saying, my guess at this point would be that the pulley on the motor is working loose.
Jun 13, 2014 | Bosch Classixx WVF 2402 Front Load...
Bosch washing machine spins but not dry enough when spun as if it is on 800 not 1400
This seems to be a common problem for Bosch WF02862. If the end result is not dry enough for you, you can try running an extra spin cycle. You can also try checking the machine if you can tweak its spin speed. Modern washers such as this model tend to have different spin levels.
Source: http://www.washingmachineadvisor.com
Mar 25, 2011 | Bosch WFO2862 Front Load
My bosch front loading washer on the small cycles will not spin the water out of the clothes..why?
Does it sound like the machine is spinning as fast as on longer cycles?Some machines run a slower spin speed on small cycles which can leave clothes wetter than normal. I've got this on mine and all I do is when the wash has finished I change over to the fast spin only program which then takes it to it's highest spin speed.
Jan 25, 2010 | Bosch Washing Machines
Clothes still wet aftre drying cycle over
It sounds as if the wash cycle isn't terminated by pumping the rinse water out and spinning to rid the clothing of most of the water.
Most dryers sense moisture but I think they all will have a maximum run-time to prevent possible fires if the programmer fails to shut them down at the end of the drying cycle.
I would watch the machine and when it started the drying cycle, I would shut it off and check for surplus water that hadn't been pumped out as it should have been.
Feb 03, 2009 | Bosch Logixx WFT 2806 Front Load...
Clothes come out extremly wrinkled on top loding whirlpool washer
This is normal. You can try a lower spin setting or smaller loads. The wrinkles will come out in your dryer.
Jan 19, 2009 | Whirlpool LSR5132PQ Top Load Washer
Washing machine noisey on final spin
this isn't a problem usually every washing machine is very noisy on a final dry its normal
Oct 15, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
My Bosch Nexxt Essence front load washer is making a knocking and squeaking noise during the whole spin cycle. It sounds like it's coming from the drum mounts - what should we do?
My Bosch Nexxt Essence front load washer will not drain. I changed the lint filter, and insured that the drainage hose was free of debris. I removed all the wet clothes, wrung out the excess water, and redistributed the clothes. Still, no draining or spinning. Initially there was a humming sound, but now there is no sound at all when I try to restart the drain or spin cycles. All the lights are appropriately "on".
Apr 13, 2008 | Bosch Washing Machines
Bosch Classixx WFC 2465 Front Load Washer Logo
179 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
