Question about Goodman Manufacturing Goodman GSX130301 GKS90703BX CAPF3030B6 Gas Furnace 2.5 Ton 13 SEER 92.1% AFUE 70000 BTU System
Will not light - Goodman Manufacturing Goodman GSX130301 GKS90703BX CAPF3030B6 Gas Furnace 2.5 Ton 13 SEER 92.1% AFUE 70000 BTU System
I have got hotpoint -ultima super silent wf 865 is getting sign f-12 pl let me know the solution.
These are the error codes : I hope it helps!
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
So in this instance with the second light flashing the error code would be f04 light 2. pressure switch stuck on empty
Nov 11, 2014 | Washing Machines
2006 brake light will not go out
Light gets power from brake light switch/.May be switch got shorted an brake light getting non-stop power causing it not to turn OFF brake light.
Get the brake light switch checked. Check volt at brake light switch.
It can be faulty brake light switch causing the problem or its wiring short for switch.
To trouble shoot brake related problem, check the help links mentioned below:-----
Click the link:----
1996 Buick Regal Grand Sport Brake light Switch Location?
http://schematicsdiagram.blogspot.in/2012/04/1996-buick-regal-gran-sport-brake-light.html
No brake lights on Buick?
http://schematicsdiagram.blogspot.in/2012/04/no-brake-lights-on-buick.html
Brake lights not working on 1989 BUICK REGAL?
http://schematicsdiagram.blogspot.in/2012/04/brake-lights-not-working-on-1989-buick.html
How to replace Brake light switch on Chevrolet Tahoe?
http://technoanswers.blogspot.in/2012/02/how-to-replace-brake-light-switch-on.html
How to replace Parking, turn, and Brake Lights on car?
http://schematicsdiagram.blogspot.com/2011/06/how-to-replace-parking-turn-and-brake.html
Upper brake lights work, but low brake light not working?
http://schematicsdiagram.blogspot.com/2011/12/upper-brake-lights-workbut-low.html
1997 Cadillac Catera: How to replace Brake Light Switch?
http://howtobyme.blogspot.in/2012/06/1997-cadillac-catera-how-to-replace.html
1996 Chrysler LHS brake light circuit wiring diagram?
http://technoanswers.blogspot.in/2012/02/1996-chrysler-lhs-brake-light-circuit.html
How to replace rear Brake lights on 2004 Toyota RAV4?
http://schematicsdiagram.blogspot.in/2012/02/how-to-replace-rear-brake-lights-on.html
One brake light on driver side not working, but other lights work?
http://schematicsdiagram.blogspot.com/2011/12/one-brake-light-on-driver-side-not.html
2002 Lincoln Town car Fuse Box
http://schematicsdiagram.blogspot.com/2012/11/2002-lincoln-town-car-fuse-box.html
2007 KIA Rio: Brake Light Fuse Box Diagram?
http://repairhelpcenter.blogspot.in/2012/06/2007-kia-rio-brake-light-fuse-box.html
Overhead Brake lights not working on 1999 GMC Sierra 4x4?
http://technoanswers.blogspot.in/2012/03/overhead-brake-lights-not-working-on.html
http://schematicsdiagram.blogspot.com/2012/11/brake-lights-not-working.html
2004 Ford Mustang: Brake light Fuse Location?
http://howtobyme.blogspot.in/2012/05/2004-ford-mustang-brake-light-fuse.html
These will help.
Thanks.
Nov 28, 2012 | Cars & Trucks
What bulb is the turn signal bulb on a 2002 oldsmobile alero
On 2002 Oldsmobile Alero Car Light Bulb Size, check this list:
Low Beam Headlight Bulb Size: 9006 or 9006 HID Upgrade KitHigh Beam Headlight Bulb Size: 9005 or 9005 HID Upgrade KitParking Light Bulb Size: 3157NALLFront Turn Signal Light Bulb Size: 3157NALLRear Turn Signal Light Bulb Size: 3157LLTail Light Bulb Size: 3157LLStop Light Bulb Size: 3157LLHigh Mount Stop Light Bulb Size: 921Fog/Driving Light Bulb Size: 894License Plate Light Bulb Size: 194Back Up Light Bulb Size: 921Front Side Marker Light Bulb Size: 194Rear Side Marker Light Bulb Size: 2825Glove Box Light Bulb Size: 194Map Light Bulb Size: 212-2Dome Light Bulb Size: 212-2 or 561Step/Courtesy Light Bulb Size: 168 or 73Trunk/Cargo Area Light Bulb Size: 211-2
Hope helps.
Apr 25, 2012 | 2002 Oldsmobile Alero
F-03
f16 N/A
f1 and f17 share the same light
Jun 21, 2011 | Indesit W 123 Front Load Washer
E03 error code
Error Codes
f16 N/A
Aug 09, 2010 | Siemens WTXD8300 Electric Dryer
No backlight or key pad light nokia e71
There is a light sensor in your Nokia E71
This light sensor senses the outside light and activates the keypad light accordingly.
