Question about Desa International ALL-PRO® SPC-85 Utility Heater
I have a dyna-pro T120 heater. the igniter does't work
I can't find parts for dyna-pro heaters
  • 193 Answers
Call 1-800-654-8534
Posted on Sep 29, 2009
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Jan 12, 2016 | Heating & Cooling
WE HAVE A 170-210 KEROSENE HEATER DYNA-GLO PRO IT IGNITES FOR 10-15 SECONDS THEN CUTS OUT,CAN YOU HELP
That sounds like a bad photocell or a dirty photocell....check the photocell and clean it firt and then replace if neccesary...
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Jan 27, 2011 | Heating & Cooling
HEATER WILL NOT STAY IGNITED WHEN START SWITCH IS RELEASED
ayama794,
I have a tip at http://www.fixya.com/support/r4258201-fix_gas_reddy_heaters_will_not_continue which should help solve your problem. It is written for a reddy heater but reddy heat, all pro and dyna glo are all the same units.
Thanks for using FixYa and for the great rating.
hardrocko
Dec 26, 2010 | All-Pro SPC-85 Utility Heater
Dyna glo pro model #rmc kfa 125tdgp flashing code e1
I have same heater and problem-1) Check fuel inlet screens at bottom of hose in tank 2) Check air filters at fan module opposite end of the fan blade 3)Check for spark in ignition chamber 4) Check for fuel flow in ignition chamber (look at pressure gauge at opposite end from air exit) You'll have to remove the top cover to do these checks. The side covers will hang on each side ok. I hope these checks help you out.Good luck.
Jan 27, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
I have a Dyna Glo-pro multi fuel heater. When I turn it on the ingitor starts working and than the fan comes on for a few seconds. Then the system shuts down because it willnot ignite. The tank is full and...
Since it does not ignite, Please check the ignition transformer. This have a secondary voltage of about 20,000 to 25,000 volts, enough to make your igniter
spark, thus, causing the atomized fuel to ignite and burn the fuel. So, please include igniter high voltage cable for ground leak. Ground leak is visible as line sparks when your heater is switched on. If your ignition transformer does not produce sparks at the
igniter, it means it needs to be replaced.
Have it done to make it work. Hope this will help you.
Jan 10, 2010 | Dyna-Glo RMC-8001SS Heater
Filters for dyna-glo pro
You can make your own filters out of felt and I have also found that with some minor modifications most of the parts from Mr. Heater will work with Dyna Glo. I have a 170btu kerosene heater and just installed an ignition, a high limit control and a flame sensor from Mr. Heater and it works like new.
Nov 03, 2008 | Desa International ALL-PRO® SPC-85 Utility...
I have no manual and no clue
After not finding any help on the Internet, I went to Home Depot to see if they could help. I deduced through my own that the ignitor has failed. (symptom: Turn on the heater, no buzzing, no ignition, heater turns off, light blinks). It's the nifty little black box that has two white wired leading to the circuit board, and two thick black wires going to the spark plug. Of course, Home Depot doesn't carry parts.
They had one Dyna Pro heater on the shelf. My wife found a phone number on the box. We called it and sure enough, we found the company and was able to order the replacement ignitor over the phone. Total cost: $33.00 (Including shipping).
IS HELP OUT THERE. Here's the info:
GHP Group.
7500 Saint Louis, Skokie, IL 60076
1-877-447-4768
The replacement part is part number: 39E0002500
It fits models: RMC-KFA125TDGP, RMC-KFA170TDGP, and RMC-KFA70TDGP
Hope this helps.
Nov 20, 2007 | Heating & Cooling
Desa International ALL-PRO® SPC-85 Utility Heater Logo
169 people viewed this question
Top Desa International Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Gil Shultz
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
