Question about QuarkXPress
Linking text boxes in Quark XPress 8
I have attempted to use the linking tool to flow text from one box to another, but nothing happens (in older versions, I immediately got an arrow showing me the linking path).  When I go to the Help section on linking boxes, it tells me that I have to select two (or more) text boxes, but I have not found a way to "select" more than one box at a time.  Holding the shift key, which is what I did in previous versions, does not do anything.
  • Anonymous Apr 09, 2009
    I have the same problem. I select the two boxes with the item tool, then use the linking tool to try and get them to connect, but nothing happens. No linking.
  • 108 Answers
Just click on the very first box and then to another and it would work
Posted on Jun 16, 2009
I purchased Quark Xpress back in 1990 or so, and the installation discs were the old 3 1/4 discs. I paid for updaters, and at updater 6.1, I still have the Quark CD, but some of the original Quark Xpress...
I continue to be amazed that no body has found THE elegant solution I did. As a matter of fact I am using Quark 4.1 on Window 7, I used it on Vista (where it performed better than Vista) and on XP back at least to 98 or perhaps 95. My original install required burning a floppy (good luck with that today) for the registration. At some point, I discovered it was truly portable and simply copied the installed Quark directory to a new location (anywhere) on each new system. I dragged out a shortcut onto the desktop to the executable on every new platform. It still runs fine on this 64bit Window 7. Has not blown up yet. Something I wish I could say about other software. The only rub I found is that MS monkeyed about with associations (which worked fine in XP & Vista) and I have yet to be able to set.QXDs to Quark when I even set .QXTs to Quark.Windows 7 automatically served up In-Design as being the first (default) association in my programs list. Something I did not accept. I even tried to rewrite the registry in an attempt to make it work.
In fact, if you look into the .DLLs under Windows, you may find versions of the same .DLL that can run under 64, 32 and 16 bit environments. I suspect it will work under Windows 8 if MS doesn't leave working procedures ALONE!
May 20, 2011 | Quark Academic QuarkXPress 6.1 for PC
Linking text boxes
Step 1 - Locate the page where you want the text linking to begin. Select the Link tool (second from the bottom on the tool palette--it looks like a chain link).
Step 2 - Click on the box you want linked. The icon will change to look like the links of a chain. Click on the mouse; you will see a moving, broken (dashed) line around the text box.
Step 3 - Go to the text box that is going to be next in the link. Place the cursor in the box and click on it. You will know the boxes have been linked by the thick black line extending from the first of the linked boxes to the second. Continue to link boxes until you have come to the end of your text. Click onto another icon on the toolbar to leave the "link" feature.
Jan 28, 2011 | QuarkXPress
Error 1720. Trying to install Quark 6.1 on Windows 7
I definitively solved this problem. Follow these steps:
1) Install first Quark Xpress 6.1 on a Windows XP PC.
2) Copy the entire directory of installed files (Normally c:\program files\quark) on a pen drive.
3) Install Quark Xpress 6.1 on your Windows 7 PC until the installation stops with 1720 error.
4) Abort the installations, then copy the Quark directory stored on your pendrive in c:\programs x 86 directory overwriting the existing one.
This way Xpress 6.1 works perfectly on a Windows 7 PC. Guaranteed!
Sep 02, 2010 | QuarkXPress 6.1
In Quark 6.1. This soft. not working Telugu language Font. Why ?
Anu PS Fonts (telugu) in WIN XP SP2 (Telugu is the One of the most using Language in Andhra Pradesh, India) not working / not supporting for QuarkXPress 6, 7 and 8 versions? How use this?. Please send me details my mail alekhyadg@gmail.com.
Jul 27, 2010 | Quark Academic QuarkXPress 6.1 for PC
Open Quark 6.5 doc "freezes" when I add a page via Page:Insert
Please make sure that the "Automatic text box" option is unchecked whenever you create a new project to avoid the addition of the pages
Aug 25, 2009 | QuarkXPress 6.5
All my CMYK images in quark xpress print fine, but my text will only print in black. is there a setting I need to change?
Please check the color for the text. also check if you get the same results in PDF as well
Aug 02, 2009 | QuarkXPress 4.1 for mac
Trying to link text boxes
Just keep the text box tool pressed in the Tools palette and you would notice the Linking tool there
Mar 30, 2009 | QuarkXPress
Quark XPress 4.1
quarkxpress_56302.jpg Related Tags:
  • quark
  • xp
  • windows 7
  • windows xp
Problem with Quark QuarkXPress
How can I install my Quark 7 on my new Windows 7? All I get is 'QuarkXpress 7 requires that your computer is running Windows XP or Windows 2003. Help!
Posted by avatar15.jpgNervousFlyer on May 29, 2010
Solutions (2) Start the Windows "Program Compatibility Wizard".
Tell it that you want to install a Windows XP application.
Tell it that the software to be installed is on a CD-ROM.
I continue to be amazed that no body has found THE elegant solution I did. As a matter of fact I am using Quark 4 on Window 7, I used it on Vista (where it performed better than Vista) and on XP back at least to 98 or perhaps 95. My original install required burning a floppy (good luck with that today) for the registration. At some point, I discovered it was truly portable and simply copied the installed Quark directory to a new location (anywhere) on each new system. I dragged out a shortcut onto the desktop to the executable on every new platform. It still runs fine on this 64bit Window 7. Has not blown up yet. Something I wish I could say about other software. The only rub I found is that MS monkeyed about with associations (which worked fine in XP & Vista) and I have yet to be able to set.QXDs to Quark when I even set .QXTs to Quark.Windows 7 automatically served up In-Design as being the first (default) association in my programs list. Something I did not accept. I even tried to rewrite the registry in an attempt to make it work.
MikeE
Jan 04, 2009 | QuarkXPress Passport 4.1 (112283) for PC
6.52 KERN_PROTECTION_FAILURE
Please let me know when exactly does QuarkXPress crashes
May 28, 2008 | QuarkXPress
Lost items in Quark 6.1
the only way to get the text back is to import it again
Sep 20, 2007 | Quark Academic QuarkXPress 6.1 for PC
QuarkXPress Logo
1,388 people viewed this question
Top Quark Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Laxman Bisht
Laxman Bisht
Are you a Quark Computer and Internet Expert? Answer questions, earn points and help others
