Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Cuts out after 5mins
My dyson stops working after 5mins, just cuts out. will start working again when it has cooled down. I have cleaned all the filters and the cyclone, but this has made no difference.
  • luckystars Aug 09, 2008
    The vacuum (dyson DC07) will work for a few minutes, then just cut out. I have emptied the dust bin and cleaned the filter. What are my other options before I have to replace parts?
  • 372 Answers
Hi Dave. The chances are that the thermal protect device is faulty or the carbon brushes are on there way out.
Posted on Sep 02, 2007
Dyson stopped working.
Have you tried starting it again? It might have stopped because it overheated and now that it has cooled it should start again. If not, then possibly the power switch or power cord has failed.
May 26, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson dc07 keeps cutting out after few minutes
This is a sure sign of a blockage. The motor cuts out because it gets too hot and will start again when it has cooled. Follow the instructions in your user manual for clearing blockages (you can download a copy from the Dyson website if necessary). Make sure the washable filter is clean too (and completely dry before you use it).
Jan 15, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson working one moment then it completely cuts out
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Most Dyson cleaners have a thermal cut-out to protect the motor from overheating in the event of a restriction to the airflow. So, if anything causes it to overheat, it will switch off. If this happens, leave the cleaner switched off for at least two hours, as it will not start again until it has cooled down.
The most common cause of a cut-out is that the cleaner has a blockage or the filter needs washing. A high room temperature may also trigger it. Before you continue vacuuming, ensure the filter is clean and there are no blockages. You can download the user guide at www.dyson.co.uk/support/. Just click on ‘Get Expert Help’ then ‘Using my Dyson product’ then ‘User Guide’.
Dec 24, 2009 | Dyson DC07 All Floors Bagless Upright...
Run cut off -run cut off every ten minutes
The TOC(thermal overload cutout) on the motor is getting too hot - thats why it keeps shutting off and starting again once its cooled, so make sure your filters are clean and they are no blockages in the hose or the brushbar compartment or any where else
Which dyson is it?
Aug 31, 2009 | Dyson Vacuums
Just stopped mid hoovering and now won't switch on!
It is probably a thermal cut-off which is caused by a blockage. The machine will turn itself off before it overheats if it is a thermal cut-off. Once it has cooled down, you will be able to turn it back on again (usually 30 mins - 1 hour).
If the machine doesn't turn on at all anymore, you may need to replace the power switch. Call the Dyson helpline, they will do a blockage troubleshoot and if it's not that, they will tell you where you can find an authorized Dyson repair dealer in your area.
Jul 07, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson Quits
cut out switch on the motor needs replacing this overheats and cuts of the motor when the motor cools down it will start again you have to keep both filters and cyclone clean and free of dust or after replacement the same will happen again
Sep 04, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson
the automatic cut out switch on the motor needs replacing when the motor gets hot this switch comes in and stops the motor from overheating when the motor cools down the cleaner will work again and cut out again when the motor gets hot if it is not replaced it will eventually burn the motor out after the switch has been replaced both the filter and cyclone need to be cleaned on a regular basis or the same will happen again
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
129 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