When you have enough backround light the keypad light wont light up.If the background light is less then the keypad light wil light up.
You dont get the keypad light ON because the light sensor might have activated.
If in dark also you wont get the keypad light on then the fault lies with the keypad light unit.please give your mobile to the nearest authorised service centre for service.
Thanx
Jul 26, 2010 | Nokia E71 Smartphone
Drivers side brake light and horn won't work,,is it the multi function switch? 1999 chev blazer 4x4 . if so how much does a new one cost?
No there not connected, replace the brake light
1999 Chevrolet Blazer Auto Light Bulb Size Guide
High Beam Headlamp Light Bulb Size: 9005
Rear Turn Signal Light Bulb Size: 3057
Tail Light Bulb Size: 3057
Stop Light Bulb Size: 3057
High Mount Stop Light Bulb Size: Assembly
Fog/Driving Light Bulb Size: 880 or 881
Back Up Light Bulb Size: 3156
Front Sidemarker Light Bulb Size: 194
Ash Tray Light Bulb Size: 161
Map Light Bulb Size: 168 or 211-2
Step/Courtesy Light Bulb Size: 168 or 211-2
Under Hood Light Bulb Size: 93
Instrument-General Light Bulb Size: 161 or 37 or PC194 or PC74
Check Engine Indicator Light Bulb Size: PC74
Hi-Beam Indicator Light Bulb Size: PC74
Seat Belt Indicator Light Bulb Size: PC194
Brake Warning Light Bulb Size: PC74
Automatic Transmission Indicator Light Bulb Size: 194
Directional Signal Indicator Light Bulb Size: PC74
As for the horn, inspect the fuse and relay and most common it would be a bad ground wire or worst a bad horn due to corrosion. Horn will be located in the drivers side fender.
Thank you for using fixya.
May 13, 2010 | 1999 Chevrolet Blazer
2000 pontiac montana. I want to replace the driving ligh bulbs. the under the headlights what size is it?
Here is the rest of the bulb size used in your Montana.
2000 Pontiac Montana Auto Light Bulb Diagram
Low Beam Headlight Bulb Size: 9004
High Beam Headlamp Light Bulb Size: 9004
Parking Light Bulb Size: 4157NALL
Front Turn Signal Light Bulb Size: 4157NALL
Rear Turn Signal Light Bulb Size: 3156
License Plate Light Bulb Size: 168
Ash Tray Light Bulb Size: 558
Dome Light Bulb Size: 562
Trunk/Cargo Area Light Bulb Size: 212-2
Daytime Running Light Bulb Size: 3157NALL
Apr 30, 2010 | 2000 Pontiac Montana
I have a 1991 Accord. Brake Light is not lighted up
Look for a Bad Ground wire connection that Links the Tail Light and Trunk Light.
Regards, DT
Aug 28, 2009 | 1991 Honda Accord
I have a 2001 hyundai elantra and the warning lights on the dashboard. I know what the oil light looks like and the airbags. What are the other two lights.
Your best bet is to go HERE and signup for a free account then Downloading your Manual - service sheets, diagrams, parts lists etc.
Hyundai is one of the best with providing their customers with free information about the vehicles!!
I have D/L the manual, and the warning lamps on the instrument cluster are...
Left to right...(starting under temp. Gauge)
WITHOUT TRIP COMPUTER
11. Traction Control Indicator Light (If installed)
12. ABS Warning Light (If installed)
13. Seat Belt Warning Light
14. Oil Pressure Warning Light
15. Charging System Warning Light
16. Parking Brake/Brake Fluid Level Warning
Light
17. Malfunction Indicator Light (MIL)
18. SRS (Airbag) Warning Light
19. Trip Odometer/Odometer
20. Trip Odometer Reset Knob
21. Low Fuel Warning Light
WITH TRIP COMPUTER
7. Front Fog Indicator Light (If installed)
8. Door Ajar Warning Light
9. Trunk Lid Open Warning Light
10. Parking Brake/Brake Fluid Level Warning
Light
11. Malfunction Indicator Light (MIL)
12. Charging System Warning Light
13. Oil Pressure Warning Light
14. SRS (Airbag) Warning Light
15. Cruise Indicator Light (If installed)
16. Seat Belt Warning Light
17. ABS Warning Light (If installed)
18. Traction Control Indicator Light (If installed)
19. Automatic Transaxle Position Indicator Light
(Auto T/A only)
22. Low Fuel Warning Light
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 21, 2009 | 2001 Hyundai Elantra
Goodman Manufacturing Goodman GSX130301 GKS90703BX CAPF3030B6 Gas Furnace 2.5 Ton 13 SEER 92.1% AFUE 70000 BTU System Logo
12 people viewed this question
Top Goodman Manufacturing Heating & Cooling Experts
bobalix
snowmanii
ray gallant
Are you a Goodman Manufacturing Heating and Cooling Expert? Answer questions, earn points and help others
